[mpich-discuss] New communicator from connect/accept primitives
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Wed Jan 20 11:34:32 CST 2010
 I have modified your code (You can download the same at http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/temp/test_inter_modif.tar.gz) and it works for me (The code is now closer to Rajeev's suggestions).
 Let me know if it works for you.
Jayesh
----- Original Message -----
Sent: Wednesday, January 20, 2010 6:47:14 AM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] New communicator from connect/accept primitives
I my algorithm server A was connected to 2 clients B and C. Since you have one client connected to 2 servers, I suggested you call
the client A and the servers B and C and follow the same algorithm. A is the common point that has connections to both B and C,
hence it is important to follow the algorithm as provided. Also, in one of your files I saw MPI_COMM_NULL as a communicator to
MPI_Intercomm_create. Although I haven't studied the code in detail, I don't think you can pass COMM_NULL. Use COMM_WORLD as in my
algorithm.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
> Francisco Javier García Blas
> Sent: Wednesday, January 20, 2010 4:40 AM
> Hello again,
> Rajeev, to clarify the code, I put signatures A,B, and C on each file.
> Jayesh, On  MPI_Intercomm_create( comm_agg, 0, pool_comm[1],
> 1, 12345 , &comm_aux ) the size of the peer comunicator  is
> 1, therefore, passing 1 is incorrect, right?
> I got the next error stack on serverC when the last
> MPI_Comm_create is invoked. Rest of processes run fine:
> No matching pg foung for id = 1024812961 Fatal error in
> MPI_Intercomm_create: Internal MPI error!, error stack:
> MPI_Intercomm_create(580).: MPI_Intercomm_create(MPI_COMM_SELF,
> local_leader=0, comm=0x84000001, remote_leader=0, tag=12346,
> newintercomm=0xbfb0a790) failed
> MPID_GPID_ToLpidArray(382): Internal MPI error: Unknown gpid
> (1289156231)0[cli_0]: aborting job:
> Fatal error in MPI_Intercomm_create: Internal MPI error!, error stack:
> (1289156231)0
> rank 0 in job 9  compute-1-0_45339   caused collective abort
> of all ranks
>   exit status of rank 0: return code 1
> Thanks for all your time.
> Best regards
> jayesh at mcs.anl.gov escribió:
> > Hi,
> >  Rajeev, correct me if I got it wrong...
> >  On the client side when creating the intercommunicator you
> should specify the client_B intercommunicator with the
> client_A intracommunicator (MPI_Intercomm_create( comm_agg,
> 0,  pool_comm[1], 1, 12345  , &comm_aux ); ).
> >  Similarly on the server B side you should specify the client_B
> > intercommunicator with the local communicator in B
> (MPI_Intercomm_create( comm_world, 0, comm_inter, 0, 12345 ,
> &comm_aux ); ).
> >  Let us know if it works.
> > Regards,
> > Jayesh
> > From: "Francisco Javier García Blas" <fjblas at arcos.inf.uc3m.es>
> > To: jayesh at mcs.anl.gov
> > Cc: mpich-discuss at mcs.anl.gov
> > Sent: Tuesday, January 19, 2010 10:20:46 AM GMT -06:00 US/Canada
> > Central
> > primitives
> > Hi Jayesh,
> > I haven't problem with MPI_Intercomm_merge. I tried to
> merge using different directions successfully. I checked also
> the size of the new intracommunicator after merging and it is
> correct too (size 2).
> > Additionally, yesterday I tried with MPI_Comm_spawn +
> MPI_Intercomm_create examples at testcase without problems.
> In these cases all the processes on the same group have same
> intercommunicators. However, in my case, I am doing something
> wrong when three processes call MPI_Intercomm_create over two
> remote groups. (AB intra, C inter). Arguments mistake maybe?
> > As suggested Dave, I tried my example with the lasted
> stable version of MPICH2, with similar results.
> > Thanks for all
> > Regards
> > El 19/01/2010, a las 16:22, jayesh at mcs.anl.gov escribió:
> > Hi,
> > I haven't looked at your code yet. You can look at the
> testcase, testconnect.c (
> https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/test/mpi/manual
> /testconnect.c ), in the MPICH2 test suite for a simple
> example on how to use connect/accept and intercomm_merge to
> create an intracommunicator.
> > -Jayesh
> > From: "Francisco Javier García Blas" < fjblas at arcos.inf.uc3m.es >
> > Sent: Monday, January 18, 2010 10:26:08 AM GMT -06:00 US/Canada
> > Central
> > primitives
> > Hello again,
> > In first place, thanks for response of Rajeev and Jayesh. Following
> > Rajeev 's instruccion, I implemented an basic example using
> > connect/accept and intercomm_create/merge primitives. I am doing
> > something wrong because when MPI_Intercomm_create is
> invoked, all the
> > processes become blocked. I don't find the error, maybe it
> could be a
> > bad numeration in local and remote communicator but I tried all the
> > combinations.
> > I am using mpich2 1.0.5.
> > I attach the source code and a makefile.
> > Best regards
> > Rajeev Thakur escribió:
> > You will need to use intercomm_merge but you have to merge them one
> > pair at a time. Example below from an old mail.
> > Rajeev
> > If you have 3 intercommunicators AB_inter, AC_inter, and
> AD_inter, you
> > can merge them all into a single
> > intercommunicator as follows:
> > * begin by doing an MPI_Intercomm_merge on AB_inter, resulting in an
> > intracommunicator AB_intra.
> > * then create an intercommunicator between AB on one side
> and C on the
> > other
> > by using MPI_Intercomm_create. Pass AB_intra as the local_comm on A
> > and B,
> > MPI_COMM_WORLD as the intracomm on C, and AC_inter as the
> peer_comm.
> > This
> > results in the intercommunicator AB_C_inter.
> > * then call MPI_Intercomm_merge on it to create the
> intracommunicator
> > ABC_intra.
> > * then call MPI_Intercomm_create to create an intercommunicator
> > between ABC
> > and D just as you did with AB and C above.
> > * Again do an intercomm_merge. This will give you an
> intracommunicator
> > containing A, B, C, D.
> > * If you want an intercommunicator with A in one group and B,C,D in
> > the
> > other, as you would get with a single spawn of 3 processes, you have
> > to call
> > MPI_Comm_split to split this single communicator into two
> > intracommunicators, one containing A and the other
> containing B,C,D.
> > Then
> > call MPI_Intercomm_create to create the intercommunicator.
> > *From:* mpich-discuss-bounces at mcs.anl.gov
> > [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of
> > *Francisco Javier García Blas
> > *Sent:* Friday, January 15, 2010 11:09 AM
> > *To:* mpich-discuss at mcs.anl.gov
> > *Subject:* [mpich-discuss] New communicator from connect/accept
> > primitives
> > Hello all,
> > I wondering the possibility of get a new inter-comunicator from N
> > communicators, which are results from different calls of
> > mpi_comm_connect or mpi_comm_accept.
> > My initial solution was first, to get the group of each
> > inter-communicator with mpi_comm_group, second, to join all the
> > groups into one bigger and finally, to create a new communicator
> > from the group with the mpi_comm_create primitive.
> > Currently I am handling a pool of inter - communicators in order
> > to keep the functionality. However this idea is not suitable for
> > collective and MPI_ANY_SOURCE sends/recvs.
> > Exist another way to join all the inter-communicator into one?
> > Any suggestion?
> > Best regards.
> > Computer Architecture, Communications and Systems Area.
> > Computer Science Department. UNIVERSIDAD CARLOS III DE MADRID
> > Avda. de la Universidad, 30
> > 28911 Leganés (Madrid), SPAIN
> > e-mail: fjblas at arcos.inf.uc3m.es < mailto:fjblas at arcos.inf.uc3m.es >
> > fjblas at inf.uc3m.es < mailto:fjblas at inf.uc3m.es >
> > Phone:(+34) 916249118
> > FAX: (+34) 916249129
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> MADRID Avda. de
> > la Universidad, 30
