[mpich-discuss] unable to build mpich2 with romio
Ryan Kroiss rrkroiss at lanl.gov
Mon Jan 25 14:08:08 CST 2010
I do have a src/mpl/confdb directory and I'm using svn 1.4.2.  I'll try
upgrading to the latest version of svn (I believe 1.6.9).
Ryan
Dave Goodell wrote:
> The AX_PREFIX_CONFIG_H macro isn't being expanded for some reason.
> The macro comes from "src/mpl/confdb/ax_prefix_config_h.m4", and the
> "src/mpl/confdb" directory is a bit special because it is an SVN
> external.  Not only is it an SVN external, but it's a "relative"
> external, which is a feature that was added in SVN 1.5 [1].
> Do you have a "src/mpl/confdb" directory?
> What version of SVN are you using?  Running "svn --version" should
> tell you.  Please upgrade to 1.5 or later if you wish to use the SVN
> version of MPICH2.
> -Dave
> [1] http://svnbook.red-bean.com/en/1.5/svn.advanced.externals.html
> (see the paragraph "As of Subversion 1.5, though, a new format [...]")
> On Jan 22, 2010, at 2:58 PM, Ryan Kroiss wrote:
>> I'm having trouble building mpich2 with ROMIO enabled.  I need this
>> so that I can work with IOFSL.  I've followed the instructions found
>> at <https://trac.mcs.anl.gov/projects/iofsl/wiki/Building>.  I'm
>> running automake version 1.11.1, autoconf version 2.63, and libtool
>> version 2.2.6b.  I believe that I was able to run ./maint/updatefiles
>> successfully (at least it completed without complaining).  After
>> running this, I'm trying to run the following command:  ./configure
>> --enable-romio --with-file-system=ufs+zoidfs.  I get the following
>> error though:
>> /home/rrkroiss/libs/mpich2/src/mpl/configure: line 11066: syntax
>> error near unexpected token `include/mplconfig.h,MPL'
>> `AX_PREFIX_CONFIG_H(include/mplconfig.h,MPL)'
>> configure: error: MPL configure failed
>> Any help would be appreciated!
>> Thanks,
>> Ryan
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
