[mpich-discuss] halt after mpiexec
Gao, Yi
gaoyi.cn at gmail.com
Thu Jan 14 12:18:31 CST 2010
Hi Dave,
I reinstalled mpich2 from apt-get on Ubuntu9.10, instead of my compiled version.
I think now it works:
I compiled cpi.c on all 3 machines, putting them to same location,
then using mpiexec.hydra and they work.
Although this does not work if I added a 64bit ubuntu9.10 machine into
the game, it's enough for me to do some prototyping. :)
Thanks!
Best,
yi
On Thu, Jan 14, 2010 at 12:09 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> Copying the cpi binary from one machine to the others (in the same path)
> should work fine, as long as all machines are running the same OS and
> processor type (x86 versus x86_64 versus PPC, etc).
> -Dave
> On Jan 14, 2010, at 10:33 AM, Gao, Yi wrote:
>> Hi Dave,
>> I tried the mpiexec.hydra -f hostfile -n 3 /path/to/cpi
>> with the hostfile being:
>> rome
>> meg
>> julia
>> but it halt with output:
>> Process 1 of 3 is on julia
>> Process 2 of 3 is on meg
>> ^CTerminated (signal 15) // after I press ^C
>> Then I remove the rome line in hostfil, leaving only
>> meg
>> julia
>> This time it runs, say for -n 4, I get great output as:
>> Process 2 of 4 is on julia
>> Process 1 of 4 is on meg
>> Process 3 of 4 is on meg
>> Process 0 of 4 is on julia
>> pi is approximately 3.1415926544231243, Error is 0.0000000008333312
>> wall clock time = 0.001271
>> In fact, only using julia and meg, two single core machine, using
>> mpdboot, mpiexec also worked.
>> Anthony pointed out in a previous email that I might be using
>> different binary cpi files. However on all the machines, 1. cpi
>> resides in the same path. 2. Since the machines are different
>> (although OS and compilers are fresh installed and are the same), does
>> copying one binary to other work?
>> Thanks!
>> Best,
>> yi
>> On Thu, Jan 14, 2010 at 11:12 AM, Dave Goodell <goodell at mcs.anl.gov>
>> wrote:
>>> Sorry, I gave poor instructions on using hydra. Because there is no
>>> mpdboot
>>> step in normal hydra usage, you need to specify a hostfile for hydra when
>>> running mpiexec:
>>> Where hostfile should contain in your case:
>>> --------8<-------
>>> rome
>>> meg
>>> julia
>>> --------8<-------
>>> -Dave
>>> On Jan 14, 2010, at 9:58 AM, Gao, Yi wrote:
>>>> Hi Dave,
>>>> Thanks for the advice. I followed your two suggestions (MPICH_NO_LOCAL
>>>> and mpiexec.hydra) and tried as follows:
>>>> 1. use MPICH_NO_LOCAL=1 mpiexec -n i /path/to/cpi
>>>> i=1, no problem, runs on rome (2-core-machine) with one process and
>>>> exit.
>>>> i=2, halt with the output:
>>>> Process 1 of 2 is on meg // meg has 1 core
>>>> i = 3, halt like this:
>>>> Process 2 of 3 is on julia // julia has 1 core
>>>> Process 1 of 3 is on meg
>>>> i=4, halt like this:
>>>> i=5, halt like this:
>>>> Process 2 of 5 is on julia
>>>> Process 1 of 5 is on meg
>>>> Process 4 of 5 is on meg
>>>> In all halt cases above, when doing a top at the meg or julia, the cpu
>>>> is 100% used. For i=5 case, seems that 2 threads are running on a
>>>> single core machine(meg), each of which takes about 50% cpu when
>>>> testing with top. None of the above shows rome, the 2core machine, in
>>>> the output.
>>>> So, comparing with situation without "MPICH_NO_LOCAL=1", this time it
>>>> only stops there without giving some error message.
>>>> 2. mpiexec.hydra -n i /path/to/cpi
>>>> 2.1
>>>> First, it asked me to add local host to known hosts: and I answered yes.
>>>> The authenticity of host 'localhost (::1)' can't be established.
>>>> RSA key fingerprint is 3e:62:41:30:a8:40:33:7e:b4:34:8e:2c:f4:37:43:20.
>>>> Are you sure you want to continue connecting (yes/no)? yes
>>>> Warning: Permanently added 'localhost' (RSA) to the list of known hosts.
>>>> Process 2 of 3 is on rome
>>>> Process 1 of 3 is on rome
>>>> Process 0 of 3 is on rome
>>>> pi is approximately 3.1415926544231323, Error is 0.0000000008333392
>>>> wall clock time = 0.008936
>>>> 2.2
>>>> The above case is when i=3, it runs and exit without error message.
>>>> However, seems that all processes are on the machine issuing the
>>>> command (rome). And this is the case for i=1,2, ..., 10. (I think if I
>>>> keep on, it'll still be the case....)
>>>> 2.3
>>>> Even if I ran: mpiexec.hydra -n i /bin/hostname
>>>> I got i "rome"'s, which is not as expected....
>>>> 2.4
>>>> Using mpdtrace -l on rome, I get normal output.
>>>> rome_53533 (128.61.134.31)
>>>> meg_46371 (128.61.134.44)
>>>> julia_53931 (128.61.135.30)
>>>> 3.
>>>> I set my first step objective as just utilizing one core per machine
>>>> no matter how many it may have. When that works, then further
>>>> exploiting SMP on each node might be the next step.
>>>> Thank you for the suggestion!
>>>> Best,
>>>> yi
>>>> On Thu, Jan 14, 2010 at 10:09 AM, Dave Goodell <goodell at mcs.anl.gov>
>>>> wrote:
>>>>> Hi yi,
>>>>> I'm not sure exactly what's going on here, but it looks like rank 3 is
>>>>> trying to setup a shared memory region for communication with another
>>>>> rank
>>>>> even though it shouldn't be.
>>>>> There's a chance that this is related to a bug in the way that mpd
>>>>> figures
>>>>> out which processes are on which machine. Can you try setting the
>>>>> environment variable MPICH_NO_LOCAL=1 and let us know what happens?
>>>>> For
>>>>> example:
>>>>> MPICH_NO_LOCAL=1 mpiexec -n 3 /path/to/cpi
>>>>> In a similar vein, you can also try using hydra to rule out the mpd
>>>>> issue:
>>>>> mpiexec.hydra -n 3 /path/to/cpi
>>>>> There are other things we can look at, but let's start there and see if
>>>>> that
>>>>> works out for us.
>>>>> -Dave
>>>>> On Jan 14, 2010, at 12:00 AM, Gao, Yi wrote:
>>>>>> Dear all,
>>>>>> I'm new here and encounter a problem at the very beginning of learning
>>>>>> mpi.
>>>>>> Basically, I get
>>>>>> mpiexec -n i /bin/hostname
>>>>>> works for any i >= 1 I've tested.
>>>>>> but
>>>>>> mpiexec -n i /path-to-example-dir/cpi
>>>>>> error for any i >= 2
>>>>>> The details are:
>>>>>> I have 3 machines, all running Ubuntu 9.10 with gcc/g++ 4.4.1
>>>>>> one has two cores, and the other two have one core for each.
>>>>>> (machine name: rome, 2 core;
>>>>>> julia, 1 core;
>>>>>> meg, 1 core )
>>>>>> On this minimal testing bed for me to learn mpi, I built using
>>>>>> mpich2-1.2.1 using the default configure in "installation guide"
>>>>>> Then on "rome", I put the mpd.hosts file in home dir with content:
>>>>>> julia
>>>>>> meg
>>>>>> Then I ran
>>>>>> mpdboot -n 3 # works
>>>>>> mpdtrace -l # works, show the three machine names and port num
>>>>>> mpiexec -l -n 3 /bin/hostname # works! show three machine names
>>>>>> but
>>>>>> mpiexec -l -n 3 /tmp/gth818n/mpich2-1.2.1/example/cpi # !!!!!!!! it
>>>>>> halted there.
>>>>>> Then I tried:
>>>>>> mpiexec -l -n 1 /tmp/gth818n/mpich2-1.2.1/example/cpi # works, run on
>>>>>> rome only and returns the result
>>>>>> But -n larger or equal than 2 causes it to halt, or getting such
>>>>>> errors (with -n 4):
>>>>>> Fatal error in MPI_Init: Other MPI error, error stack:
>>>>>> MPIR_Init_thread(394).................: Initialization failed
>>>>>> MPID_Init(135)........................: channel initialization failed
>>>>>> MPIDI_CH3_Init(43)....................:
>>>>>> MPID_nem_init(202)....................:
>>>>>> MPIDI_CH3I_Seg_commit(366)............:
>>>>>> MPIU_SHMW_Hnd_deserialize(358)........:
>>>>>> MPIU_SHMW_Seg_open(897)...............:
>>>>>> MPIU_SHMW_Seg_create_attach_templ(671): open failed - No such file or
>>>>>> directory
>>>>>> rank 3 in job 12 rome_39209 caused collective abort of all ranks
>>>>>> exit status of rank 3: return code 1
>>>>>> Then, I rebuild mpich2 on rome (coz it's SMP), with
>>>>>> --with-device=ch3:ssm
>>>>>> But got same error.
>>>>>> Could any one gives me some directions to go?
>>>>>> Thanks in advance!
>>>>>> Best,
>>>>>> yi
>>>>>> _______________________________________________
>>>>>> mpich-discuss mailing list
>>>>>> mpich-discuss at mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>>> Yi Gao
>>>> Graduate Student
>>>> Dept. Biomedical Engineering
>>>> Georgia Institute of Technology
Yi Gao
Graduate Student
