[mpich-discuss] New communicator from connect/accept primitives
    Rajeev Thakur
    thakur at mcs.anl.gov
    Fri Jan 15 12:16:34 CST 2010
You will need to use intercomm_merge but you have to merge them one pair
at a time. Example below from an old mail.
Rajeev
If you have 3 intercommunicators AB_inter, AC_inter, and AD_inter, you
can merge them all into a single
intercommunicator as follows:
* begin by doing an MPI_Intercomm_merge on AB_inter, resulting in an
intracommunicator AB_intra.
* then create an intercommunicator between AB on one side and C on the
other
by using MPI_Intercomm_create. Pass AB_intra as the local_comm on A and
B,
MPI_COMM_WORLD as the intracomm on C, and AC_inter as the peer_comm.
This
results in the intercommunicator AB_C_inter.
* then call MPI_Intercomm_merge on it to create the intracommunicator
ABC_intra.
* then call MPI_Intercomm_create to create an intercommunicator between
ABC
and D just as you did with AB and C above.
* Again do an intercomm_merge. This will give you an intracommunicator
containing A, B, C, D.
* If you want an intercommunicator with A in one group and B,C,D in the
other, as you would get with a single spawn of 3 processes, you have to
call
MPI_Comm_split to split this single communicator into two
intracommunicators, one containing A and the other containing B,C,D.
Then
call MPI_Intercomm_create to create the intercommunicator.
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Francisco Javier
García Blas
Sent: Friday, January 15, 2010 11:09 AM
Subject: [mpich-discuss] New communicator from connect/accept primitives
Hello all,
I wondering the possibility of get a new inter-comunicator from N
communicators, which are results from different calls of
mpi_comm_connect or mpi_comm_accept.
My initial solution was first,  to get the group of each
inter-communicator with mpi_comm_group, second, to join all the groups
into one bigger and finally, to create a new communicator from the group
with the mpi_comm_create primitive.
Currently I am handling a pool of inter - communicators in order to keep
the functionality. However this idea is not suitable for collective and
MPI_ANY_SOURCE sends/recvs.
Exist another way to join all the inter-communicator into one?
Any suggestion?
Best regards.
Francisco Javier García Blas
Computer Architecture, Communications and Systems Area.
Computer Science Department. UNIVERSIDAD CARLOS III DE MADRID
Avda. de la Universidad, 30
28911 Leganés (Madrid), SPAIN
e-mail: fjblas at arcos.inf.uc3m.es
              fjblas at inf.uc3m.es
Phone:(+34) 916249118
FAX: (+34) 916249129
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100115/9b85cae7/attachment.htm>
