[mpich-discuss] mpdboot beheviour
    Cezary Śliwa
    sliwa at cft.edu.pl
    Fri Jan 15 10:57:44 CST 2010
Hello,
Regarding mpdboot in mpich2-1.2.1. The default is to use --ncpus=1
rather than the value from  mpd.hosts. Does it make sense? Why not use
the value from mpd.hosts as the default?
In case of running a job under PBS or SGE, the correct number is in the
file. At present, one has to extract this information from the file and
put it on the mpdboot command line. This is cumbersome.
Moreover, if the host running mpdboot is not in mpd.hosts, it makes
sense to use --ncpus=0 as the default.
Cezary Sliwa
