[mpich-discuss] Problem: *** gethostbyname_ex failed
    Brooks Garrison
    bgarisn at gmail.com
    Wed Jan 13 15:38:57 CST 2010
Hello all,
First let me preemptively say thank you for any and all help that can
be provided, as I had no where else to look really.
I've just started re-learning about MPI (had a class in college that
used it) and am trying to set MPICH2 on my local machine to try and
compile some example code (I don't have my Linux cluster set up just
yet) but I wanted to get familiar with the set up process before hand.
 I've been working through the installer's guide, Quick Start Section,
and have come across a snag that my limited experience with Linux
cannot solve.
I've completed the following:
1.  Unpacked the tar file to /home/bgarrison/libraries
2.  Created an install directory at /home/bgarrison/mpich2-install
3.  Created a build directory at /home/bgarrison/mpich2-build
4.  CD'd to the build directory and from there run the command:
         /home/bgarrison/libraries/mpich2-1.2.1/configure
--prefix=/home/bgarrison/mpich2-install 2>&1 | tee c.txt
     which produced the attached c.txt output that I checked for
errors and found none.
5.  I then ran the command:
         make VERBOSE=1 2>&1 | tee m.txt (I also ran it without the
VERBOSE option but thought I'd run it anyway to have the most
information)
     which produced the attached m.txt output that I checked for
6.  I then ran the command:
         make install 2>&1 | tee mi.txt
     which produced the attached mi.txt output that I checked for
7.  I then appended the PATH environment variable with
         /home/bgarrison/mpich2-install/bin
8.  I then checked to make sure everything was in order with the
following commands:
         which mpd        - > /home/bgarrison/mpich2-install/bin/mpd
         which mpicc      - > /home/bgarrison/mpich2-install/bin/mpicc
         which mpiexec  - > /home/bgarrison/mpich2-install/bin/mpiexec
         which mpirun- > /home/bgarrison/mpich2-install/bin/mpd
9.  I created the .mpd.conf file and added the secretword to it and
changed it's permissions.
Then when I tried to perform the first 'sanity check' as soon as I
typed "mpd &" I got the message:
bgarrison at STK:~$ mpd &
mpd failed: gethostbyname_ex failed for STK
I then looked at Appendix::A for trouble shooting advice:
"If you can ssh from each machine to itself, and from each machine to each
other machine in your set (and back), then you probably have an adequate
environment for mpd" ~ From Installation Guide
I'm able to SSH from my machine to itself (and I currently do not have
the other machines in yet, so I'm unsure about the rest of it), but
I'm still getting errors.  I checked to make sure that there were no
mpd were running as the guide suggests and then ran:
mpdcheck -s
And I get the result:
server listening at INADDR_ANY on: STK 49252
Which is an output that I should expect.  However, when I run the client using:
mpdcheck -c STK 49252
I get this result in the client terminal window:
Traceback (most recent call last):
  File "/home/bgarrison/mpich2-install/bin/mpdcheck", line 109, in <module>
    sock.connect((argv[argidx+1],int(argv[argidx+2])))  # note double parens
  File "<string>", line 1, in connect
socket.gaierror: (-5, 'No address associated with hostname')
Which is -not- an output I expect.  So then I ran:
mpdcheck -v
Result:
obtaining hostname via gethostname and getfqdn
gethostname gives  STK
getfqdn gives  STK
checking out unqualified hostname; make sure is not "localhost", etc.
checking out qualified hostname; make sure is not "localhost", etc.
obtain IP addrs via qualified and unqualified hostnames;  make sure
other than 127.0.0.1
*** gethostbyname_ex failed for this host STK
*** gethostbyname_ex failed for host STK
checking that IP addrs resolve to same host
And:
mpdcheck -l
Result:
    The system call gethostbyname(3) failed to resolve your
    unqualified hostname, or $uqhn. This can be caused by
    missing info from your /etc/hosts file or your system not
    having correctly configured name resolvers, or by your IP
    address not existing in resolution services.
    If you run DNS, you may wish to make sure that your
    DNS server has the correct forward A set up for your machine's
    hostname. If you are not using DNS and are only using hosts
    files, please check that a line similar to the one below exists
    in your /etc/hosts file:
$ipaddr $uqdn
    If you plan to use DNS but you are not sure that it is
    correctly configured, please check that the file /etc/resolv.conf
    contains entries similar to the following:
nameserver 1.2.3.4
    where 1.2.3.4 is an actual IP of one of your nameservers.
    fully qualified hostname, or $fqhn. This can be caused by
    If you run DNS, please check and make sure that your
    DNS server has the correct forward A record set up for your
    machine's hostname. If you are not using DNS and are only using
    hosts files, please check that a line similar to the one below
    exists in your /etc/hosts file:
$ipaddr $fqhn
    If you intend to use DNS but you are not sure that it is
nameserver 1.2.3.4
I am at a loss for what to do.  Is this a networking problem or is did
I mess something up in the download/install process? :(
Thanks for any and all help,
Brooks
now do some gethostbyaddr and gethostbyname_ex for machines in hosts file
Configuring MPICH2 version 1.2.1 with  '--prefix=/home/bgarrison/mpich2-install'
Running on system: Linux STK 2.6.24-26-generic #1 SMP Tue Dec 1 17:55:03 UTC 2009 x86_64 GNU/Linux
Executing mpich2prereq in /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3 with
Executing mpich2prereq in /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis
sourcing /home/bgarrison/libraries/mpich2-1.2.1/src/pm/mpd/mpich2prereq
sourcing /home/bgarrison/libraries/mpich2-1.2.1/src/pm/hydra/mpich2prereq
sourcing /home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/mpich2prereq
sourcing /home/bgarrison/libraries/mpich2-1.2.1/src/pm/mpd/setup_pm
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking whether C compiler accepts option -O2... yes
checking whether routines compiled with -O2 can be linked with ones compiled without -O2... yes
checking for type of weak symbol alias support... pragma weak
checking whether __attribute__ ((weak)) allowed... yes
checking whether __attribute ((weak_import)) allowed... yes
checking for multiple weak symbol support... yes
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking whether the C++ compiler c++ can build an executable... yes
checking whether C++ compiler works with string... yes
checking whether the compiler supports exceptions... yes
checking whether the compiler recognizes bool as a built-in type... yes
checking whether the compiler implements namespaces... yes
checking whether <iostream> available... yes
checking whether the compiler implements the namespace std... yes
checking whether <math> available... no
checking for GNU g++ version... 4 . 2
checking whether C++ compiler accepts option -O2... yes
checking for perl... /usr/bin/perl
checking for ar... ar
checking for ranlib... ranlib
checking for killall... killall
checking for a BSD-compatible install... /usr/bin/install -c
checking whether install works... yes
checking whether install breaks libraries... no
checking whether mkdir -p works... yes
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... no
checking for bash... /bin/bash
checking whether /bin/bash supports arrays... yes
checking for doctext... false
checking for location of doctext style files... unavailable
checking for an ANSI C-conforming const... yes
checking for working volatile... yes
checking for C/C++ restrict keyword... __restrict
checking for inline... inline
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
checking whether byte ordering is bigendian... no
checking whether C compiler allows unaligned doubles... yes
checking whether gcc supports __func__... yes
Using gcc to determine dependencies
checking whether long double is supported... yes
checking whether long long is supported... yes
checking for max C struct integer alignment... eight
checking for max C struct floating point alignment... sixteen
checking for max C struct alignment of structs with doubles... eight
checking for max C struct floating point alignment with long doubles... sixteen
configure: WARNING: Structures containing long doubles may be aligned differently from structures with floats or longs.  MPICH2 does not handle this case automatically and you should avoid assumed extents for structures containing float types.
checking if alignment of structs with doubles is based on position... no
checking if alignment of structs with long long ints is based on position... no
checking if double alignment breaks rules, find actual alignment... no
checking for alignment restrictions on pointers... int or better
checking size of char... 1
checking size of unsigned char... 1
checking size of short... 2
checking size of unsigned short... 2
checking size of int... 4
checking size of unsigned int... 4
checking size of long... 8
checking size of unsigned long... 8
checking size of long long... 8
checking size of unsigned long long... 8
checking size of float... 4
checking size of double... 8
checking size of long double... 16
checking size of void *... 8
checking for ANSI C header files... no
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking size of wchar_t... 4
checking size of float_int... 8
checking size of double_int... 16
checking size of long_int... 16
checking size of short_int... 8
checking size of two_int... 8
checking size of long_double_int... 32
checking sys/bitypes.h usability... yes
checking sys/bitypes.h presence... yes
checking for sys/bitypes.h... yes
checking inttypes.h usability... yes
checking inttypes.h presence... yes
checking for inttypes.h... yes
checking stdint.h usability... yes
checking stdint.h presence... yes
checking for stdint.h... yes
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking size of _Bool... 1
checking size of float _Complex... 8
checking size of double _Complex... 16
checking size of long double _Complex... 32
checking for _Bool... yes
checking for float _Complex... yes
checking for double _Complex... yes
checking for long double _Complex... yes
checking size of bool... 1
checking how to run the C++ preprocessor... c++ -E
checking complex usability... yes
checking complex presence... yes
checking for complex... yes
checking size of Complex... 8
checking size of DoubleComplex... 16
checking size of LongDoubleComplex... 32
checking if char * pointers use byte addresses... yes
checking for alignment restrictions on ... no
checking for alignment restrictions on int32_t... no
checking size of MPIR_Bsend_data_t... 88
checking for gcc __asm__ and pentium cmpxchgl instruction... no
checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction... yes
checking for gcc __asm__ and IA64 xchg4 instruction... no
checking for ANSI C header files... (cached) no
checking stdlib.h usability... yes
checking stdlib.h presence... yes
checking for stdlib.h... yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking sys/types.h usability... yes
checking sys/types.h presence... yes
checking for sys/types.h... yes
checking string.h usability... yes
checking string.h presence... yes
checking for string.h... yes
checking for inttypes.h... (cached) yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for stddef.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking unistd.h usability... yes
checking unistd.h presence... yes
checking for unistd.h... yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for sys/uio.h... yes
checking for size_t... yes
checking for setitimer... yes
checking for alarm... yes
checking for vsnprintf... yes
checking for vsprintf... yes
checking whether vsnprintf needs a declaration... no
checking for strerror... yes
checking for strncasecmp... yes
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for va_copy... yes
checking for variable argument list macro functionality... yes
checking valgrind.h usability... no
checking valgrind.h presence... no
checking for valgrind.h... no
checking memcheck.h usability... no
checking memcheck.h presence... no
checking for memcheck.h... no
checking valgrind/valgrind.h usability... no
checking valgrind/valgrind.h presence... no
checking for valgrind/valgrind.h... no
checking valgrind/memcheck.h usability... no
checking valgrind/memcheck.h presence... no
checking for valgrind/memcheck.h... no
checking for working alloca.h... yes
checking for alloca... yes
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for mkstemp... yes
checking whether mkstemp needs a declaration... no
checking for fdopen... yes
checking whether fdopen needs a declaration... yes
checking for putenv... yes
checking whether putenv needs a declaration... no
checking for clock_gettime... no
checking for clock_getres... no
checking for gethrtime... no
checking for gettimeofday... yes
sourcing /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/setup_device
RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
sourcing /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/setup_channel
RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
sourcing /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks/setup
RUNNING SETUP FOR THE PROCESS LOCKS MODULE
SPARC V9 inline spin locks supported...no
SPARC V8 inline spin locks supported...no
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for fgrep... /bin/fgrep
checking for pthread_key_create in -lpthread... yes
checking for pthread_yield... yes
checking for pthread_key_create... yes
checking for pthread_cleanup_push... no
checking whether pthread_cleanup_push is available (may be a macro in pthread.h)... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE_NP... yes
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE... no
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK_NP... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK... no
checking for sched_yield... yes
checking for yield... no
checking for usleep... yes
checking for sleep... yes
checking for select... yes
checking for getpid... yes
checking for sched_setaffinity... yes
checking for sched_getaffinity... yes
checking for bindprocessor... no
checking for thread_policy_set... no
checking whether cpu_set_t available... yes
checking whether the CPU_SET and CPU_ZERO macros are defined... no
configure: configuring subsystem in src/openpa
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking whether to enable assertions... yes
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/stat.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking atomic.h usability... no
checking atomic.h presence... no
checking for atomic.h... no
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking for stdint.h... (cached) yes
checking for pthread_create in -lpthread... yes
checking if 100 threads can be run at once... yes
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 bit primitives... yes
checking for support for gcc x86 bit primitives for pre-Pentium 4... yes
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... yes
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
checking whether to enable strict fairness checks... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating src/config.h
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
config.status: executing depfiles commands
configure: configuring subsystem in src/mpid/ch3
RUNNING CONFIGURE FOR CH3 DEVICE
checking whether make sets CFLAGS... yes
16
checking for string.h... (cached) yes
checking for sys/types.h... (cached) yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking uuid/uuid.h usability... no
checking uuid/uuid.h presence... no
checking for uuid/uuid.h... no
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking for unistd.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for net/if.h... yes
checking for pid_t... yes
checking for inet_pton... yes
checking for gethostname... yes
checking whether gethostname needs a declaration... no
checking for CFUUIDCreate... no
checking for uuid_generate... no
checking for time... yes
checking whether CPP accepts variable length argument lists... yes
checking whether we can use struct ifconf... yes
config.status: creating util/Makefile
config.status: creating util/shm/Makefile
config.status: creating util/shmbase/Makefile
config.status: creating channels/Makefile
config.status: creating util/ftb/Makefile
config.status: creating localdefs
config.status: creating include/mpid_thread.h
config.status: creating include/mpidi_ch3_conf.h
config.status: executing default-1 commands
copying /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/../common/thread/mpid_thread_mpe.c to src/mpid_thread.c
=== configuring in channels/nemesis (/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis)
configure: running /bin/bash /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/configure --disable-option-checking '--prefix=/home/bgarrison/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'CC=gcc' 'CFLAGS= -O2' 'LIBS= -lpthread' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' --cache-file=/dev/null --srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis
RUNNING CONFIGURE FOR THE NEMESIS CHANNEL
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking for netinet/in.h... yes
checking for rand... yes
checking for srand... yes
checking for OpenPA atomic primitive availability... yes
checking for mmap... yes
checking for munmap... yes
configure: Using a memory-mapped file for shared memory
checking whether struct hostent contains h_addr_list... yes
checking knem_io.h usability... no
checking knem_io.h presence... no
checking for knem_io.h... no
config.status: creating nemesis/Makefile
config.status: creating nemesis/src/Makefile
config.status: creating nemesis/utils/Makefile
config.status: creating nemesis/utils/replacements/Makefile
config.status: creating nemesis/utils/monitor/Makefile
config.status: creating nemesis/netmod/Makefile
config.status: creating nemesis/netmod/elan/Makefile
config.status: creating nemesis/netmod/gm/Makefile
config.status: creating nemesis/netmod/mx/Makefile
config.status: creating nemesis/netmod/tcp/Makefile
config.status: creating nemesis/netmod/ib/Makefile
config.status: creating nemesis/netmod/psm/Makefile
config.status: creating nemesis/netmod/newmad/Makefile
config.status: creating nemesis/netmod/none/Makefile
config.status: creating nemesis/include/mpid_nem_net_module_defs.h
config.status: creating nemesis/src/mpid_nem_net_array.c
config.status: creating include/mpidi_ch3i_nemesis_conf.h
configure: configuring subsystem in src/mpid/common/locks
configure: WARNING: unrecognized options: --with-atomic-primitives
RUNNING CONFIGURE FOR LOCKS
checking for mutex_init... no
checking for compare_and_swap... no
checking for pthread_mutexattr_init... yes
checking for pthread_mutexattr_setpshared... yes
config.status: creating mpid_locksconf.h
config.status: mpid_locksconf.h is unchanged
configure: configuring subsystem in src/mpi/romio
Configuring with args --prefix=/home/bgarrison/mpich2-install --with-atomic-primitives=auto_allow_emulation
checking for architecture... LINUX
ROMIO home directory is /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio
checking for memalign... yes
checking Fortran external names
configure: WARNING: Unable to test Fortran compiler.  Compiling a test
program failed to produce an object file
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for u_char... yes
checking for u_short... yes
checking for u_int... yes
checking for u_long... yes
checking sys/attr.h usability... no
checking sys/attr.h presence... no
checking for sys/attr.h... no
checking for int large enough for pointers... no
Overriding Array test for MPICH2
checking for weak symbol support... pragma weak
checking that weak symbols are visible to other files... yes
checking that the compiler correctly implements weak symbols... yes
checking whether struct flock compatible with MPI_Offset... yes
checking for pvfs2-config... notfound
checking configured file systems... testfs ufs nfs
configure: WARNING: File locks may not work with NFS.  See the Installation and
users manual for instructions on testing and if necessary fixing this
checking for library containing aio_write... -lrt
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking if aio.h exists and can be compiled... yes
checking if sys/aio.h exists and can be compiled... no
checking whether aio routines can be used... yes
checking for obsolete two-argument aio_write... no
checking for obsolete two-argument aio_suspend... no
checking for aio_fildes member of aiocb structure... yes
checking for aio_whence member of aiocb structure... no
checking for aio_handle member of aiocb structure... no
checking for aio_reqprio member of aiocb structure... yes
checking for aio_sigevent member of aiocb structure... yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking whether struct statfs properly defined... yes
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... no
checking for large file defines... yes
checking whether off64_t is an scalar type... yes
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
checking for lseek64... yes
checking whether lseek64 needs a declaration... no
setting SYSDEP_INC to
setting CC to gcc
setting F77 to :
setting TEST_CC to /home/bgarrison/mpich2-build/bin/mpicc
setting TEST_F77 to /home/bgarrison/mpich2-build/bin/mpif77
setting CFLAGS to  -O2  -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64
setting USER_CFLAGS to
setting USER_FFLAGS to
config.status: creating mpi-io/Makefile
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating adio/common/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating test-internal/Makefile
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating adio/ad_nfs/Makefile
config.status: creating adio/ad_ufs/Makefile
config.status: creating adio/ad_bgl/Makefile
config.status: creating adio/ad_bglockless/Makefile
config.status: creating adio/ad_panfs/Makefile
config.status: creating adio/ad_xfs/Makefile
config.status: creating adio/ad_sfs/Makefile
config.status: creating adio/ad_pfs/Makefile
config.status: creating adio/ad_testfs/Makefile
config.status: creating adio/ad_pvfs/Makefile
config.status: creating adio/ad_pvfs2/Makefile
config.status: creating adio/ad_gridftp/Makefile
config.status: creating adio/ad_lustre/Makefile
config.status: creating adio/ad_zoidfs/Makefile
config.status: creating mpi-io/fortran/Makefile
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating mpi-io/glue/mpich2/Makefile
config.status: creating mpi-io/glue/mpich1/Makefile
config.status: creating mpi-io/glue/default/Makefile
config.status: creating common/dataloop/Makefile
config.status: creating adio/include/romioconf.h
configure: configuring subsystem in src/pmi/simple
RUNNING CONFIGURE FOR THE SIMPLE PMI
checking for stdlib.h... (cached) yes
checking for strings.h... (cached) yes
checking for sys/socket.h... (cached) yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking for socket... yes
checking for setsockopt... yes
checking for gethostbyname... yes
checking whether socklen_t is defined (in sys/socket.h if present)... yes
config.status: creating pmiconf.h
configure: configuring subsystem in src/pm/mpd
checking whether ln -s works... yes
checking whether install /usr/bin/install -c works... yes
Using INSTALL=/usr/bin/install -c
checking for totalview... no
checking for python2.6... no
checking for python2.5... python2.5
checking for python2.4... no
checking for python2.3... no
checking for python2.2... no
checking for python2... no
checking for python... python
checking that python2.5 is a valid python version... yes
checking that the cPickle module is available for python2.5... yes
checking for sys/wait.h that is POSIX.1 compatible... yes
config.status: creating mpdconf.h
configure: configuring subsystem in src/pm/hydra
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking the maximum length of command line arguments... 98304
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for strip... strip
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for doxygen... no
checking for socket in -lsocket... no
checking for gethostbyname in -lnsl... yes
checking for sigaction... yes
checking for signal... yes
checking for alloca... no
checking for unsetenv... yes
checking for strsignal... yes
checking for putenv... (cached) yes
checking for environ in unistd.h... no
checking for manually declared extern environ... yes
checking boot-strap server... ssh,rsh,fork,slurm
checking communication subsystem... none
checking resource management kernel... dummy,pbs
checking process manager... pmiserv
checking user interface... mpiexec
checking debugging support... no
checking warnings... no
checking process binding library... plpa
checking if plpa works correctly... yes
checking checkpointing library... none
checking whether the compiler allows __VA_ARGS__... yes
checking for strsignal... (cached) yes
checking whether strsignal needs a declaration... yes
checking for sigaction... (cached) yes
checking for signal... (cached) yes
checking for sigset... yes
checking for struct sigaction and sa_handler... yes
config.status: creating tools/bootstrap/src/bsci_init.c
config.status: creating tools/bootstrap/include/bsci.h
config.status: creating rmk/src/rmki_init.c
config.status: creating rmk/include/rmki.h
config.status: creating css/src/cssi_init.c
config.status: creating css/include/cssi.h
config.status: creating hydra-doxygen.cfg
config.status: creating include/hydra_config.h
config.status: executing libtool commands
=== configuring in ../../mpl (/home/bgarrison/mpich2-build/src/pm/hydra/../../mpl)
configure: running /bin/bash /home/bgarrison/libraries/mpich2-1.2.1/src/pm/hydra/../../mpl/configure --disable-option-checking '--prefix=/home/bgarrison/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' --cache-file=/dev/null --srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/pm/hydra/../../mpl
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
config.status: creating include/config.h
config.status: executing include/mplconfig.h commands
config.status: creating include/mplconfig.h - prefix MPL for include/config.h defines
configure: configuring subsystem in src/pm/gforker
RUNNING CONFIGURE FOR THE GFORKER PM
checking for setsid... yes
checking for isatty... yes
checking for getsid... yes
checking for library containing socketpair... none required
checking sys/ptrace.h usability... yes
checking sys/ptrace.h presence... yes
checking for sys/ptrace.h... yes
checking for struct sigaction... yes
checking wait.h usability... yes
checking wait.h presence... yes
checking for wait.h... yes
config.status: creating forkerconf.h
=== configuring in ../util (/home/bgarrison/mpich2-build/src/pm/gforker/../util)
configure: running /bin/bash /home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util/configure --disable-option-checking '--prefix=/home/bgarrison/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' --cache-file=/dev/null --srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util
RUNNING CONFIGURE FOR THE PM UTILITIES
checking for strtol... yes
checking whether getsid is prototyped in unistd.h... no
checking for cygwin1.dll in /bin... yes
checking for extern environ in runtime... yes
checking for ANSI C header files... (cached) yes
checking whether struct iovec is defined in sys/uio.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking whether FD_ZERO works... yes
config.status: creating pmutilconf.h
configure: configuring subsystem in src/mpe2
Configuring MPE Profiling System with  '--prefix=/home/bgarrison/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS='
checking gnumake... yes using --no-print-directory
checking BSD 4.4 make... no - whew
checking OSF V3 make... no
This MPE build is part of the MPICH2 build
checking for leftover Makefiles in subpackages ... none
checking whether MPI_CC has been set ... /home/bgarrison/mpich2-build/bin/mpicc
checking whether MPI_F77 has been set ... /home/bgarrison/mpich2-build/bin/mpif77
config.status: creating sbin/mpetestlink
config.status: creating sbin/mpetestexec
config.status: creating sbin/mpetestexeclog
config.status: creating sbin/mpeinstall
config.status: creating sbin/mpecheckinstall
config.status: WARNING:  '/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/sbin/mpecheckinstall.in' seems to ignore the --datarootdir setting
config.status: creating sbin/mpecheckbuild
config.status: creating etc/mpe_help.conf
config.status: creating etc/mpe_f77env.conf
config.status: creating mpe_conf.h
=== configuring in src/misc (/home/bgarrison/mpich2-build/src/mpe2/src/misc)
configure: running /bin/bash /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/configure --disable-option-checking '--prefix=/home/bgarrison/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' --cache-file=/dev/null --srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc
Configuring MPE Miscellaneous Library with  '--disable-option-checking' '--prefix=/home/bgarrison/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc'
checking whether gcc and cc understand -c and -o together... yes
checking for dbx... no
checking for gdb... /usr/bin/gdb
checking for sysinfo... yes
checking for uname... yes
checking sys/systeminfo.h usability... no
checking sys/systeminfo.h presence... no
checking for sys/systeminfo.h... no
checking for sighandler_t... no
checking for kill... yes
checking whether kill needs a declaration... no
config.status: creating src/dbxerr.c
config.status: creating mpe_misc_conf.h
=== configuring in src/callstack (/home/bgarrison/mpich2-build/src/mpe2/src/callstack)
configure: running /bin/bash /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/configure --disable-option-checking '--prefix=/home/bgarrison/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' --cache-file=/dev/null --srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack
Configuring MPE CallStack Library with  '--disable-option-checking' '--prefix=/home/bgarrison/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack'
checking execinfo.h usability... yes
checking execinfo.h presence... yes
checking for execinfo.h... yes
checking whether <execinfo.h> defines backtrace_symbols_fd() ... yes
checking if <execinfo.h> links with -Wl,--export-dynamic ... yes
checking whether fdopen needs a declaration... no
config.status: creating include/mpe_callstack.h
config.status: creating etc/mpe_callstack_ldflags.conf
config.status: creating mpe_callstack_conf.h
=== configuring in src/logging (/home/bgarrison/mpich2-build/src/mpe2/src/logging)
configure: running /bin/bash /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/configure --disable-option-checking '--prefix=/home/bgarrison/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' --cache-file=/dev/null --srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging
Configuring MPE Logging Library and Tools with  '--disable-option-checking' '--prefix=/home/bgarrison/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging'
checking for header that defines C99 integer types, intXX_t ... <stdint.h>
checking whether <inttypes.h> defines the PRIdXX macros ... yes
checking if <stdint.h> can be behind system headers ... yes
checking for address-sized integer ... CLOG_int64_t
checking for srand48... yes
checking whether srand48 needs a declaration... no
checking for lrand48... yes
checking whether lrand48 needs a declaration... no
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking for O_LARGEFILE for open() ... needs _LARGEFILE64_SOURCE
checking for O_BINARY for open() ... no
checking for pthread_mutex_lock in -lpthread... yes
config.status: creating include/clog_inttypes.h
config.status: creating include/mpi_null.h
config.status: creating include/mpe_log_thread.h
config.status: creating etc/mpe_log.conf
config.status: creating etc/mpe_nolog.conf
config.status: creating etc/mpe_log_postlib.conf
config.status: creating mpe_logging_conf.h
=== configuring in src/wrappers (/home/bgarrison/mpich2-build/src/mpe2/src/wrappers)
configure: running /bin/bash /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers/configure --disable-option-checking '--prefix=/home/bgarrison/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' --cache-file=/dev/null --srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers
Configuring MPE Wrapper Libraries For MPI with  '--disable-option-checking' '--prefix=/home/bgarrison/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers'
checking for stdarg is correct... yes
checking if compiler accepts prototypes ... yes
checking for safe PMPI invocations ... no
config.status: creating etc/mpe_mpilog.conf
config.status: creating etc/mpe_mpitrace.conf
config.status: creating mpe_wrappers_conf.h
=== configuring in src/graphics (/home/bgarrison/mpich2-build/src/mpe2/src/graphics)
configure: running /bin/bash /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/configure --disable-option-checking '--prefix=/home/bgarrison/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' --cache-file=/dev/null --srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics
Configuring MPE X Graphics Library with  '--disable-option-checking' '--prefix=/home/bgarrison/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics'
checking for X... libraries , headers
checking for long pointer... yes
checking for system... yes
config.status: creating contrib/life/Makefile
config.status: creating contrib/mandel/Makefile
config.status: creating contrib/mastermind/Makefile
config.status: creating contrib/test/Makefile
config.status: creating etc/mpe_mpianim.conf
config.status: creating etc/mpe_graphics.conf
config.status: creating mpe_graphics_conf.h
=== configuring in src/collchk (/home/bgarrison/mpich2-build/src/mpe2/src/collchk)
configure: running /bin/bash /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/configure --disable-option-checking '--prefix=/home/bgarrison/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' --cache-file=/dev/null --srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk
Configuring MPE Collective and Datatype Checking Library with  '--disable-option-checking' '--prefix=/home/bgarrison/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk'
config.status: creating etc/mpe_mpicheck.conf
config.status: creating mpe_collchk_conf.h
=== configuring in src/slog2sdk (/home/bgarrison/mpich2-build/src/mpe2/src/slog2sdk)
configure: running /bin/bash /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/slog2sdk/configure --disable-option-checking '--prefix=/home/bgarrison/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' --cache-file=/dev/null --srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/slog2sdk
Configuring SLOG2SDK with  '--disable-option-checking' '--prefix=/home/bgarrison/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/slog2sdk'
checking if CLASSPATH is set... no, good to go
checking for java in user's PATH... found /usr/bin/java
checking if /usr/bin/java runs simple java class... yes
checking if /usr/bin/java runs simple jar file... yes
checking if /usr/bin/java runs non-GUI tool... yes
checking if /usr/bin/java runs simple Swing class... yes
checking if /usr/bin/java runs simple Swing jar file... yes
checking for Java version... java full version "gcj-1.5.0", i.e. Java 2 SDK
checking for cygpath... no
creating /home/bgarrison/mpich2-build/src/mpe2/src/slog2sdk/lib from source
creating directory /home/bgarrison/mpich2-build/src/mpe2/src/slog2sdk/bin
creating /home/bgarrison/mpich2-build/src/mpe2/src/slog2sdk/doc from source
creating /home/bgarrison/mpich2-build/src/mpe2/src/slog2sdk/share
creating /home/bgarrison/mpich2-build/src/mpe2/src/slog2sdk/share/logfiles
creating sample logfiles from source
config.status: creating sbin/install-package
config.status: creating bin/slog2print
config.status: creating bin/slog2navigator
config.status: creating bin/slog2filter
config.status: creating bin/slog2updater
config.status: creating bin/logconvertor
config.status: creating bin/jumpshot
config.status: creating bin/clogprint
config.status: creating bin/clogTOslog2
config.status: creating bin/clog2print
config.status: creating bin/clog2TOslog2
=== configuring in trace_rlog (/home/bgarrison/mpich2-build/src/mpe2/src/slog2sdk/trace_rlog)
configure: running /bin/bash /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/slog2sdk/trace_rlog/configure --disable-option-checking '--prefix=/home/bgarrison/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' --cache-file=/dev/null --srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/slog2sdk/trace_rlog
Configuring TRACE_RLOG implementation with  '--disable-option-checking' '--prefix=/home/bgarrison/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/home/bgarrison/mpich2-build/bin/mpicc' 'MPI_F77=/home/bgarrison/mpich2-build/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/slog2sdk/trace_rlog'
checking size of __int64... 0
checking for sed... sed
checking for a sed that does not truncate output... sed
checking whether to build static libraries... no
checking for malloc in -lefence... no
checking for strstr... yes
checking target system type... x86_64-unknown-linux-gnu
checking for javah in user's PATH... not found
configure: WARNING:  Invalid JNI include dir, exit!
configure: WARNING: SLOG2SDK: No sub-package has been configured
MPE2:  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/graphics" "src/collchk" "src/slog2sdk" have been configured
checking size of OPA_ptr_t... 8
configure: WARNING: Could not define Fortran MPI datatypes for C
checking the sizeof MPI_Offset... 8
config.status: creating src/include/Makefile
config.status: creating src/include/mpich2info.h
config.status: creating mpich2-doxygen
config.status: creating src/include/mpichtimer.h
config.status: creating src/binding/Makefile
config.status: creating src/binding/cxx/Makefile
config.status: creating src/binding/cxx/mpicxx.h
config.status: creating src/binding/f77/Makefile
config.status: creating src/binding/f77/mpif.h
config.status: creating src/binding/f77/setbotf.f
config.status: creating src/binding/f90/Makefile
config.status: creating src/binding/f90/mpi_sizeofs.f90
config.status: creating src/packaging/Makefile
config.status: creating src/packaging/pkgconfig/mpich2-ch3.pc
config.status: creating src/packaging/pkgconfig/Makefile
config.status: creating src/packaging/envmods/mpich2.module
config.status: WARNING:  '/home/bgarrison/libraries/mpich2-1.2.1/src/packaging/envmods/mpich2.module.in' seems to ignore the --datarootdir setting
config.status: creating src/packaging/envmods/Makefile
config.status: creating src/env/mpixxx_opts.conf
config.status: creating src/env/mpicc
config.status: creating src/env/mpicc.conf
config.status: creating src/env/mpicc.bash
config.status: creating src/env/mpicxx
config.status: creating src/env/mpicxx.conf
config.status: creating src/env/mpicxx.bash
config.status: creating src/env/mpif77
config.status: creating src/env/mpif77.conf
config.status: creating src/env/mpif77.bash
config.status: creating src/env/mpif90
config.status: creating src/env/mpif90.conf
config.status: creating src/env/mpif90.bash
config.status: creating src/env/parkill
config.status: creating src/env/Makefile
config.status: creating src/util/createshlib
config.status: creating src/mpi/Makefile
config.status: creating src/mpi/attr/Makefile
config.status: creating src/mpi/coll/Makefile
config.status: creating src/mpi/comm/Makefile
config.status: creating src/mpi/datatype/Makefile
config.status: creating src/mpi/debugger/Makefile
config.status: creating src/mpi/errhan/Makefile
config.status: creating src/mpi/group/Makefile
config.status: creating src/mpi/init/Makefile
config.status: creating src/mpi/misc/Makefile
config.status: creating src/mpi/pt2pt/Makefile
config.status: creating src/mpi/rma/Makefile
config.status: creating src/mpi/spawn/Makefile
config.status: creating src/mpi/timer/Makefile
config.status: creating src/mpi/topo/Makefile
config.status: creating src/mpid/Makefile
config.status: creating src/mpid/common/Makefile
config.status: creating src/mpid/common/datatype/Makefile
config.status: creating src/mpid/common/datatype/dataloop/Makefile
config.status: creating src/pm/Makefile
config.status: creating src/pmi/Makefile
config.status: creating src/pmi/simple/Makefile
config.status: creating src/nameserv/Makefile
config.status: creating src/nameserv/file/Makefile
config.status: creating src/nameserv/mpd/Makefile
config.status: creating src/nameserv/pmi/Makefile
config.status: creating src/nameserv/test/Makefile
config.status: creating src/util/Makefile
config.status: creating src/util/info/Makefile
config.status: creating src/util/instrm/Makefile
config.status: creating src/util/thread/Makefile
config.status: creating src/util/mem/Makefile
config.status: creating src/util/msgs/Makefile
config.status: creating src/util/param/Makefile
config.status: creating src/util/dbg/Makefile
config.status: creating src/util/dbg/getfuncstack
config.status: creating src/util/osserv/Makefile
config.status: creating src/util/procmap/Makefile
config.status: creating src/util/other/Makefile
config.status: creating src/include/mpi.h
config.status: creating test/util/Makefile
config.status: creating test/basic/Makefile
config.status: creating test/commands/Makefile
config.status: creating test/commands/cmdtests
config.status: creating test/mpid/Makefile
config.status: creating test/mpid/ch3/Makefile
config.status: creating test/util/timer/Makefile
config.status: creating examples/Makefile
config.status: creating examples/f77/Makefile
config.status: creating examples/f90/Makefile
config.status: creating examples/cxx/Makefile
config.status: creating src/util/logging/Makefile
config.status: creating src/util/logging/common/Makefile
config.status: creating doc/Makefile
config.status: creating doc/mansrc/Makefile
config.status: creating doc/mansrc/createhtmlindex
config.status: creating doc/refman/Makefile
config.status: creating doc/installguide/Makefile
config.status: creating doc/userguide/Makefile
config.status: creating doc/logging/Makefile
config.status: creating doc/design/Makefile
config.status: creating doc/smpd/Makefile
config.status: creating doc/windev/Makefile
config.status: creating src/include/mpichconf.h
config.status: executing default-2 commands
config.status: executing default-3 commands
config.status: executing default-4 commands
config.status: executing default-5 commands
config.status: executing default-6 commands
config.status: executing default-7 commands
config.status: executing default-8 commands
Updating dependency directories .deps
config.status: executing default-9 commands
config.status: executing default-10 commands
config.status: executing default-11 commands
config.status: executing default-12 commands
config.status: executing default-13 commands
=== configuring in test/mpi (/home/bgarrison/mpich2-build/test/mpi)
configure: running /bin/bash /home/bgarrison/libraries/mpich2-1.2.1/test/mpi/configure --disable-option-checking '--prefix=/home/bgarrison/mpich2-install'  --cache-file=/dev/null --srcdir=/home/bgarrison/libraries/mpich2-1.2.1/test/mpi
RUNNING CONFIGURE FOR MPI TESTS
checking for memory.h... (cached) yes
checking for pthread_create... no
checking for pthread_yield... no
checking for pthread_barrier_init... no
checking for pthread_barrier_wait... no
Configuring tests for MPICH2
checking whether struct hostent contains h_addr_list... no
configure: WARNING: Selecting integer*8 as the Fortran type for MPI_Offset
configure: WARNING: Selecting integer as the Fortran type for MPI_Aint
checking whether MPI_2DOUBLE_COMPLEX is available... no
checking for C integer type of address size... long
config.status: creating maint/testmerge
config.status: creating runtests
config.status: creating basic/Makefile
config.status: creating attr/Makefile
config.status: creating coll/Makefile
config.status: creating comm/Makefile
config.status: creating datatype/Makefile
config.status: creating errhan/Makefile
config.status: creating group/Makefile
config.status: creating info/Makefile
config.status: creating init/Makefile
config.status: creating pt2pt/Makefile
config.status: creating rma/Makefile
config.status: creating spawn/Makefile
config.status: creating topo/Makefile
config.status: creating io/Makefile
config.status: creating f77/Makefile
config.status: creating f77/attr/Makefile
config.status: creating f77/attr/attraints.h
config.status: creating f77/pt2pt/attr1aints.h
config.status: creating f77/ext/add1size.h
config.status: creating f77/datatype/Makefile
config.status: creating f77/datatype/typeaints.h
config.status: creating f77/util/Makefile
config.status: creating f77/coll/Makefile
config.status: creating f77/comm/Makefile
config.status: creating f77/topo/Makefile
config.status: creating f77/init/Makefile
config.status: creating f77/rma/addsize.h
config.status: creating f77/pt2pt/Makefile
config.status: creating f77/info/Makefile
config.status: creating f77/spawn/Makefile
config.status: creating f77/spawn/type1aint.h
config.status: creating f77/rma/Makefile
config.status: creating f77/ext/Makefile
config.status: creating f77/ext/testlist
config.status: creating f77/io/Makefile
config.status: creating f77/io/iooffset.h
config.status: creating f77/io/iodisp.h
config.status: creating f77/io/ioaint.h
config.status: creating f90/Makefile
config.status: creating f90/attr/Makefile
config.status: creating f90/datatype/Makefile
config.status: creating f90/f90types/Makefile
config.status: creating f90/util/Makefile
config.status: creating f90/coll/Makefile
config.status: creating f90/comm/Makefile
config.status: creating f90/topo/Makefile
config.status: creating f90/init/Makefile
config.status: creating f90/pt2pt/Makefile
config.status: creating f90/rma/Makefile
config.status: creating f90/info/Makefile
config.status: creating f90/spawn/Makefile
config.status: creating f90/timer/Makefile
config.status: creating f90/ext/Makefile
config.status: creating f90/ext/testlist
config.status: creating f90/io/Makefile
config.status: creating f90/misc/Makefile
config.status: creating cxx/Makefile
config.status: creating cxx/util/Makefile
config.status: creating cxx/attr/Makefile
config.status: creating cxx/pt2pt/Makefile
config.status: creating cxx/comm/Makefile
config.status: creating cxx/coll/Makefile
config.status: creating cxx/info/Makefile
config.status: creating cxx/datatype/Makefile
config.status: creating cxx/io/Makefile
config.status: creating cxx/init/Makefile
config.status: creating cxx/rma/Makefile
config.status: creating cxx/spawn/Makefile
config.status: creating threads/Makefile
config.status: creating threads/pt2pt/Makefile
config.status: creating threads/util/Makefile
config.status: creating threads/comm/Makefile
config.status: creating threads/init/Makefile
config.status: creating threads/spawn/Makefile
config.status: creating errors/Makefile
config.status: creating errors/attr/Makefile
config.status: creating errors/basic/Makefile
config.status: creating errors/coll/Makefile
config.status: creating errors/comm/Makefile
config.status: creating errors/faults/Makefile
config.status: creating errors/group/Makefile
config.status: creating errors/pt2pt/Makefile
config.status: creating errors/rma/Makefile
config.status: creating errors/spawn/Makefile
config.status: creating errors/topo/Makefile
config.status: creating errors/io/Makefile
config.status: creating errors/cxx/Makefile
config.status: creating errors/cxx/errhan/Makefile
config.status: creating errors/cxx/io/Makefile
config.status: creating errors/f77/Makefile
config.status: creating errors/f90/Makefile
config.status: creating manual/Makefile
config.status: creating manual/manyconnect
config.status: creating perf/Makefile
config.status: creating testlist
config.status: creating cxx/testlist
config.status: creating f77/testlist
config.status: creating f90/testlist
config.status: creating threads/testlist
config.status: creating errors/testlist
config.status: creating errors/cxx/testlist
config.status: creating include/mpitestconf.h
Configuration completed.
Beginning make
Using variables CC='gcc' CFLAGS=' -O2' LDFLAGS='' AR='ar' FC='' F90='' FFLAGS='' F90FLAGS='' CXX='c++' CPPFLAGS=' -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS  -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers'
make all-local
make[1]: Entering directory `/home/bgarrison/mpich2-build'
make[1]: Leaving directory `/home/bgarrison/mpich2-build'
make[1]: Entering directory `/home/bgarrison/mpich2-build/src/openpa'
Making all in src
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/openpa/src'
make  all-am
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/openpa/src'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src   -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS  -O2 -MT opa_primitives.o -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.o /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/opa_primitives.c
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Po
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src   -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS  -O2 -MT opa_queue.o -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.o /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/opa_queue.c
mv -f .deps/opa_queue.Tpo .deps/opa_queue.Po
rm -f libopa.a
ar cru libopa.a opa_primitives.o opa_queue.o
ranlib libopa.a
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/openpa/src'
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/openpa/src'
Making all in test
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/openpa/test'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/openpa/test'
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/openpa'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/openpa'
make[1]: Leaving directory `/home/bgarrison/mpich2-build/src/openpa'
make[1]: Entering directory `/home/bgarrison/mpich2-build/src'
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/mpid'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/common'
make[4]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/common/locks'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks/mpidu_process_locks.c
ar cr ../../../../lib/libmpich.a mpidu_process_locks.o
ranlib ../../../../lib/libmpich.a
date > .libstamp0
make[4]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/common/locks'
make[4]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/common/datatype'
make[5]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/common/datatype/dataloop'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/.. -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/dataloop.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/.. -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/segment.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/.. -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/segment_ops.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/.. -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/dataloop_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/.. -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/dataloop_create_contig.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/.. -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/dataloop_create_vector.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/.. -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/dataloop_create_blockindexed.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/.. -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/dataloop_create_indexed.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/.. -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/dataloop_create_struct.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/.. -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/dataloop_create_pairtype.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/.. -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/subarray_support.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/.. -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/dataloop/darray_support.c
ar cr ../../../../../lib/libmpich.a dataloop.o segment.o segment_ops.o dataloop_create.o dataloop_create_contig.o dataloop_create_vector.o dataloop_create_blockindexed.o dataloop_create_indexed.o dataloop_create_struct.o dataloop_create_pairtype.o subarray_support.o darray_support.o
ranlib ../../../../../lib/libmpich.a
date > .libstamp0
make[5]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/common/datatype/dataloop'
make all-local
make[5]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/common/datatype'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_type_debug.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_segment.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_ext32_segment.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_ext32_datatype.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_type_dup.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpir_type_get_contig_blocks.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpir_type_flatten.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_type_commit.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_type_zerolen.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_type_vector.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_type_contiguous.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_type_create_resized.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_type_blockindexed.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_type_indexed.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_type_struct.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_type_get_envelope.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_datatype_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_datatype_contents.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_type_get_contents.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_type_create_pairtype.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype/mpid_contents_support.c
ar cr ../../../../lib/libmpich.a mpid_type_debug.o mpid_segment.o mpid_ext32_segment.o mpid_ext32_datatype.o mpid_type_dup.o mpir_type_get_contig_blocks.o mpir_type_flatten.o mpid_type_commit.o mpid_type_zerolen.o mpid_type_vector.o mpid_type_contiguous.o mpid_type_create_resized.o mpid_type_blockindexed.o mpid_type_indexed.o mpid_type_struct.o mpid_type_get_envelope.o mpid_datatype_free.o mpid_datatype_contents.o mpid_type_get_contents.o mpid_type_create_pairtype.o mpid_contents_support.o
date > .libstamp0
make[5]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/common/datatype'
make[4]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/common/datatype'
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/common'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/ch3'
make[4]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels'
make[5]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis'
make[6]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis'
make[7]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/src'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_alloc.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_init.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_queue.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_barrier.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_mpich2.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_ckpt.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_finalize.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_network_poll.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_network.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_debug.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_shm.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c mpid_nem_net_array.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_dma.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -I/home/bgarrison/mpich2-build/src/util/wrappers -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_vmsplice.c
ar cr ../../../../../../../lib/libmpich.a mpid_nem_alloc.o mpid_nem_init.o mpid_nem_queue.o mpid_nem_barrier.o mpid_nem_mpich2.o mpid_nem_ckpt.o mpid_nem_finalize.o mpid_nem_network_poll.o mpid_nem_network.o mpid_nem_debug.o mpid_nem_lmt.o mpid_nem_lmt_shm.o mpid_nem_net_array.o mpid_nem_lmt_dma.o mpid_nem_lmt_vmsplice.o
ranlib ../../../../../../../lib/libmpich.a
date > .libstamp0
make[7]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/src'
make[7]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/netmod'
make[8]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_finalize.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_init.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_send.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_utility.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/socksm.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_getip.c
ar cr ../../../../../../../../lib/libmpich.a tcp_finalize.o tcp_init.o tcp_send.o tcp_utility.o socksm.o tcp_getip.o
ranlib ../../../../../../../../lib/libmpich.a
date > .libstamp0
make[8]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
make[7]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/netmod'
make[7]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[8]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I. -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor/papi_defs.c
ar cr ../../../../../../../../lib/libmpich.a papi_defs.o
date > .libstamp0
make[8]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
make[8]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements -I. -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/mpich2-build/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements/mkstemp.c
ar cr ../../../../../../../../lib/libmpich.a mkstemp.o
date > .libstamp0
make[8]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
make[7]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[6]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis'
make[6]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/src'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src/ch3_finalize.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src/ch3_init.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src/ch3_isend.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src/ch3_isendv.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src/ch3_istartmsg.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src/ch3_istartmsgv.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src/ch3_progress.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src/ch3_comm_spawn.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src/ch3_abort.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src/ch3i_comm.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/src/ch3i_eagernoncontig.c
ar cr ../../../../../../lib/libmpich.a ch3_finalize.o ch3_init.o ch3_isend.o ch3_isendv.o ch3_istartmsg.o ch3_istartmsgv.o ch3_progress.o ch3_comm_spawn.o ch3_abort.o ch3i_comm.o ch3i_eagernoncontig.o
ranlib ../../../../../../lib/libmpich.a
date > .libstamp0
make[6]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/src'
make[5]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis'
make[4]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/ch3/channels'
make[4]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/ch3/src'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/ch3u_buffer.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/ch3u_comm_spawn_multiple.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/ch3u_handle_connection.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/ch3u_handle_recv_pkt.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/ch3u_handle_recv_req.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/ch3u_handle_send_req.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/ch3u_port.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/ch3u_recvq.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/ch3u_request.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/ch3u_rma_ops.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/ch3u_rma_sync.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/ch3u_rndv.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/ch3u_eager.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/ch3u_eagersync.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_abort.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_cancel_recv.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_cancel_send.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_comm_disconnect.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_comm_spawn_multiple.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_finalize.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_get_universe_size.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_getpname.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_init.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_iprobe.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_irecv.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_irsend.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_isend.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_issend.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_port.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_probe.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_recv.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_rsend.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_send.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_ssend.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_startall.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_vc.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpid_rma.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpidi_isend_self.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpidi_pg.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/src/mpidi_printf.c
ar cr ../../../../lib/libmpich.a ch3u_buffer.o ch3u_comm_spawn_multiple.o ch3u_handle_connection.o ch3u_handle_recv_pkt.o ch3u_handle_recv_req.o ch3u_handle_send_req.o ch3u_port.o ch3u_recvq.o ch3u_request.o ch3u_rma_ops.o ch3u_rma_sync.o ch3u_rndv.o ch3u_eager.o ch3u_eagersync.o mpid_abort.o mpid_cancel_recv.o mpid_cancel_send.o mpid_comm_disconnect.o mpid_comm_spawn_multiple.o mpid_finalize.o mpid_get_universe_size.o mpid_getpname.o mpid_init.o mpid_iprobe.o mpid_irecv.o mpid_irsend.o mpid_isend.o mpid_issend.o mpid_port.o mpid_probe.o mpid_recv.o mpid_rsend.o mpid_send.o mpid_ssend.o mpid_startall.o mpid_vc.o mpid_rma.o mpidi_isend_self.o mpidi_pg.o mpidi_printf.o
ranlib ../../../../lib/libmpich.a
date > .libstamp0
make[4]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/ch3/src'
make[4]: Entering directory `/home/bgarrison/mpich2-build/src/mpid/ch3/util'
make[4]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/ch3/util'
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid/ch3'
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/mpid'
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/mpi'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/attr'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/attr_delete.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/attr_get.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/attr_put.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/comm_create_keyval.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/comm_delete_attr.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/comm_free_keyval.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/comm_get_attr.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/comm_set_attr.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/keyval_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/keyval_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/type_create_keyval.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/type_delete_attr.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/type_free_keyval.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/type_get_attr.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/type_set_attr.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/win_create_keyval.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/win_delete_attr.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/win_free_keyval.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/win_get_attr.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/win_set_attr.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/attrutil.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/attr/dup_fn.c
ar cr ../../../lib/libmpich.a attr_delete.o attr_get.o attr_put.o comm_create_keyval.o comm_delete_attr.o comm_free_keyval.o comm_get_attr.o comm_set_attr.o keyval_create.o keyval_free.o type_create_keyval.o type_delete_attr.o type_free_keyval.o type_get_attr.o type_set_attr.o win_create_keyval.o win_delete_attr.o win_free_keyval.o win_get_attr.o win_set_attr.o attrutil.o dup_fn.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/attr'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/coll'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/allreduce.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/barrier.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/op_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/op_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/bcast.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/alltoall.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/alltoallv.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/reduce.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/scatter.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/gather.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/scatterv.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/gatherv.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/scan.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/exscan.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/allgather.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/allgatherv.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/red_scat.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/alltoallw.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/reduce_local.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/op_commutative.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/red_scat_block.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/helper_fns.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/opsum.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/opmax.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/opmin.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/opband.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/opbor.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/opbxor.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/opland.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/oplor.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/oplxor.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/opprod.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/opminloc.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/coll/opmaxloc.c
ar cr ../../../lib/libmpich.a allreduce.o barrier.o op_create.o op_free.o bcast.o alltoall.o alltoallv.o reduce.o scatter.o gather.o scatterv.o gatherv.o scan.o exscan.o allgather.o allgatherv.o red_scat.o alltoallw.o reduce_local.o op_commutative.o red_scat_block.o helper_fns.o opsum.o opmax.o opmin.o opband.o opbor.o opbxor.o opland.o oplor.o oplxor.o opprod.o opminloc.o opmaxloc.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/coll'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/comm'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/comm_compare.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/comm_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/comm_dup.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/comm_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/comm_get_name.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/comm_group.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/comm_rank.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/comm_size.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/comm_remote_group.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/comm_remote_size.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/comm_set_name.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/comm_split.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/comm_test_inter.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/intercomm_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/intercomm_merge.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/comm/commutil.c
ar cr ../../../lib/libmpich.a comm_compare.o comm_create.o comm_dup.o comm_free.o comm_get_name.o comm_group.o comm_rank.o comm_size.o comm_remote_group.o comm_remote_size.o comm_set_name.o comm_split.o comm_test_inter.o intercomm_create.o intercomm_merge.o commutil.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/comm'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/datatype'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/address.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/get_address.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/get_count.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/get_elements.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/pack.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/unpack.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/pack_size.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/status_set_elements.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_get_name.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_set_name.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_size.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_extent.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_vector.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_commit.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_indexed.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_hindexed.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_struct.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_contiguous.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_hvector.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_dup.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_get_envelope.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_get_contents.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_ub.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_lb.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_get_extent.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_get_true_extent.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_match_size.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_create_struct.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_create_hindexed.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_create_hvector.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/pack_external.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/pack_external_size.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/unpack_external.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_create_indexed_block.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_create_resized.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_create_darray.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/type_create_subarray.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype/typeutil.c
ar cr ../../../lib/libmpich.a address.o get_address.o get_count.o get_elements.o pack.o unpack.o pack_size.o status_set_elements.o type_get_name.o type_set_name.o type_size.o type_extent.o type_vector.o type_commit.o type_indexed.o type_hindexed.o type_struct.o type_contiguous.o type_free.o type_hvector.o type_dup.o type_get_envelope.o type_get_contents.o type_ub.o type_lb.o type_get_extent.o type_get_true_extent.o type_match_size.o type_create_struct.o type_create_hindexed.o type_create_hvector.o pack_external.o pack_external_size.o unpack_external.o type_create_indexed_block.o type_create_resized.o type_create_darray.o type_create_subarray.o typeutil.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/datatype'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/errhan'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/add_error_code.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/add_error_class.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/add_error_string.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/comm_call_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/comm_create_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/comm_get_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/comm_set_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/errhandler_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/errhandler_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/errhandler_get.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/errhandler_set.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/error_class.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/error_string.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/file_create_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/file_get_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/file_set_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/file_call_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/win_create_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/win_call_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/win_get_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/win_set_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/errutil.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/errhan/dynerrutil.c
ar cr ../../../lib/libmpich.a add_error_code.o add_error_class.o add_error_string.o comm_call_errhandler.o comm_create_errhandler.o comm_get_errhandler.o comm_set_errhandler.o errhandler_create.o errhandler_free.o errhandler_get.o errhandler_set.o error_class.o error_string.o file_create_errhandler.o file_get_errhandler.o file_set_errhandler.o file_call_errhandler.o win_create_errhandler.o win_call_errhandler.o win_get_errhandler.o win_set_errhandler.o errutil.o dynerrutil.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/errhan'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/group'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group/group_compare.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group/group_difference.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group/group_excl.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group/group_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group/group_incl.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group/group_intersection.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group/group_range_excl.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group/group_range_incl.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group/group_rank.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group/group_size.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group/group_translate_ranks.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group/group_union.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/group/grouputil.c
ar cr ../../../lib/libmpich.a group_compare.o group_difference.o group_excl.o group_free.o group_incl.o group_intersection.o group_range_excl.o group_range_incl.o group_rank.o group_size.o group_translate_ranks.o group_union.o grouputil.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/group'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/init'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init/abort.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init/init.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init/initialized.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init/initthread.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init/ismain.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init/finalize.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init/finalized.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init/querythread.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init/async.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/init/initinfo.c
ar cr ../../../lib/libmpich.a abort.o init.o initialized.o initthread.o ismain.o finalize.o finalized.o querythread.o async.o initinfo.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/init'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/misc'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/misc -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/misc/getpname.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/misc -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/misc/pcontrol.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/misc -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/misc/version.c
ar cr ../../../lib/libmpich.a getpname.o pcontrol.o version.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/misc'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/pt2pt'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/bsend.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/bsend_init.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/bufattach.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/buffree.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/cancel.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/greq_start.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/greq_complete.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/ibsend.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/iprobe.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/irecv.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/irsend.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/isend.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/issend.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/probe.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/recv.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/recv_init.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/request_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/request_get_status.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/rsend.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/rsend_init.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/send.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/send_init.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/sendrecv.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/sendrecv_rep.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/status_set_cancelled.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/ssend.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/ssend_init.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/start.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/startall.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/test.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/test_cancelled.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/testall.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/testany.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/testsome.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/wait.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/waitall.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/waitany.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/waitsome.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/bsendutil.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/pt2pt/mpir_request.c
ar cr ../../../lib/libmpich.a bsend.o bsend_init.o bufattach.o buffree.o cancel.o greq_start.o greq_complete.o ibsend.o iprobe.o irecv.o irsend.o isend.o issend.o probe.o recv.o recv_init.o request_free.o request_get_status.o rsend.o rsend_init.o send.o send_init.o sendrecv.o sendrecv_rep.o status_set_cancelled.o ssend.o ssend_init.o start.o startall.o test.o test_cancelled.o testall.o testany.o testsome.o wait.o waitall.o waitany.o waitsome.o bsendutil.o mpir_request.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/pt2pt'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/rma'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/accumulate.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/alloc_mem.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/free_mem.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/get.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/put.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/win_complete.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/win_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/win_fence.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/win_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/win_get_group.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/win_get_name.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/win_lock.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/win_post.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/win_set_name.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/win_start.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/win_unlock.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/win_wait.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/win_test.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/rma/winutil.c
ar cr ../../../lib/libmpich.a accumulate.o alloc_mem.o free_mem.o get.o put.o win_complete.o win_create.o win_fence.o win_free.o win_get_group.o win_get_name.o win_lock.o win_post.o win_set_name.o win_start.o win_unlock.o win_wait.o win_test.o winutil.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/rma'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/spawn'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn/comm_disconnect.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn/comm_get_parent.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn/comm_join.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn/comm_spawn.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn/comm_spawn_multiple.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn/lookup_name.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn/publish_name.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn/unpublish_name.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn/open_port.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn/close_port.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn/comm_connect.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn/comm_accept.c
ar cr ../../../lib/libmpich.a comm_disconnect.o comm_get_parent.o comm_join.o comm_spawn.o comm_spawn_multiple.o lookup_name.o publish_name.o unpublish_name.o open_port.o close_port.o comm_connect.o comm_accept.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/spawn'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/timer'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/timer -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/timer/wtime.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/timer -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/timer/wtick.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/timer -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/timer/mpidtime.c
ar cr ../../../lib/libmpich.a wtime.o wtick.o mpidtime.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/timer'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/topo'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/cart_coords.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/cart_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/cart_get.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/cart_map.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/cart_rank.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/cart_shift.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/cart_sub.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/dims_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/graph_get.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/graph_map.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/graph_nbr.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/graphcreate.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/graphdimsget.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/graphnbrcnt.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/cartdim_get.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/topo_test.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/dist_gr_create_adj.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/dist_gr_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/dist_gr_neighb_count.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/dist_gr_neighb.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/topo/topoutil.c
ar cr ../../../lib/libmpich.a cart_coords.o cart_create.o cart_get.o cart_map.o cart_rank.o cart_shift.o cart_sub.o dims_create.o graph_get.o graph_map.o graph_nbr.o graphcreate.o graphdimsget.o graphnbrcnt.o cartdim_get.o topo_test.o dist_gr_create_adj.o dist_gr_create.o dist_gr_neighb_count.o dist_gr_neighb.o topoutil.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/topo'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/romio'
make mpiolib
make[4]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/romio'
compiling ROMIO in directory mpi-io
make[5]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/romio/mpi-io'
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/close.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/read.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/open.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/write.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/set_view.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/iread.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/iwrite.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/seek.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/get_posn.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/delete.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/read_all.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/read_at.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/read_atall.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/iread_at.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/iwrite_at.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/write_all.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/get_bytoff.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/write_at.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/write_atall.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/get_view.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/get_group.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/get_amode.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/get_extent.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/fsync.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/get_atom.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/set_atom.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/set_size.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/get_size.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/prealloc.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/file_f2c.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/file_c2f.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/set_info.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/get_info.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/rd_atallb.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/rd_atalle.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/read_allb.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/read_alle.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/wr_atallb.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/wr_atalle.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/write_allb.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/write_alle.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/get_posn_sh.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/iread_sh.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/read_sh.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/write_sh.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/iwrite_sh.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/seek_sh.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/read_ord.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/read_orde.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/write_ordb.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/read_ordb.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/write_ord.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/write_orde.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/mpiu_greq.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/mpich2_fileutil.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/register_datarep.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/mpir-mpioinit.c
ar cr /home/bgarrison/mpich2-build/lib/libmpich.a close.o read.o open.o write.o set_view.o iread.o iwrite.o seek.o get_posn.o delete.o read_all.o read_at.o read_atall.o iread_at.o iwrite_at.o write_all.o get_bytoff.o write_at.o write_atall.o get_view.o get_group.o get_amode.o get_extent.o fsync.o get_atom.o set_atom.o set_size.o get_size.o prealloc.o file_f2c.o file_c2f.o set_info.o get_info.o rd_atallb.o rd_atalle.o read_allb.o read_alle.o wr_atallb.o wr_atalle.o write_allb.o write_alle.o get_posn_sh.o iread_sh.o read_sh.o write_sh.o iwrite_sh.o seek_sh.o read_ord.o read_orde.o write_ordb.o read_ordb.o write_ord.o write_orde.o mpiu_greq.o mpich2_fileutil.o register_datarep.o mpir-mpioinit.o
ranlib /home/bgarrison/mpich2-build/lib/libmpich.a
make[5]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/romio/mpi-io'
compiling ROMIO in directory adio/common
make[5]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/romio/adio/common'
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_close.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_init.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_end.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_open.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/flatten.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/malloc.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_read_coll.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/eof_offset.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_write_coll.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/lock.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_read_str.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_write_str.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/iscontig.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/get_fp_posn.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_seek.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_delete.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_flush.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_hints.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/error.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_fstype.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_get_sh_fp.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_set_sh_fp.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/shfp_fname.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/byte_offset.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/status_setb.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_aggregate.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/cb_config_list.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_read_str_naive.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_set_view.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_iopen.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_write_str_naive.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_resize.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_read.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_write.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_iread.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_iwrite.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_done.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_wait.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/adi_close.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_prealloc.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_fcntl.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_iread_fake.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_iwrite_fake.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_done_fake.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_wait_fake.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_subarray.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_darray.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/strfns.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/greq_fns.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/system_hints.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_write_nolock.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_coll_exch_new.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_coll_build_req_new.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_io_coll.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_aggregate_new.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/heap-sort.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_opencoll.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_opencoll_scalable.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_opencoll_failsafe.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/common/ad_features.c
ar cr /home/bgarrison/mpich2-build/lib/libmpich.a ad_close.o ad_init.o ad_end.o ad_open.o flatten.o malloc.o ad_read_coll.o eof_offset.o ad_write_coll.o lock.o ad_read_str.o ad_write_str.o iscontig.o get_fp_posn.o ad_seek.o ad_delete.o ad_flush.o ad_hints.o error.o ad_fstype.o ad_get_sh_fp.o ad_set_sh_fp.o shfp_fname.o byte_offset.o status_setb.o ad_aggregate.o cb_config_list.o ad_read_str_naive.o ad_set_view.o ad_iopen.o ad_write_str_naive.o ad_resize.o ad_read.o ad_write.o ad_iread.o ad_iwrite.o ad_done.o ad_wait.o adi_close.o ad_prealloc.o ad_fcntl.o ad_iread_fake.o ad_iwrite_fake.o ad_done_fake.o ad_wait_fake.o ad_subarray.o ad_darray.o strfns.o greq_fns.o system_hints.o ad_write_nolock.o ad_coll_exch_new.o ad_coll_build_req_new.o ad_io_coll.o ad_aggregate_new.o heap-sort.o ad_opencoll.o ad_opencoll_scalable.o ad_opencoll_failsafe.o ad_features.o
ranlib /home/bgarrison/mpich2-build/lib/libmpich.a
make[5]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/romio/adio/common'
compiling ROMIO in directory mpi-io/glue/mpich2
make[5]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/romio/mpi-io/glue/mpich2'
gcc -I. -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/glue/mpich2/../../../mpi-io -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/glue/mpich2/../../../adio/include -I../../../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/glue/mpich2/../../../../../../src/include -I../../../../../../src/include -DHAVE_MPI_INFO_SRC -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/glue/mpich2/mpio_file.c
gcc -I. -I../../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/glue/mpich2/../../../mpi-io -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/glue/mpich2/../../../adio/include -I../../../adio/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/glue/mpich2/../../../../../../src/include -I../../../../../../src/include -DHAVE_MPI_INFO_SRC -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/mpi-io/glue/mpich2/mpio_err.c
ar cr /home/bgarrison/mpich2-build/lib/libmpich.a mpio_file.o mpio_err.o
make[5]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/romio/mpi-io/glue/mpich2'
compiling ROMIO in directory adio/ad_testfs
make[5]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/romio/adio/ad_testfs'
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_close.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_read.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_rdcoll.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_wrcoll.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_open.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_write.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_done.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_fcntl.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_iread.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_iwrite.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_wait.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_flush.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_seek.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_resize.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_hints.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs_delete.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_testfs/ad_testfs.c
ar cr /home/bgarrison/mpich2-build/lib/libmpich.a ad_testfs_close.o ad_testfs_read.o ad_testfs_rdcoll.o ad_testfs_wrcoll.o ad_testfs_open.o ad_testfs_write.o ad_testfs_done.o ad_testfs_fcntl.o ad_testfs_iread.o ad_testfs_iwrite.o ad_testfs_wait.o ad_testfs_flush.o ad_testfs_seek.o ad_testfs_resize.o ad_testfs_hints.o ad_testfs_delete.o ad_testfs.o
make[5]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/romio/adio/ad_testfs'
compiling ROMIO in directory adio/ad_ufs
make[5]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/romio/adio/ad_ufs'
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_ufs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_ufs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_ufs/ad_ufs_open.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_ufs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_ufs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_ufs/ad_ufs.c
ar cr /home/bgarrison/mpich2-build/lib/libmpich.a ad_ufs_open.o ad_ufs.o
make[5]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/romio/adio/ad_ufs'
compiling ROMIO in directory adio/ad_nfs
make[5]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/romio/adio/ad_nfs'
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/ad_nfs_read.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/ad_nfs_open.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/ad_nfs_write.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/ad_nfs_done.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/ad_nfs_fcntl.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/ad_nfs_iread.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/ad_nfs_iwrite.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/ad_nfs_wait.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/ad_nfs_setsh.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/ad_nfs_getsh.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/ad_nfs.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/ad_nfs_resize.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpi/romio/adio/ad_nfs/ad_nfs_features.c
ar cr /home/bgarrison/mpich2-build/lib/libmpich.a ad_nfs_read.o ad_nfs_open.o ad_nfs_write.o ad_nfs_done.o ad_nfs_fcntl.o ad_nfs_iread.o ad_nfs_iwrite.o ad_nfs_wait.o ad_nfs_setsh.o ad_nfs_getsh.o ad_nfs.o ad_nfs_resize.o ad_nfs_features.o
make[5]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/romio/adio/ad_nfs'
make[4]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/romio'
make[4]: Entering directory `/home/bgarrison/mpich2-build/src/mpi/romio'
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi/romio'
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/mpi'
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/util'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/util/mem'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/mem -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/mem/trmem.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/mem -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/mem/handlemem.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/mem -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/mem/safestr.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/mem -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/mem/argstr.c
ar cr ../../../lib/libmpich.a trmem.o handlemem.o safestr.o argstr.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/util/mem'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/util/info'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/info -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/info/infoutil.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/info -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/info/info_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/info -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/info/info_delete.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/info -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/info/info_dup.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/info -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/info/info_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/info -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/info/info_get.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/info -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/info/info_getn.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/info -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/info/info_getnth.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/info -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/info/info_getvallen.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/info -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/info/info_set.c
ar cr ../../../lib/libmpich.a infoutil.o info_create.o info_delete.o info_dup.o info_free.o info_get.o info_getn.o info_getnth.o info_getvallen.o info_set.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/util/info'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/util/msgs'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/msgs -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/msgs/msgprint.c
ar cr ../../../lib/libmpich.a msgprint.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/util/msgs'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/util/instrm'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/instrm -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/instrm/states.c
ar cr ../../../lib/libmpich.a states.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/util/instrm'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/util/thread'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/thread -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/thread/mpiu_thread.c
ar cr ../../../lib/libmpich.a mpiu_thread.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/util/thread'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/util/dbg'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/dbg -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/dbg/dbg_printf.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/dbg -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/dbg/timelimit.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/dbg -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/dbg/exit.c
ar cr ../../../lib/libmpich.a dbg_printf.o timelimit.o exit.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/util/dbg'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/util/param'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/param -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/param/param.c
ar cr ../../../lib/libmpich.a param.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/util/param'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/util/osserv'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/osserv -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/osserv/dl.c
ar cr ../../../lib/libmpich.a dl.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/util/osserv'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/util/procmap'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/procmap -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/procmap/local_proc.c
ar cr ../../../lib/libmpich.a local_proc.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/util/procmap'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/util/other'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/other -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/util/other/outliers.c
ar cr ../../../lib/libmpich.a outliers.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/util/other'
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/util'
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/nameserv'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/nameserv/mpd'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/nameserv/mpd -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpi/spawn -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/nameserv/mpd/mpd_nameserv.c
ar cr ../../../lib/libmpich.a mpd_nameserv.o
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/nameserv/mpd'
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/nameserv'
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/binding'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/binding/cxx'
c++ -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/binding/cxx -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/binding/cxx/initcxx.cxx
ar cr ../../../lib/libmpichcxx.a initcxx.o
ranlib ../../../lib/libmpichcxx.a
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/binding/cxx'
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/binding'
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/env'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/env -I../include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/env/mpich2version.c
gcc -O2   -o mpich2version mpich2version.o  \
	../../lib/libmpich.a -lpthread   -lrt
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/env'
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/packaging'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/packaging/pkgconfig'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/packaging/pkgconfig'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/packaging/envmods'
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/packaging/envmods'
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/packaging'
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/mpe2'
make --no-print-directory  build_lib_bin
**** Making src/misc ....
make --no-print-directory  mpe_debug_objs
make --no-print-directory  /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_nompi.a
gcc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/../../include -O2 -DMPI_LINUX  -DMPE_NOMPI -o mpehname.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/src/mpehname.c
ar cr /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_nompi.a mpehname.no
ranlib /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_nompi.a
make --no-print-directory  /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe.a
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o decomp.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/src/decomp.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o mpe_seq.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/src/mpe_seq.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o dbxerr.po -c dbxerr.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o getgrank.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/src/getgrank.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o examine.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/src/examine.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o privtags.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/src/privtags.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o mpehname.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/src/mpehname.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o mpe_io.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/misc/src/mpe_io.c
ar cr /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe.a decomp.po mpe_seq.po dbxerr.po getgrank.po examine.po privtags.po mpehname.po mpe_io.po
ranlib /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe.a
**** Making src/callstack ....
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/../../include   -o iterator.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/src/iterator.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/../../include   -o fancyprint.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/src/fancyprint.c
gcc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/../../include -O2  -o iterator.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/src/iterator.c
gcc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/../../include -O2  -o fancyprint.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/src/fancyprint.c
ar cr /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_nompi.a iterator.no fancyprint.no
ar cr /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe.a iterator.po fancyprint.po
make --no-print-directory  /home/bgarrison/mpich2-build/src/mpe2/bin/check_callstack
gcc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/../../include -O2  -o check_callstack.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/callstack/src/check_callstack.c
cp -f check_callstack.no mpe2tmp.o
gcc -Wl,--export-dynamic -O2  -o /home/bgarrison/mpich2-build/src/mpe2/bin/check_callstack mpe2tmp.o \
	                         -L/home/bgarrison/mpich2-build/src/mpe2/lib -lmpe_nompi
**** Making src/logging ....
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o mpi_null.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/mpi_null.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_util.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_util.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_timer.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_timer.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_uuid.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_uuid.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_commset.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_commset.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_preamble.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_preamble.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_record.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_record.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_sync.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_sync.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_block.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_block.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_buffer.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_buffer.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_merger.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_merger.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_cache.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_cache.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_joiner.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_joiner.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o mpe_log_thread.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/mpe_log_thread.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o mpe_log.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/mpe_log.c
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o mpe_log_null.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/mpe_log_null.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o mpe_log_null.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/mpe_log_null.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o clog_util.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_util.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o clog_timer.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_timer.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o clog_uuid.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_uuid.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o clog_commset.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_commset.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o clog_preamble.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_preamble.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o clog_record.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_record.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o clog_sync.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_sync.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o clog_block.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_block.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o clog_buffer.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_buffer.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o clog_merger.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_merger.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o clog_cache.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_cache.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o clog_joiner.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_joiner.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o clog.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o mpe_log_thread.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/mpe_log_thread.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include   -o mpe_log.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/mpe_log.c
ar cr /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_nompi.a mpi_null.no clog_util.no clog_timer.no clog_uuid.no clog_commset.no clog_preamble.no clog_record.no clog_sync.no clog_block.no clog_buffer.no clog_merger.no clog_cache.no clog_joiner.no clog.no mpe_log_thread.no mpe_log.no
make --no-print-directory  /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_nompi_null.a
ar cr /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_nompi_null.a mpi_null.no mpe_log_null.no
ranlib /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_nompi_null.a
make --no-print-directory  /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_null.a
ar cr /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_null.a mpe_log_null.po
ranlib /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_null.a
ar cr /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe.a clog_util.po clog_timer.po clog_uuid.po clog_commset.po clog_preamble.po clog_record.po clog_sync.po clog_block.po clog_buffer.po clog_merger.po clog_cache.po clog_joiner.po clog.po mpe_log_thread.po mpe_log.po
make --no-print-directory  /home/bgarrison/mpich2-build/src/mpe2/bin/clog2_print /home/bgarrison/mpich2-build/src/mpe2/bin/clog2_join /home/bgarrison/mpich2-build/src/mpe2/bin/clog2_repair
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_print.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_print.c
cp -f clog_print.no mpe2tmp1.o
gcc  -O2  -o /home/bgarrison/mpich2-build/src/mpe2/bin/clog2_print mpe2tmp1.o \
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_join.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_join.c
cp -f clog_join.no mpe2tmp2.o
gcc  -O2  -o /home/bgarrison/mpich2-build/src/mpe2/bin/clog2_join mpe2tmp2.o \
gcc -I.. -I../../.. -I../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_repair.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/logging/src/clog_repair.c
cp -f clog_repair.no mpe2tmp3.o
gcc  -O2  -o /home/bgarrison/mpich2-build/src/mpe2/bin/clog2_repair mpe2tmp3.o \
**** Making src/wrappers ....
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers/src/log_mpi_util.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers/src/log_mpi_core.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers/src/trace_mpi_core.c
make --no-print-directory  /home/bgarrison/mpich2-build/src/mpe2/lib/liblmpe.a
ar cr /home/bgarrison/mpich2-build/src/mpe2/lib/liblmpe.a log_mpi_util.o log_mpi_core.o
ranlib /home/bgarrison/mpich2-build/src/mpe2/lib/liblmpe.a
make --no-print-directory  /home/bgarrison/mpich2-build/src/mpe2/lib/libtmpe.a
ar cr /home/bgarrison/mpich2-build/src/mpe2/lib/libtmpe.a trace_mpi_core.o
ranlib /home/bgarrison/mpich2-build/src/mpe2/lib/libtmpe.a
make --no-print-directory  /home/bgarrison/mpich2-build/src/mpe2/lib/mpe_prof.o
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/wrappers/src/mpe_prof.c
make --no-print-directory  linktest_all
make --no-print-directory  linktest_C
make --no-print-directory  linktest_F77
**** Making src/graphics ....
gcc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include  -O2  -DMPE_NOMPI -o mpe_graphics.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/mpe_graphics.c
gcc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include  -O2  -DMPE_NOMPI -o xcolor.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/xcolor.c
gcc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include  -O2  -DMPE_NOMPI -o xframe.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/xframe.c
gcc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include  -O2  -DMPE_NOMPI -o xinit.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/xinit.c
gcc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include  -O2  -DMPE_NOMPI -o xwmap.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/xwmap.c
gcc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include  -O2  -DMPE_NOMPI -o xmouse.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/xmouse.c
gcc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include  -O2  -DMPE_NOMPI -o xkey.no -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/xkey.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include    -o mpe_graphics.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/mpe_graphics.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include    -o xcolor.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/xcolor.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include    -o xframe.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/xframe.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include    -o xinit.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/xinit.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include    -o xwmap.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/xwmap.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include    -o xmouse.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/xmouse.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include    -o xkey.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/xkey.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/../../include    -o visual_mess.po -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/graphics/src/visual_mess.c
ar cr /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_nompi.a mpe_graphics.no xcolor.no xframe.no xinit.no xwmap.no xmouse.no xkey.no
ar cr /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe.a mpe_graphics.po xcolor.po xframe.po xinit.po xwmap.po xmouse.po xkey.po
make --no-print-directory  /home/bgarrison/mpich2-build/src/mpe2/lib/libampe.a
ar cr /home/bgarrison/mpich2-build/src/mpe2/lib/libampe.a visual_mess.po
ranlib /home/bgarrison/mpich2-build/src/mpe2/lib/libampe.a
**** Making src/collchk ....
make --no-print-directory  /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_collchk.a
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/begin.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/err_han.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/is_init.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/check_buff.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/check_dims.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/check_graph.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/check_size.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/same_amode.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/same_call.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/same_dtype.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/same_high_low.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/same_int.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/same_local_leader.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/same_op.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/same_root.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/same_tag.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/same_datarep.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/same_whence.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/allgather.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/allgatherv.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/allreduce.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/alltoall.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/alltoallv.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/barrier.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/bcast.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/cart_create.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/cart_map.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/gather.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/gatherv.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/graph_create.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/graph_map.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/init.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/intercomm_create.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/intercomm_merge.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/reduce.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/reduce_scatter.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/scan.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/scatter.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/scatterv.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/finalize.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/exscan.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/alltoallw.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_open.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_preallocate.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_read_all_begin.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_read_all.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_read_all_end.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_read_at_all_begin.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_read_at_all.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_read_at_all_end.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_read_ordered_begin.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_read_ordered.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_read_ordered_end.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_seek_shared.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_set_atomicity.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_set_size.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_set_view.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_write_all_begin.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_write_all.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_write_all_end.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_write_at_all_begin.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_write_at_all.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_write_at_all_end.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_write_ordered_begin.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_write_ordered.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/file_write_ordered_end.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/add_fh.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/get_fh.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/win_create.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/win_fence.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/add_win.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/get_win.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/comm_accept.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/comm_connect.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/comm_create.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/comm_disconnect.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/comm_dup.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/comm_spawn.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/comm_spawn_multiple.c
/home/bgarrison/mpich2-build/bin/mpicc -I.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/include -I/home/bgarrison/mpich2-build/src/mpe2/include -I../../.. -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/../../include   -c /home/bgarrison/libraries/mpich2-1.2.1/src/mpe2/src/collchk/src/comm_split.c
ar cr /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_collchk.a *.o
ranlib /home/bgarrison/mpich2-build/src/mpe2/lib/libmpe_collchk.a
**** Making src/slog2sdk ....
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/mpe2'
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/pmi'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/pmi/simple'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple/simple_pmiutil.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -I/home/bgarrison/mpich2-build/src/mpid/ch3/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/include -I/home/bgarrison/mpich2-build/src/mpid/common/datatype -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/datatype -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/bgarrison/mpich2-build/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/bgarrison/mpich2-build/src/mpid/common/locks -I/home/bgarrison/libraries/mpich2-1.2.1/src/mpid/common/locks -I/home/bgarrison/mpich2-build/src/util/wrappers -I/home/bgarrison/libraries/mpich2-1.2.1/src/util/wrappers -c /home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple/simple_pmi.c
ar cr ../../../lib/libmpich.a simple_pmiutil.o simple_pmi.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/pmi/simple'
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/pmi'
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/pm'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/pm/mpd'
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pm/mpd -O2  -c  /home/bgarrison/libraries/mpich2-1.2.1/src/pm/mpd/mpdroot.c
gcc -O2   -o mpdroot mpdroot.o -lpthread   -lrt
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/pm/mpd'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/pm/hydra'
Making all in ../../mpl
make[4]: Entering directory `/home/bgarrison/mpich2-build/src/mpl'
  CC     mplstr.o
  AR     libmpl.a
make[4]: Leaving directory `/home/bgarrison/mpich2-build/src/mpl'
Making all in .
make[4]: Entering directory `/home/bgarrison/mpich2-build/src/pm/hydra'
  CC     alloc.o
  CC     args.o
  CC     dbg.o
  CC     env.o
  CC     launch.o
  CC     others.o
  CC     signals.o
  CC     sock.o
  CC     string.o
  CC     timer.o
  CC     rmki_init.o
  CC     rmki_query_node_list.o
  CC     rmku_query_node_list.o
  CC     rmk_dummy_init.o
  CC     rmk_pbs_init.o
  CC     rmk_pbs_query_node_list.o
  CC     cssi_init.o
  CC     cssi_finalize.o
  CC     cssi_query_string.o
  CC     cssu_tmp.o
  CC     bind.o
  CC     bind_plpa.o
  CC     plpa_api_probe.o
  CC     plpa_dispatch.o
  CC     plpa_map.o
  CC     plpa_runtime.o
  CC     bsci_init.o
  CC     bsci_finalize.o
  CC     bsci_launch.o
  CC     bsci_query_node_list.o
  CC     bsci_query_proxy_id.o
  CC     bsci_usize.o
  CC     bsci_wait.o
  CC     bscu_finalize.o
  CC     bscu_query_node_list.o
  CC     bscu_query_proxy_id.o
  CC     bscu_usize.o
  CC     bscu_wait.o
  CC     ssh_init.o
  CC     ssh_launch.o
  CC     rsh_init.o
  CC     rsh_launch.o
  CC     fork_init.o
  CC     fork_launch.o
  CC     slurm_init.o
  CC     slurm_launch.o
  CC     slurm_query_node_list.o
  CC     slurm_query_proxy_id.o
  CC     ckpoint.o
  CC     demux.o
  AR     libhydra.a
  CC     pmi.o
  CC     pmi_handle.o
  CC     pmi_handle_common.o
  CC     pmi_handle_v1.o
  CC     pmi_handle_v2.o
  CC     pmi_serv_cb.o
  CC     pmi_serv_finalize.o
  CC     pmi_serv_launch.o
  CC     pmi_serv_utils.o
  AR     libpm.a
  CC     uiu.o
  AR     libui.a
  CC     pmi_proxy.o
  CC     pmi_proxy_cb.o
  CC     pmi_proxy_utils.o
  CCLD   pmi_proxy
  CC     mpiexec-callback.o
  CC     mpiexec-mpiexec.o
  CC     mpiexec-utils.o
  CCLD   mpiexec
make[4]: Leaving directory `/home/bgarrison/mpich2-build/src/pm/hydra'
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/pm/hydra'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/pm/gforker'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I../../pmi/simple -I/home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple -I/home/bgarrison/libraries/mpich2-1.2.1/src/pm/util -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -c /home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/mpiexec.c
cd ../util && make
make[4]: Entering directory `/home/bgarrison/mpich2-build/src/pm/util'
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I../../pmi/simple -I/home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -c /home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util/cmnargs.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I../../pmi/simple -I/home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -c /home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util/process.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I../../pmi/simple -I/home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -c /home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util/ioloop.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I../../pmi/simple -I/home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -c /home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util/pmiserv.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I../../pmi/simple -I/home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -c /home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util/labelout.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I../../pmi/simple -I/home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -c /home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util/env.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I../../pmi/simple -I/home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -c /home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util/newsession.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I../../pmi/simple -I/home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -c /home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util/rm.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I../../pmi/simple -I/home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -c /home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util/pmiport.c
gcc -DHAVE_CONFIG_H -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util -I../../include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -I../../pmi/simple -I/home/bgarrison/libraries/mpich2-1.2.1/src/pmi/simple -O2 -I/home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src -I/home/bgarrison/mpich2-build/src/openpa/src -DUSE_PROCESS_LOCKS -c /home/bgarrison/libraries/mpich2-1.2.1/src/pm/gforker/../util/dbgiface.c
ar cr libmpiexec.a cmnargs.o process.o ioloop.o pmiserv.o labelout.o env.o newsession.o rm.o pmiport.o dbgiface.o
ranlib libmpiexec.a
make[4]: Leaving directory `/home/bgarrison/mpich2-build/src/pm/util'
gcc -O2    -o mpiexec mpiexec.o  \
	../util/libmpiexec.a ../../../lib/libmpich.a -lpthread   -lrt
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/pm/gforker'
make all-postamble
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/pm'
if [ -n "mpd" -a -d "mpd" ] ; then \
	build_prefix=`cd ../.. && pwd` && cd mpd && \
	make prefix=$build_prefix exec_prefix=$build_prefix bindir=$build_prefix/bin mpich2-build-install ; \
	fi
make[4]: Entering directory `/home/bgarrison/mpich2-build/src/pm/mpd'
/usr/bin/install -c -m 644 /home/bgarrison/libraries/mpich2-1.2.1/src/pm/mpd/mpdroot.c mpich2-mpdroot.c
gcc -I. -I/home/bgarrison/libraries/mpich2-1.2.1/src/pm/mpd -O2  -c mpich2-mpdroot.c
rm -f mpich2-mpdroot.c
gcc -O2   -o mpich2-mpdroot mpich2-mpdroot.o -lpthread   -lrt
rm -f mpich2-mpdroot.o
copying python files/links into  /home/bgarrison/mpich2-build/bin
make[4]: Leaving directory `/home/bgarrison/mpich2-build/src/pm/mpd'
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/pm'
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/pm'
make[1]: Leaving directory `/home/bgarrison/mpich2-build/src'
make[1]: Entering directory `/home/bgarrison/mpich2-build/examples'
../bin/mpicc -I../src/include -I/home/bgarrison/libraries/mpich2-1.2.1/src/include -c /home/bgarrison/libraries/mpich2-1.2.1/examples/cpi.c
../bin/mpicc   -o cpi cpi.o  -lm
make[1]: Leaving directory `/home/bgarrison/mpich2-build/examples'
make all-postamble
make[1]: Entering directory `/home/bgarrison/mpich2-build'
Make completed
make[1]: Leaving directory `/home/bgarrison/mpich2-build'
if [ ! -d /home/bgarrison/mpich2-install ] ; then mkdir -p /home/bgarrison/mpich2-install ; fi
if [ ! -d /home/bgarrison/mpich2-install/share ] ; then mkdir -p /home/bgarrison/mpich2-install/share ; fi
if [ ! -d /home/bgarrison/mpich2-install/share/doc/ ] ; then mkdir -p /home/bgarrison/mpich2-install/share/doc/ ; fi
if [ ! -d /home/bgarrison/mpich2-install/share/man ] ; then mkdir -p /home/bgarrison/mpich2-install/share/man ; fi
if [ ! -d /home/bgarrison/mpich2-install/include ] ; then mkdir -p /home/bgarrison/mpich2-install/include ; fi
if [ ! -d /home/bgarrison/mpich2-install/lib ] ; then mkdir -p /home/bgarrison/mpich2-install/lib ; fi
make install-local
if [ "no" = "yes" ] ; then \
	    /usr/bin/install -c -m 644 src/mpi/debugger/libtvmpich2.so \
			/home/bgarrison/mpich2-install/lib/libtvmpich2.so ; fi
if [ -n " hydra gforker" ] ; then \
	    for pm in  hydra gforker /dev/null ; do \
		if [ -d src/pm/$pm ] ; then \
		     (cd src/pm/$pm && make install-alt ) ; fi ; \
	    done ; \
	fi
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/pm/hydra'
/usr/bin/install -c  mpiexec /home/bgarrison/mpich2-install/bin/mpiexec.hydra
/usr/bin/install -c  pmi_proxy /home/bgarrison/mpich2-install/bin/
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/pm/hydra'
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/pm/gforker'
cd ../util && make
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/pm/util'
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/pm/util'
/usr/bin/install -c  mpiexec /home/bgarrison/mpich2-install/bin/mpiexec.gforker
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/pm/gforker'
/usr/bin/install -c -m 644 src/include/mpi.h /home/bgarrison/mpich2-install/include/mpi.h
/usr/bin/install -c -m 644 lib/libmpich.a /home/bgarrison/mpich2-install/lib/libmpich.a
/usr/bin/install -c -m 644 index.htm /home/bgarrison/mpich2-install/share/doc//index.htm
/usr/bin/install -c -m 644 index.htm /home/bgarrison/mpich2-install/share/doc//www1/index.htm
/usr/bin/install -c -m 644 mpicc.html /home/bgarrison/mpich2-install/share/doc//www1/mpicc.html
/usr/bin/install -c -m 644 mpicxx.html /home/bgarrison/mpich2-install/share/doc//www1/mpicxx.html
/usr/bin/install -c -m 644 mpiexec.html /home/bgarrison/mpich2-install/share/doc//www1/mpiexec.html
/usr/bin/install -c -m 644 mpif77.html /home/bgarrison/mpich2-install/share/doc//www1/mpif77.html
/usr/bin/install -c -m 644 mpif90.html /home/bgarrison/mpich2-install/share/doc//www1/mpif90.html
/usr/bin/install -c -m 644 MPI.html /home/bgarrison/mpich2-install/share/doc//www1/MPI.html
/usr/bin/install -c -m 644 index.htm /home/bgarrison/mpich2-install/share/doc//www3/index.htm
/usr/bin/install -c -m 644 MPI_Abort.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Abort.html
/usr/bin/install -c -m 644 MPI_Accumulate.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Accumulate.html
/usr/bin/install -c -m 644 MPI_Add_error_class.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Add_error_class.html
/usr/bin/install -c -m 644 MPI_Add_error_code.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Add_error_code.html
/usr/bin/install -c -m 644 MPI_Add_error_string.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Add_error_string.html
/usr/bin/install -c -m 644 MPI_Address.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Address.html
/usr/bin/install -c -m 644 MPI_Allgather.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Allgather.html
/usr/bin/install -c -m 644 MPI_Allgatherv.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Allgatherv.html
/usr/bin/install -c -m 644 MPI_Alloc_mem.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Alloc_mem.html
/usr/bin/install -c -m 644 MPI_Allreduce.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Allreduce.html
/usr/bin/install -c -m 644 MPI_Alltoall.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Alltoall.html
/usr/bin/install -c -m 644 MPI_Alltoallv.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Alltoallv.html
/usr/bin/install -c -m 644 MPI_Alltoallw.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Alltoallw.html
/usr/bin/install -c -m 644 MPI_Attr_delete.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Attr_delete.html
/usr/bin/install -c -m 644 MPI_Attr_get.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Attr_get.html
/usr/bin/install -c -m 644 MPI_Attr_put.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Attr_put.html
/usr/bin/install -c -m 644 MPI_Barrier.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Barrier.html
/usr/bin/install -c -m 644 MPI_Bcast.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Bcast.html
/usr/bin/install -c -m 644 MPI_Bsend.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Bsend.html
/usr/bin/install -c -m 644 MPI_Bsend_init.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Bsend_init.html
/usr/bin/install -c -m 644 MPI_Buffer_attach.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Buffer_attach.html
/usr/bin/install -c -m 644 MPI_Buffer_detach.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Buffer_detach.html
/usr/bin/install -c -m 644 MPI_Cancel.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Cancel.html
/usr/bin/install -c -m 644 MPI_Cart_coords.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Cart_coords.html
/usr/bin/install -c -m 644 MPI_Cart_create.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Cart_create.html
/usr/bin/install -c -m 644 MPI_Cartdim_get.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Cartdim_get.html
/usr/bin/install -c -m 644 MPI_Cart_get.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Cart_get.html
/usr/bin/install -c -m 644 MPI_Cart_map.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Cart_map.html
/usr/bin/install -c -m 644 MPI_Cart_rank.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Cart_rank.html
/usr/bin/install -c -m 644 MPI_Cart_shift.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Cart_shift.html
/usr/bin/install -c -m 644 MPI_Cart_sub.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Cart_sub.html
/usr/bin/install -c -m 644 MPI_Close_port.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Close_port.html
/usr/bin/install -c -m 644 MPI_Comm_accept.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_accept.html
/usr/bin/install -c -m 644 MPI_Comm_call_errhandler.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_call_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_compare.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_compare.html
/usr/bin/install -c -m 644 MPI_Comm_connect.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_connect.html
/usr/bin/install -c -m 644 MPI_Comm_create_errhandler.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_create_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_create.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_create.html
/usr/bin/install -c -m 644 MPI_Comm_create_keyval.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_create_keyval.html
/usr/bin/install -c -m 644 MPI_Comm_delete_attr.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_delete_attr.html
/usr/bin/install -c -m 644 MPI_Comm_disconnect.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_disconnect.html
/usr/bin/install -c -m 644 MPI_Comm_dup.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_dup.html
/usr/bin/install -c -m 644 MPI_Comm_free.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_free.html
/usr/bin/install -c -m 644 MPI_Comm_free_keyval.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_free_keyval.html
/usr/bin/install -c -m 644 MPI_Comm_get_attr.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_get_attr.html
/usr/bin/install -c -m 644 MPI_Comm_get_errhandler.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_get_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_get_name.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_get_name.html
/usr/bin/install -c -m 644 MPI_Comm_get_parent.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_get_parent.html
/usr/bin/install -c -m 644 MPI_Comm_group.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_group.html
/usr/bin/install -c -m 644 MPI_Comm_join.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_join.html
/usr/bin/install -c -m 644 MPI_Comm_rank.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_rank.html
/usr/bin/install -c -m 644 MPI_Comm_remote_group.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_remote_group.html
/usr/bin/install -c -m 644 MPI_Comm_remote_size.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_remote_size.html
/usr/bin/install -c -m 644 MPI_Comm_set_attr.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_set_attr.html
/usr/bin/install -c -m 644 MPI_Comm_set_errhandler.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_set_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_set_name.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_set_name.html
/usr/bin/install -c -m 644 MPI_Comm_size.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_size.html
/usr/bin/install -c -m 644 MPI_Comm_spawn.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_spawn.html
/usr/bin/install -c -m 644 MPI_Comm_spawn_multiple.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_spawn_multiple.html
/usr/bin/install -c -m 644 MPI_Comm_split.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_split.html
/usr/bin/install -c -m 644 MPI_Comm_test_inter.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Comm_test_inter.html
/usr/bin/install -c -m 644 MPI_Dims_create.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Dims_create.html
/usr/bin/install -c -m 644 MPI_Dist_graph_create_adjacent.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Dist_graph_create_adjacent.html
/usr/bin/install -c -m 644 MPI_Dist_graph_create.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Dist_graph_create.html
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors_count.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Dist_graph_neighbors_count.html
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Dist_graph_neighbors.html
/usr/bin/install -c -m 644 MPI_Errhandler_create.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Errhandler_create.html
/usr/bin/install -c -m 644 MPI_Errhandler_free.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Errhandler_free.html
/usr/bin/install -c -m 644 MPI_Errhandler_get.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Errhandler_get.html
/usr/bin/install -c -m 644 MPI_Errhandler_set.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Errhandler_set.html
/usr/bin/install -c -m 644 MPI_Error_class.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Error_class.html
/usr/bin/install -c -m 644 MPI_Error_string.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Error_string.html
/usr/bin/install -c -m 644 MPI_Exscan.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Exscan.html
/usr/bin/install -c -m 644 MPI_File_c2f.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_c2f.html
/usr/bin/install -c -m 644 MPI_File_call_errhandler.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_call_errhandler.html
/usr/bin/install -c -m 644 MPI_File_close.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_close.html
/usr/bin/install -c -m 644 MPI_File_create_errhandler.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_create_errhandler.html
/usr/bin/install -c -m 644 MPI_File_delete.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_delete.html
/usr/bin/install -c -m 644 MPI_File_f2c.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_f2c.html
/usr/bin/install -c -m 644 MPI_File_get_amode.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_get_amode.html
/usr/bin/install -c -m 644 MPI_File_get_atomicity.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_get_atomicity.html
/usr/bin/install -c -m 644 MPI_File_get_byte_offset.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_get_byte_offset.html
/usr/bin/install -c -m 644 MPI_File_get_errhandler.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_get_errhandler.html
/usr/bin/install -c -m 644 MPI_File_get_group.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_get_group.html
/usr/bin/install -c -m 644 MPI_File_get_info.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_get_info.html
/usr/bin/install -c -m 644 MPI_File_get_position.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_get_position.html
/usr/bin/install -c -m 644 MPI_File_get_position_shared.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_get_position_shared.html
/usr/bin/install -c -m 644 MPI_File_get_size.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_get_size.html
/usr/bin/install -c -m 644 MPI_File_get_type_extent.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_get_type_extent.html
/usr/bin/install -c -m 644 MPI_File_get_view.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_get_view.html
/usr/bin/install -c -m 644 MPI_File_iread_at.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_iread_at.html
/usr/bin/install -c -m 644 MPI_File_iread.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_iread.html
/usr/bin/install -c -m 644 MPI_File_iread_shared.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_iread_shared.html
/usr/bin/install -c -m 644 MPI_File_iwrite_at.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_iwrite_at.html
/usr/bin/install -c -m 644 MPI_File_iwrite.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_iwrite.html
/usr/bin/install -c -m 644 MPI_File_iwrite_shared.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_iwrite_shared.html
/usr/bin/install -c -m 644 MPI_File_open.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_open.html
/usr/bin/install -c -m 644 MPI_File_preallocate.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_preallocate.html
/usr/bin/install -c -m 644 MPI_File_read_all_begin.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_read_all_begin.html
/usr/bin/install -c -m 644 MPI_File_read_all_end.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_read_all_end.html
/usr/bin/install -c -m 644 MPI_File_read_all.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_read_all.html
/usr/bin/install -c -m 644 MPI_File_read_at_all_begin.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_read_at_all_begin.html
/usr/bin/install -c -m 644 MPI_File_read_at_all_end.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_read_at_all_end.html
/usr/bin/install -c -m 644 MPI_File_read_at_all.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_read_at_all.html
/usr/bin/install -c -m 644 MPI_File_read_at.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_read_at.html
/usr/bin/install -c -m 644 MPI_File_read.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_read.html
/usr/bin/install -c -m 644 MPI_File_read_ordered_begin.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_read_ordered_begin.html
/usr/bin/install -c -m 644 MPI_File_read_ordered_end.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_read_ordered_end.html
/usr/bin/install -c -m 644 MPI_File_read_ordered.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_read_ordered.html
/usr/bin/install -c -m 644 MPI_File_read_shared.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_read_shared.html
/usr/bin/install -c -m 644 MPI_File_seek.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_seek.html
/usr/bin/install -c -m 644 MPI_File_seek_shared.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_seek_shared.html
/usr/bin/install -c -m 644 MPI_File_set_atomicity.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_set_atomicity.html
/usr/bin/install -c -m 644 MPI_File_set_errhandler.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_set_errhandler.html
/usr/bin/install -c -m 644 MPI_File_set_info.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_set_info.html
/usr/bin/install -c -m 644 MPI_File_set_size.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_set_size.html
/usr/bin/install -c -m 644 MPI_File_set_view.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_set_view.html
/usr/bin/install -c -m 644 MPI_File_sync.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_sync.html
/usr/bin/install -c -m 644 MPI_File_write_all_begin.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_write_all_begin.html
/usr/bin/install -c -m 644 MPI_File_write_all_end.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_write_all_end.html
/usr/bin/install -c -m 644 MPI_File_write_all.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_write_all.html
/usr/bin/install -c -m 644 MPI_File_write_at_all_begin.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_write_at_all_begin.html
/usr/bin/install -c -m 644 MPI_File_write_at_all_end.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_write_at_all_end.html
/usr/bin/install -c -m 644 MPI_File_write_at_all.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_write_at_all.html
/usr/bin/install -c -m 644 MPI_File_write_at.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_write_at.html
/usr/bin/install -c -m 644 MPI_File_write.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_write.html
/usr/bin/install -c -m 644 MPI_File_write_ordered_begin.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_write_ordered_begin.html
/usr/bin/install -c -m 644 MPI_File_write_ordered_end.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_write_ordered_end.html
/usr/bin/install -c -m 644 MPI_File_write_ordered.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_write_ordered.html
/usr/bin/install -c -m 644 MPI_File_write_shared.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_File_write_shared.html
/usr/bin/install -c -m 644 MPI_Finalized.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Finalized.html
/usr/bin/install -c -m 644 MPI_Finalize.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Finalize.html
/usr/bin/install -c -m 644 MPI_Free_mem.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Free_mem.html
/usr/bin/install -c -m 644 MPI_Gather.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Gather.html
/usr/bin/install -c -m 644 MPI_Gatherv.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Gatherv.html
/usr/bin/install -c -m 644 MPI_Get_address.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Get_address.html
/usr/bin/install -c -m 644 MPI_Get_count.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Get_count.html
/usr/bin/install -c -m 644 MPI_Get_elements.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Get_elements.html
/usr/bin/install -c -m 644 MPI_Get.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Get.html
/usr/bin/install -c -m 644 MPI_Get_processor_name.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Get_processor_name.html
/usr/bin/install -c -m 644 MPI_Get_version.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Get_version.html
/usr/bin/install -c -m 644 MPI_Graph_create.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Graph_create.html
/usr/bin/install -c -m 644 MPI_Graphdims_get.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Graphdims_get.html
/usr/bin/install -c -m 644 MPI_Graph_get.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Graph_get.html
/usr/bin/install -c -m 644 MPI_Graph_map.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Graph_map.html
/usr/bin/install -c -m 644 MPI_Graph_neighbors_count.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Graph_neighbors_count.html
/usr/bin/install -c -m 644 MPI_Graph_neighbors.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Graph_neighbors.html
/usr/bin/install -c -m 644 MPI_Grequest_complete.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Grequest_complete.html
/usr/bin/install -c -m 644 MPI_Grequest_start.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Grequest_start.html
/usr/bin/install -c -m 644 MPI_Group_compare.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Group_compare.html
/usr/bin/install -c -m 644 MPI_Group_difference.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Group_difference.html
/usr/bin/install -c -m 644 MPI_Group_excl.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Group_excl.html
/usr/bin/install -c -m 644 MPI_Group_free.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Group_free.html
/usr/bin/install -c -m 644 MPI_Group_incl.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Group_incl.html
/usr/bin/install -c -m 644 MPI_Group_intersection.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Group_intersection.html
/usr/bin/install -c -m 644 MPI_Group_range_excl.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Group_range_excl.html
/usr/bin/install -c -m 644 MPI_Group_range_incl.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Group_range_incl.html
/usr/bin/install -c -m 644 MPI_Group_rank.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Group_rank.html
/usr/bin/install -c -m 644 MPI_Group_size.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Group_size.html
/usr/bin/install -c -m 644 MPI_Group_translate_ranks.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Group_translate_ranks.html
/usr/bin/install -c -m 644 MPI_Group_union.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Group_union.html
/usr/bin/install -c -m 644 MPI_Ibsend.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Ibsend.html
/usr/bin/install -c -m 644 MPI_Info_create.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Info_create.html
/usr/bin/install -c -m 644 MPI_Info_delete.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Info_delete.html
/usr/bin/install -c -m 644 MPI_Info_dup.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Info_dup.html
/usr/bin/install -c -m 644 MPI_Info_free.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Info_free.html
/usr/bin/install -c -m 644 MPI_Info_get.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Info_get.html
/usr/bin/install -c -m 644 MPI_Info_get_nkeys.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Info_get_nkeys.html
/usr/bin/install -c -m 644 MPI_Info_get_nthkey.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Info_get_nthkey.html
/usr/bin/install -c -m 644 MPI_Info_get_valuelen.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Info_get_valuelen.html
/usr/bin/install -c -m 644 MPI_Info_set.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Info_set.html
/usr/bin/install -c -m 644 MPI_Init.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Init.html
/usr/bin/install -c -m 644 MPI_Initialized.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Initialized.html
/usr/bin/install -c -m 644 MPI_Init_thread.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Init_thread.html
/usr/bin/install -c -m 644 MPI_Intercomm_create.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Intercomm_create.html
/usr/bin/install -c -m 644 MPI_Intercomm_merge.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Intercomm_merge.html
/usr/bin/install -c -m 644 MPI_Iprobe.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Iprobe.html
/usr/bin/install -c -m 644 MPI_Irecv.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Irecv.html
/usr/bin/install -c -m 644 MPI_Irsend.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Irsend.html
/usr/bin/install -c -m 644 MPI_Isend.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Isend.html
/usr/bin/install -c -m 644 MPI_Issend.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Issend.html
/usr/bin/install -c -m 644 MPI_Is_thread_main.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Is_thread_main.html
/usr/bin/install -c -m 644 MPI_Keyval_create.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Keyval_create.html
/usr/bin/install -c -m 644 MPI_Keyval_free.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Keyval_free.html
/usr/bin/install -c -m 644 MPI_Lookup_name.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Lookup_name.html
/usr/bin/install -c -m 644 MPI_Op_commute.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Op_commute.html
/usr/bin/install -c -m 644 MPI_Op_create.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Op_create.html
/usr/bin/install -c -m 644 MPI_Open_port.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Open_port.html
/usr/bin/install -c -m 644 MPI_Op_free.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Op_free.html
/usr/bin/install -c -m 644 MPI_Pack_external.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Pack_external.html
/usr/bin/install -c -m 644 MPI_Pack_external_size.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Pack_external_size.html
/usr/bin/install -c -m 644 MPI_Pack.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Pack.html
/usr/bin/install -c -m 644 MPI_Pack_size.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Pack_size.html
/usr/bin/install -c -m 644 MPI_Pcontrol.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Pcontrol.html
/usr/bin/install -c -m 644 MPI_Probe.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Probe.html
/usr/bin/install -c -m 644 MPI_Publish_name.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Publish_name.html
/usr/bin/install -c -m 644 MPI_Put.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Put.html
/usr/bin/install -c -m 644 MPI_Query_thread.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Query_thread.html
/usr/bin/install -c -m 644 MPI_Recv.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Recv.html
/usr/bin/install -c -m 644 MPI_Recv_init.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Recv_init.html
/usr/bin/install -c -m 644 MPI_Reduce.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Reduce.html
/usr/bin/install -c -m 644 MPI_Reduce_local.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Reduce_local.html
/usr/bin/install -c -m 644 MPI_Reduce_scatter_block.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Reduce_scatter_block.html
/usr/bin/install -c -m 644 MPI_Reduce_scatter.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Reduce_scatter.html
/usr/bin/install -c -m 644 MPI_Register_datarep.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Register_datarep.html
/usr/bin/install -c -m 644 MPI_Request_free.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Request_free.html
/usr/bin/install -c -m 644 MPI_Request_get_status.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Request_get_status.html
/usr/bin/install -c -m 644 MPI_Rsend.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Rsend.html
/usr/bin/install -c -m 644 MPI_Rsend_init.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Rsend_init.html
/usr/bin/install -c -m 644 MPI_Scan.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Scan.html
/usr/bin/install -c -m 644 MPI_Scatter.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Scatter.html
/usr/bin/install -c -m 644 MPI_Scatterv.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Scatterv.html
/usr/bin/install -c -m 644 MPI_Send.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Send.html
/usr/bin/install -c -m 644 MPI_Send_init.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Send_init.html
/usr/bin/install -c -m 644 MPI_Sendrecv.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Sendrecv.html
/usr/bin/install -c -m 644 MPI_Sendrecv_replace.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Sendrecv_replace.html
/usr/bin/install -c -m 644 MPI_Ssend.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Ssend.html
/usr/bin/install -c -m 644 MPI_Ssend_init.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Ssend_init.html
/usr/bin/install -c -m 644 MPI_Startall.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Startall.html
/usr/bin/install -c -m 644 MPI_Start.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Start.html
/usr/bin/install -c -m 644 MPI_Status_set_cancelled.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Status_set_cancelled.html
/usr/bin/install -c -m 644 MPI_Status_set_elements.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Status_set_elements.html
/usr/bin/install -c -m 644 MPI_Testall.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Testall.html
/usr/bin/install -c -m 644 MPI_Testany.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Testany.html
/usr/bin/install -c -m 644 MPI_Test_cancelled.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Test_cancelled.html
/usr/bin/install -c -m 644 MPI_Test.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Test.html
/usr/bin/install -c -m 644 MPI_Testsome.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Testsome.html
/usr/bin/install -c -m 644 MPI_Topo_test.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Topo_test.html
/usr/bin/install -c -m 644 MPI_Type_commit.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_commit.html
/usr/bin/install -c -m 644 MPI_Type_contiguous.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_contiguous.html
/usr/bin/install -c -m 644 MPI_Type_create_darray.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_create_darray.html
/usr/bin/install -c -m 644 MPI_Type_create_hindexed.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_create_hindexed.html
/usr/bin/install -c -m 644 MPI_Type_create_hvector.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_create_hvector.html
/usr/bin/install -c -m 644 MPI_Type_create_indexed_block.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_create_indexed_block.html
/usr/bin/install -c -m 644 MPI_Type_create_keyval.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_create_keyval.html
/usr/bin/install -c -m 644 MPI_Type_create_resized.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_create_resized.html
/usr/bin/install -c -m 644 MPI_Type_create_struct.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_create_struct.html
/usr/bin/install -c -m 644 MPI_Type_create_subarray.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_create_subarray.html
/usr/bin/install -c -m 644 MPI_Type_delete_attr.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_delete_attr.html
/usr/bin/install -c -m 644 MPI_Type_dup.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_dup.html
/usr/bin/install -c -m 644 MPI_Type_extent.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_extent.html
/usr/bin/install -c -m 644 MPI_Type_free.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_free.html
/usr/bin/install -c -m 644 MPI_Type_free_keyval.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_free_keyval.html
/usr/bin/install -c -m 644 MPI_Type_get_attr.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_get_attr.html
/usr/bin/install -c -m 644 MPI_Type_get_contents.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_get_contents.html
/usr/bin/install -c -m 644 MPI_Type_get_envelope.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_get_envelope.html
/usr/bin/install -c -m 644 MPI_Type_get_extent.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_get_extent.html
/usr/bin/install -c -m 644 MPI_Type_get_name.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_get_name.html
/usr/bin/install -c -m 644 MPI_Type_get_true_extent.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_get_true_extent.html
/usr/bin/install -c -m 644 MPI_Type_hindexed.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_hindexed.html
/usr/bin/install -c -m 644 MPI_Type_hvector.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_hvector.html
/usr/bin/install -c -m 644 MPI_Type_indexed.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_indexed.html
/usr/bin/install -c -m 644 MPI_Type_lb.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_lb.html
/usr/bin/install -c -m 644 MPI_Type_match_size.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_match_size.html
/usr/bin/install -c -m 644 MPI_Type_set_attr.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_set_attr.html
/usr/bin/install -c -m 644 MPI_Type_set_name.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_set_name.html
/usr/bin/install -c -m 644 MPI_Type_size.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_size.html
/usr/bin/install -c -m 644 MPI_Type_struct.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_struct.html
/usr/bin/install -c -m 644 MPI_Type_ub.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_ub.html
/usr/bin/install -c -m 644 MPI_Type_vector.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Type_vector.html
/usr/bin/install -c -m 644 MPI_Unpack_external.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Unpack_external.html
/usr/bin/install -c -m 644 MPI_Unpack.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Unpack.html
/usr/bin/install -c -m 644 MPI_Unpublish_name.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Unpublish_name.html
/usr/bin/install -c -m 644 MPI_Waitall.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Waitall.html
/usr/bin/install -c -m 644 MPI_Waitany.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Waitany.html
/usr/bin/install -c -m 644 MPI_Wait.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Wait.html
/usr/bin/install -c -m 644 MPI_Waitsome.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Waitsome.html
/usr/bin/install -c -m 644 MPI_Win_call_errhandler.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_call_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_complete.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_complete.html
/usr/bin/install -c -m 644 MPI_Win_create_errhandler.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_create_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_create.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_create.html
/usr/bin/install -c -m 644 MPI_Win_create_keyval.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_create_keyval.html
/usr/bin/install -c -m 644 MPI_Win_delete_attr.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_delete_attr.html
/usr/bin/install -c -m 644 MPI_Win_fence.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_fence.html
/usr/bin/install -c -m 644 MPI_Win_free.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_free.html
/usr/bin/install -c -m 644 MPI_Win_free_keyval.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_free_keyval.html
/usr/bin/install -c -m 644 MPI_Win_get_attr.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_get_attr.html
/usr/bin/install -c -m 644 MPI_Win_get_errhandler.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_get_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_get_group.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_get_group.html
/usr/bin/install -c -m 644 MPI_Win_get_name.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_get_name.html
/usr/bin/install -c -m 644 MPI_Win_lock.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_lock.html
/usr/bin/install -c -m 644 MPI_Win_post.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_post.html
/usr/bin/install -c -m 644 MPI_Win_set_attr.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_set_attr.html
/usr/bin/install -c -m 644 MPI_Win_set_errhandler.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_set_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_set_name.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_set_name.html
/usr/bin/install -c -m 644 MPI_Win_start.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_start.html
/usr/bin/install -c -m 644 MPI_Win_test.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_test.html
/usr/bin/install -c -m 644 MPI_Win_unlock.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_unlock.html
/usr/bin/install -c -m 644 MPI_Win_wait.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Win_wait.html
/usr/bin/install -c -m 644 MPI_Wtick.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Wtick.html
/usr/bin/install -c -m 644 MPI_Wtime.html /home/bgarrison/mpich2-install/share/doc//www3/MPI_Wtime.html
/usr/bin/install -c -m 644 mpd.1 /home/bgarrison/mpich2-install/share/man/man1/mpd.1
/usr/bin/install -c -m 644 mpdallexit.1 /home/bgarrison/mpich2-install/share/man/man1/mpdallexit.1
/usr/bin/install -c -m 644 mpdboot.1 /home/bgarrison/mpich2-install/share/man/man1/mpdboot.1
/usr/bin/install -c -m 644 mpdcheck.1 /home/bgarrison/mpich2-install/share/man/man1/mpdcheck.1
/usr/bin/install -c -m 644 mpdchkpyver.1 /home/bgarrison/mpich2-install/share/man/man1/mpdchkpyver.1
/usr/bin/install -c -m 644 mpdcleanup.1 /home/bgarrison/mpich2-install/share/man/man1/mpdcleanup.1
/usr/bin/install -c -m 644 mpdexit.1 /home/bgarrison/mpich2-install/share/man/man1/mpdexit.1
/usr/bin/install -c -m 644 mpdgdbdrv.1 /home/bgarrison/mpich2-install/share/man/man1/mpdgdbdrv.1
/usr/bin/install -c -m 644 mpdhelp.1 /home/bgarrison/mpich2-install/share/man/man1/mpdhelp.1
/usr/bin/install -c -m 644 mpdkilljob.1 /home/bgarrison/mpich2-install/share/man/man1/mpdkilljob.1
/usr/bin/install -c -m 644 mpdlib.1 /home/bgarrison/mpich2-install/share/man/man1/mpdlib.1
/usr/bin/install -c -m 644 mpdlistjobs.1 /home/bgarrison/mpich2-install/share/man/man1/mpdlistjobs.1
/usr/bin/install -c -m 644 mpdman.1 /home/bgarrison/mpich2-install/share/man/man1/mpdman.1
/usr/bin/install -c -m 644 mpdringtest.1 /home/bgarrison/mpich2-install/share/man/man1/mpdringtest.1
/usr/bin/install -c -m 644 mpdsigjob.1 /home/bgarrison/mpich2-install/share/man/man1/mpdsigjob.1
/usr/bin/install -c -m 644 mpdtrace.1 /home/bgarrison/mpich2-install/share/man/man1/mpdtrace.1
/usr/bin/install -c -m 644 MPI.1 /home/bgarrison/mpich2-install/share/man/man1/MPI.1
/usr/bin/install -c -m 644 mpicc.1 /home/bgarrison/mpich2-install/share/man/man1/mpicc.1
/usr/bin/install -c -m 644 mpicxx.1 /home/bgarrison/mpich2-install/share/man/man1/mpicxx.1
/usr/bin/install -c -m 644 mpiexec.1 /home/bgarrison/mpich2-install/share/man/man1/mpiexec.1
/usr/bin/install -c -m 644 mpif77.1 /home/bgarrison/mpich2-install/share/man/man1/mpif77.1
/usr/bin/install -c -m 644 mpif90.1 /home/bgarrison/mpich2-install/share/man/man1/mpif90.1
/usr/bin/install -c -m 644 Zeroconf.1 /home/bgarrison/mpich2-install/share/man/man1/Zeroconf.1
/usr/bin/install -c -m 644 MPI_Abort.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Abort.3
/usr/bin/install -c -m 644 MPI_Accumulate.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Accumulate.3
/usr/bin/install -c -m 644 MPI_Add_error_class.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Add_error_class.3
/usr/bin/install -c -m 644 MPI_Add_error_code.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Add_error_code.3
/usr/bin/install -c -m 644 MPI_Add_error_string.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Add_error_string.3
/usr/bin/install -c -m 644 MPI_Address.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Address.3
/usr/bin/install -c -m 644 MPI_Allgather.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Allgather.3
/usr/bin/install -c -m 644 MPI_Allgatherv.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Allgatherv.3
/usr/bin/install -c -m 644 MPI_Alloc_mem.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Alloc_mem.3
/usr/bin/install -c -m 644 MPI_Allreduce.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Allreduce.3
/usr/bin/install -c -m 644 MPI_Alltoall.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Alltoall.3
/usr/bin/install -c -m 644 MPI_Alltoallv.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Alltoallv.3
/usr/bin/install -c -m 644 MPI_Alltoallw.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Alltoallw.3
/usr/bin/install -c -m 644 MPI_Attr_delete.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Attr_delete.3
/usr/bin/install -c -m 644 MPI_Attr_get.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Attr_get.3
/usr/bin/install -c -m 644 MPI_Attr_put.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Attr_put.3
/usr/bin/install -c -m 644 MPI_Barrier.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Barrier.3
/usr/bin/install -c -m 644 MPI_Bcast.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Bcast.3
/usr/bin/install -c -m 644 MPI_Bsend.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Bsend.3
/usr/bin/install -c -m 644 MPI_Bsend_init.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Bsend_init.3
/usr/bin/install -c -m 644 MPI_Buffer_attach.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Buffer_attach.3
/usr/bin/install -c -m 644 MPI_Buffer_detach.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Buffer_detach.3
/usr/bin/install -c -m 644 MPI_Cancel.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Cancel.3
/usr/bin/install -c -m 644 MPI_Cart_coords.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Cart_coords.3
/usr/bin/install -c -m 644 MPI_Cart_create.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Cart_create.3
/usr/bin/install -c -m 644 MPI_Cartdim_get.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Cartdim_get.3
/usr/bin/install -c -m 644 MPI_Cart_get.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Cart_get.3
/usr/bin/install -c -m 644 MPI_Cart_map.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Cart_map.3
/usr/bin/install -c -m 644 MPI_Cart_rank.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Cart_rank.3
/usr/bin/install -c -m 644 MPI_Cart_shift.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Cart_shift.3
/usr/bin/install -c -m 644 MPI_Cart_sub.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Cart_sub.3
/usr/bin/install -c -m 644 MPI_Close_port.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Close_port.3
/usr/bin/install -c -m 644 MPI_Comm_accept.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_accept.3
/usr/bin/install -c -m 644 MPI_Comm_call_errhandler.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_call_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_compare.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_compare.3
/usr/bin/install -c -m 644 MPI_Comm_connect.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_connect.3
/usr/bin/install -c -m 644 MPI_Comm_create.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_create.3
/usr/bin/install -c -m 644 MPI_Comm_create_errhandler.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_create_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_create_keyval.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_create_keyval.3
/usr/bin/install -c -m 644 MPI_Comm_delete_attr.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_delete_attr.3
/usr/bin/install -c -m 644 MPI_Comm_disconnect.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_disconnect.3
/usr/bin/install -c -m 644 MPI_Comm_dup.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_dup.3
/usr/bin/install -c -m 644 MPI_Comm_free.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_free.3
/usr/bin/install -c -m 644 MPI_Comm_free_keyval.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_free_keyval.3
/usr/bin/install -c -m 644 MPI_Comm_get_attr.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_get_attr.3
/usr/bin/install -c -m 644 MPI_Comm_get_errhandler.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_get_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_get_name.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_get_name.3
/usr/bin/install -c -m 644 MPI_Comm_get_parent.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_get_parent.3
/usr/bin/install -c -m 644 MPI_Comm_group.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_group.3
/usr/bin/install -c -m 644 MPI_Comm_join.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_join.3
/usr/bin/install -c -m 644 MPI_Comm_rank.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_rank.3
/usr/bin/install -c -m 644 MPI_Comm_remote_group.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_remote_group.3
/usr/bin/install -c -m 644 MPI_Comm_remote_size.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_remote_size.3
/usr/bin/install -c -m 644 MPI_Comm_set_attr.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_set_attr.3
/usr/bin/install -c -m 644 MPI_Comm_set_errhandler.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_set_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_set_name.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_set_name.3
/usr/bin/install -c -m 644 MPI_Comm_size.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_size.3
/usr/bin/install -c -m 644 MPI_Comm_spawn.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_spawn.3
/usr/bin/install -c -m 644 MPI_Comm_spawn_multiple.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_spawn_multiple.3
/usr/bin/install -c -m 644 MPI_Comm_split.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_split.3
/usr/bin/install -c -m 644 MPI_Comm_test_inter.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Comm_test_inter.3
/usr/bin/install -c -m 644 MPI_Dims_create.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Dims_create.3
/usr/bin/install -c -m 644 MPI_Dist_graph_create.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Dist_graph_create.3
/usr/bin/install -c -m 644 MPI_Dist_graph_create_adjacent.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Dist_graph_create_adjacent.3
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Dist_graph_neighbors.3
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors_count.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Dist_graph_neighbors_count.3
/usr/bin/install -c -m 644 MPI_Errhandler_create.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Errhandler_create.3
/usr/bin/install -c -m 644 MPI_Errhandler_free.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Errhandler_free.3
/usr/bin/install -c -m 644 MPI_Errhandler_get.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Errhandler_get.3
/usr/bin/install -c -m 644 MPI_Errhandler_set.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Errhandler_set.3
/usr/bin/install -c -m 644 MPI_Error_class.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Error_class.3
/usr/bin/install -c -m 644 MPI_Error_string.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Error_string.3
/usr/bin/install -c -m 644 MPI_Exscan.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Exscan.3
/usr/bin/install -c -m 644 MPI_File_c2f.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_c2f.3
/usr/bin/install -c -m 644 MPI_File_call_errhandler.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_call_errhandler.3
/usr/bin/install -c -m 644 MPI_File_close.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_close.3
/usr/bin/install -c -m 644 MPI_File_create_errhandler.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_create_errhandler.3
/usr/bin/install -c -m 644 MPI_File_delete.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_delete.3
/usr/bin/install -c -m 644 MPI_File_f2c.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_f2c.3
/usr/bin/install -c -m 644 MPI_File_get_amode.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_get_amode.3
/usr/bin/install -c -m 644 MPI_File_get_atomicity.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_get_atomicity.3
/usr/bin/install -c -m 644 MPI_File_get_byte_offset.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_get_byte_offset.3
/usr/bin/install -c -m 644 MPI_File_get_errhandler.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_get_errhandler.3
/usr/bin/install -c -m 644 MPI_File_get_group.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_get_group.3
/usr/bin/install -c -m 644 MPI_File_get_info.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_get_info.3
/usr/bin/install -c -m 644 MPI_File_get_position.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_get_position.3
/usr/bin/install -c -m 644 MPI_File_get_position_shared.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_get_position_shared.3
/usr/bin/install -c -m 644 MPI_File_get_size.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_get_size.3
/usr/bin/install -c -m 644 MPI_File_get_type_extent.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_get_type_extent.3
/usr/bin/install -c -m 644 MPI_File_get_view.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_get_view.3
/usr/bin/install -c -m 644 MPI_File_iread.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_iread.3
/usr/bin/install -c -m 644 MPI_File_iread_at.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_iread_at.3
/usr/bin/install -c -m 644 MPI_File_iread_shared.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_iread_shared.3
/usr/bin/install -c -m 644 MPI_File_iwrite.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_iwrite.3
/usr/bin/install -c -m 644 MPI_File_iwrite_at.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_iwrite_at.3
/usr/bin/install -c -m 644 MPI_File_iwrite_shared.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_iwrite_shared.3
/usr/bin/install -c -m 644 MPI_File_open.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_open.3
/usr/bin/install -c -m 644 MPI_File_preallocate.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_preallocate.3
/usr/bin/install -c -m 644 MPI_File_read.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_read.3
/usr/bin/install -c -m 644 MPI_File_read_all.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_read_all.3
/usr/bin/install -c -m 644 MPI_File_read_all_begin.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_read_all_begin.3
/usr/bin/install -c -m 644 MPI_File_read_all_end.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_read_all_end.3
/usr/bin/install -c -m 644 MPI_File_read_at.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_read_at.3
/usr/bin/install -c -m 644 MPI_File_read_at_all.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_read_at_all.3
/usr/bin/install -c -m 644 MPI_File_read_at_all_begin.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_read_at_all_begin.3
/usr/bin/install -c -m 644 MPI_File_read_at_all_end.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_read_at_all_end.3
/usr/bin/install -c -m 644 MPI_File_read_ordered.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_read_ordered.3
/usr/bin/install -c -m 644 MPI_File_read_ordered_begin.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_read_ordered_begin.3
/usr/bin/install -c -m 644 MPI_File_read_ordered_end.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_read_ordered_end.3
/usr/bin/install -c -m 644 MPI_File_read_shared.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_read_shared.3
/usr/bin/install -c -m 644 MPI_File_seek.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_seek.3
/usr/bin/install -c -m 644 MPI_File_seek_shared.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_seek_shared.3
/usr/bin/install -c -m 644 MPI_File_set_atomicity.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_set_atomicity.3
/usr/bin/install -c -m 644 MPI_File_set_errhandler.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_set_errhandler.3
/usr/bin/install -c -m 644 MPI_File_set_info.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_set_info.3
/usr/bin/install -c -m 644 MPI_File_set_size.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_set_size.3
/usr/bin/install -c -m 644 MPI_File_set_view.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_set_view.3
/usr/bin/install -c -m 644 MPI_File_sync.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_sync.3
/usr/bin/install -c -m 644 MPI_File_write.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_write.3
/usr/bin/install -c -m 644 MPI_File_write_all.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_write_all.3
/usr/bin/install -c -m 644 MPI_File_write_all_begin.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_write_all_begin.3
/usr/bin/install -c -m 644 MPI_File_write_all_end.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_write_all_end.3
/usr/bin/install -c -m 644 MPI_File_write_at.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_write_at.3
/usr/bin/install -c -m 644 MPI_File_write_at_all.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_write_at_all.3
/usr/bin/install -c -m 644 MPI_File_write_at_all_begin.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_write_at_all_begin.3
/usr/bin/install -c -m 644 MPI_File_write_at_all_end.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_write_at_all_end.3
/usr/bin/install -c -m 644 MPI_File_write_ordered.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_write_ordered.3
/usr/bin/install -c -m 644 MPI_File_write_ordered_begin.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_write_ordered_begin.3
/usr/bin/install -c -m 644 MPI_File_write_ordered_end.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_write_ordered_end.3
/usr/bin/install -c -m 644 MPI_File_write_shared.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_File_write_shared.3
/usr/bin/install -c -m 644 MPI_Finalize.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Finalize.3
/usr/bin/install -c -m 644 MPI_Finalized.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Finalized.3
/usr/bin/install -c -m 644 MPI_Free_mem.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Free_mem.3
/usr/bin/install -c -m 644 MPI_Gather.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Gather.3
/usr/bin/install -c -m 644 MPI_Gatherv.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Gatherv.3
/usr/bin/install -c -m 644 MPI_Get.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Get.3
/usr/bin/install -c -m 644 MPI_Get_address.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Get_address.3
/usr/bin/install -c -m 644 MPI_Get_count.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Get_count.3
/usr/bin/install -c -m 644 MPI_Get_elements.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Get_elements.3
/usr/bin/install -c -m 644 MPI_Get_processor_name.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Get_processor_name.3
/usr/bin/install -c -m 644 MPI_Get_version.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Get_version.3
/usr/bin/install -c -m 644 MPI_Graph_create.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Graph_create.3
/usr/bin/install -c -m 644 MPI_Graphdims_get.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Graphdims_get.3
/usr/bin/install -c -m 644 MPI_Graph_get.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Graph_get.3
/usr/bin/install -c -m 644 MPI_Graph_map.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Graph_map.3
/usr/bin/install -c -m 644 MPI_Graph_neighbors.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Graph_neighbors.3
/usr/bin/install -c -m 644 MPI_Graph_neighbors_count.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Graph_neighbors_count.3
/usr/bin/install -c -m 644 MPI_Grequest_complete.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Grequest_complete.3
/usr/bin/install -c -m 644 MPI_Grequest_start.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Grequest_start.3
/usr/bin/install -c -m 644 MPI_Group_compare.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Group_compare.3
/usr/bin/install -c -m 644 MPI_Group_difference.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Group_difference.3
/usr/bin/install -c -m 644 MPI_Group_excl.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Group_excl.3
/usr/bin/install -c -m 644 MPI_Group_free.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Group_free.3
/usr/bin/install -c -m 644 MPI_Group_incl.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Group_incl.3
/usr/bin/install -c -m 644 MPI_Group_intersection.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Group_intersection.3
/usr/bin/install -c -m 644 MPI_Group_range_excl.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Group_range_excl.3
/usr/bin/install -c -m 644 MPI_Group_range_incl.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Group_range_incl.3
/usr/bin/install -c -m 644 MPI_Group_rank.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Group_rank.3
/usr/bin/install -c -m 644 MPI_Group_size.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Group_size.3
/usr/bin/install -c -m 644 MPI_Group_translate_ranks.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Group_translate_ranks.3
/usr/bin/install -c -m 644 MPI_Group_union.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Group_union.3
/usr/bin/install -c -m 644 MPI_Ibsend.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Ibsend.3
/usr/bin/install -c -m 644 MPI_Info_create.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Info_create.3
/usr/bin/install -c -m 644 MPI_Info_delete.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Info_delete.3
/usr/bin/install -c -m 644 MPI_Info_dup.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Info_dup.3
/usr/bin/install -c -m 644 MPI_Info_free.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Info_free.3
/usr/bin/install -c -m 644 MPI_Info_get.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Info_get.3
/usr/bin/install -c -m 644 MPI_Info_get_nkeys.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Info_get_nkeys.3
/usr/bin/install -c -m 644 MPI_Info_get_nthkey.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Info_get_nthkey.3
/usr/bin/install -c -m 644 MPI_Info_get_valuelen.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Info_get_valuelen.3
/usr/bin/install -c -m 644 MPI_Info_set.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Info_set.3
/usr/bin/install -c -m 644 MPI_Init.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Init.3
/usr/bin/install -c -m 644 MPI_Initialized.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Initialized.3
/usr/bin/install -c -m 644 MPI_Init_thread.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Init_thread.3
/usr/bin/install -c -m 644 MPI_Intercomm_create.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Intercomm_create.3
/usr/bin/install -c -m 644 MPI_Intercomm_merge.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Intercomm_merge.3
/usr/bin/install -c -m 644 MPI_Iprobe.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Iprobe.3
/usr/bin/install -c -m 644 MPI_Irecv.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Irecv.3
/usr/bin/install -c -m 644 MPI_Irsend.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Irsend.3
/usr/bin/install -c -m 644 MPI_Isend.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Isend.3
/usr/bin/install -c -m 644 MPI_Issend.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Issend.3
/usr/bin/install -c -m 644 MPI_Is_thread_main.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Is_thread_main.3
/usr/bin/install -c -m 644 MPI_Keyval_create.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Keyval_create.3
/usr/bin/install -c -m 644 MPI_Keyval_free.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Keyval_free.3
/usr/bin/install -c -m 644 MPI_Lookup_name.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Lookup_name.3
/usr/bin/install -c -m 644 MPI_Op_commute.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Op_commute.3
/usr/bin/install -c -m 644 MPI_Op_create.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Op_create.3
/usr/bin/install -c -m 644 MPI_Open_port.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Open_port.3
/usr/bin/install -c -m 644 MPI_Op_free.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Op_free.3
/usr/bin/install -c -m 644 MPI_Pack.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Pack.3
/usr/bin/install -c -m 644 MPI_Pack_external.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Pack_external.3
/usr/bin/install -c -m 644 MPI_Pack_external_size.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Pack_external_size.3
/usr/bin/install -c -m 644 MPI_Pack_size.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Pack_size.3
/usr/bin/install -c -m 644 MPI_Pcontrol.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Pcontrol.3
/usr/bin/install -c -m 644 MPI_Probe.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Probe.3
/usr/bin/install -c -m 644 MPI_Publish_name.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Publish_name.3
/usr/bin/install -c -m 644 MPI_Put.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Put.3
/usr/bin/install -c -m 644 MPI_Query_thread.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Query_thread.3
/usr/bin/install -c -m 644 MPI_Recv.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Recv.3
/usr/bin/install -c -m 644 MPI_Recv_init.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Recv_init.3
/usr/bin/install -c -m 644 MPI_Reduce.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Reduce.3
/usr/bin/install -c -m 644 MPI_Reduce_local.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Reduce_local.3
/usr/bin/install -c -m 644 MPI_Reduce_scatter.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Reduce_scatter.3
/usr/bin/install -c -m 644 MPI_Reduce_scatter_block.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Reduce_scatter_block.3
/usr/bin/install -c -m 644 MPI_Register_datarep.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Register_datarep.3
/usr/bin/install -c -m 644 MPI_Request_free.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Request_free.3
/usr/bin/install -c -m 644 MPI_Request_get_status.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Request_get_status.3
/usr/bin/install -c -m 644 MPI_Rsend.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Rsend.3
/usr/bin/install -c -m 644 MPI_Rsend_init.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Rsend_init.3
/usr/bin/install -c -m 644 MPI_Scan.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Scan.3
/usr/bin/install -c -m 644 MPI_Scatter.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Scatter.3
/usr/bin/install -c -m 644 MPI_Scatterv.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Scatterv.3
/usr/bin/install -c -m 644 MPI_Send.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Send.3
/usr/bin/install -c -m 644 MPI_Send_init.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Send_init.3
/usr/bin/install -c -m 644 MPI_Sendrecv.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Sendrecv.3
/usr/bin/install -c -m 644 MPI_Sendrecv_replace.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Sendrecv_replace.3
/usr/bin/install -c -m 644 MPI_Ssend.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Ssend.3
/usr/bin/install -c -m 644 MPI_Ssend_init.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Ssend_init.3
/usr/bin/install -c -m 644 MPI_Start.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Start.3
/usr/bin/install -c -m 644 MPI_Startall.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Startall.3
/usr/bin/install -c -m 644 MPI_Status_set_cancelled.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Status_set_cancelled.3
/usr/bin/install -c -m 644 MPI_Status_set_elements.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Status_set_elements.3
/usr/bin/install -c -m 644 MPI_Test.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Test.3
/usr/bin/install -c -m 644 MPI_Testall.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Testall.3
/usr/bin/install -c -m 644 MPI_Testany.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Testany.3
/usr/bin/install -c -m 644 MPI_Test_cancelled.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Test_cancelled.3
/usr/bin/install -c -m 644 MPI_Testsome.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Testsome.3
/usr/bin/install -c -m 644 MPI_Topo_test.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Topo_test.3
/usr/bin/install -c -m 644 MPI_Type_commit.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_commit.3
/usr/bin/install -c -m 644 MPI_Type_contiguous.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_contiguous.3
/usr/bin/install -c -m 644 MPI_Type_create_darray.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_create_darray.3
/usr/bin/install -c -m 644 MPI_Type_create_hindexed.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_create_hindexed.3
/usr/bin/install -c -m 644 MPI_Type_create_hvector.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_create_hvector.3
/usr/bin/install -c -m 644 MPI_Type_create_indexed_block.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_create_indexed_block.3
/usr/bin/install -c -m 644 MPI_Type_create_keyval.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_create_keyval.3
/usr/bin/install -c -m 644 MPI_Type_create_resized.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_create_resized.3
/usr/bin/install -c -m 644 MPI_Type_create_struct.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_create_struct.3
/usr/bin/install -c -m 644 MPI_Type_create_subarray.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_create_subarray.3
/usr/bin/install -c -m 644 MPI_Type_delete_attr.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_delete_attr.3
/usr/bin/install -c -m 644 MPI_Type_dup.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_dup.3
/usr/bin/install -c -m 644 MPI_Type_extent.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_extent.3
/usr/bin/install -c -m 644 MPI_Type_free.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_free.3
/usr/bin/install -c -m 644 MPI_Type_free_keyval.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_free_keyval.3
/usr/bin/install -c -m 644 MPI_Type_get_attr.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_get_attr.3
/usr/bin/install -c -m 644 MPI_Type_get_contents.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_get_contents.3
/usr/bin/install -c -m 644 MPI_Type_get_envelope.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_get_envelope.3
/usr/bin/install -c -m 644 MPI_Type_get_extent.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_get_extent.3
/usr/bin/install -c -m 644 MPI_Type_get_name.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_get_name.3
/usr/bin/install -c -m 644 MPI_Type_get_true_extent.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_get_true_extent.3
/usr/bin/install -c -m 644 MPI_Type_hindexed.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_hindexed.3
/usr/bin/install -c -m 644 MPI_Type_hvector.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_hvector.3
/usr/bin/install -c -m 644 MPI_Type_indexed.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_indexed.3
/usr/bin/install -c -m 644 MPI_Type_lb.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_lb.3
/usr/bin/install -c -m 644 MPI_Type_match_size.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_match_size.3
/usr/bin/install -c -m 644 MPI_Type_set_attr.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_set_attr.3
/usr/bin/install -c -m 644 MPI_Type_set_name.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_set_name.3
/usr/bin/install -c -m 644 MPI_Type_size.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_size.3
/usr/bin/install -c -m 644 MPI_Type_struct.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_struct.3
/usr/bin/install -c -m 644 MPI_Type_ub.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_ub.3
/usr/bin/install -c -m 644 MPI_Type_vector.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Type_vector.3
/usr/bin/install -c -m 644 MPI_Unpack.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Unpack.3
/usr/bin/install -c -m 644 MPI_Unpack_external.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Unpack_external.3
/usr/bin/install -c -m 644 MPI_Unpublish_name.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Unpublish_name.3
/usr/bin/install -c -m 644 MPI_Wait.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Wait.3
/usr/bin/install -c -m 644 MPI_Waitall.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Waitall.3
/usr/bin/install -c -m 644 MPI_Waitany.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Waitany.3
/usr/bin/install -c -m 644 MPI_Waitsome.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Waitsome.3
/usr/bin/install -c -m 644 MPI_Win_call_errhandler.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_call_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_complete.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_complete.3
/usr/bin/install -c -m 644 MPI_Win_create.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_create.3
/usr/bin/install -c -m 644 MPI_Win_create_errhandler.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_create_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_create_keyval.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_create_keyval.3
/usr/bin/install -c -m 644 MPI_Win_delete_attr.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_delete_attr.3
/usr/bin/install -c -m 644 MPI_Win_fence.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_fence.3
/usr/bin/install -c -m 644 MPI_Win_free.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_free.3
/usr/bin/install -c -m 644 MPI_Win_free_keyval.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_free_keyval.3
/usr/bin/install -c -m 644 MPI_Win_get_attr.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_get_attr.3
/usr/bin/install -c -m 644 MPI_Win_get_errhandler.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_get_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_get_group.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_get_group.3
/usr/bin/install -c -m 644 MPI_Win_get_name.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_get_name.3
/usr/bin/install -c -m 644 MPI_Win_lock.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_lock.3
/usr/bin/install -c -m 644 MPI_Win_post.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_post.3
/usr/bin/install -c -m 644 MPI_Win_set_attr.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_set_attr.3
/usr/bin/install -c -m 644 MPI_Win_set_errhandler.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_set_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_set_name.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_set_name.3
/usr/bin/install -c -m 644 MPI_Win_start.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_start.3
/usr/bin/install -c -m 644 MPI_Win_test.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_test.3
/usr/bin/install -c -m 644 MPI_Win_unlock.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_unlock.3
/usr/bin/install -c -m 644 MPI_Win_wait.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Win_wait.3
/usr/bin/install -c -m 644 MPI_Wtick.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Wtick.3
/usr/bin/install -c -m 644 MPI_Wtime.3 /home/bgarrison/mpich2-install/share/man/man3/MPI_Wtime.3
if [ -s src/mpi/romio/include/mpiof.h ] ; then /usr/bin/install -c -m 644 src/mpi/romio/include/mpiof.h /home/bgarrison/mpich2-install/include/mpiof.h ; fi
if [ -s src/mpi/romio/include/mpio.h ] ; then /usr/bin/install -c -m 644 src/mpi/romio/include/mpio.h /home/bgarrison/mpich2-install/include/mpio.h ; fi
if [ -s lib/libmpich.a ] ; then /usr/bin/install -c -m 644 lib/libmpich.a /home/bgarrison/mpich2-install/lib/libmpich.a ; fi
if [ -s lib/libmpichcxx.a ] ; then /usr/bin/install -c -m 644 lib/libmpichcxx.a /home/bgarrison/mpich2-install/lib/libmpichcxx.a ; fi
if [ -s lib/libfmpich.a ] ; then /usr/bin/install -c -m 644 lib/libfmpich.a /home/bgarrison/mpich2-install/lib/libfmpich.a ; fi
if [ -s lib/libpmpich.a ] ; then /usr/bin/install -c -m 644 lib/libpmpich.a /home/bgarrison/mpich2-install/lib/libpmpich.a ; fi
if [ -s lib/libmpichf90.a ] ; then /usr/bin/install -c -m 644 lib/libmpichf90.a /home/bgarrison/mpich2-install/lib/libmpichf90.a ; fi
if [ -s lib/libmpich.so ] ; then false -version-info 1:2 --mode=install lib/libmpich.so /home/bgarrison/mpich2-install/lib/libmpich.so ; fi
if [ -s lib/libpmpich.so ] ; then false -version-info 1:2 --mode=install lib/libpmpich.so /home/bgarrison/mpich2-install/lib/libpmpich.so ; fi
if [ -s lib/libfmpich.so ] ; then false -version-info 1:2 --mode=install lib/libfmpich.so /home/bgarrison/mpich2-install/lib/libfmpich.so ; fi
if [ -s lib/libmpichf90.so ] ; then false -version-info 1:2 --mode=install lib/libmpichf90.so /home/bgarrison/mpich2-install/lib/libmpichf90.so ; fi
if [ -s lib/libmpichcxx.so ] ; then false -version-info 1:2 --mode=install lib/libmpichcxx.so /home/bgarrison/mpich2-install/lib/libmpichcxx.so ; fi
if [ -s /home/bgarrison/libraries/mpich2-1.2.1/doc/userguide/user.pdf ] ; then /usr/bin/install -c -m 644 /home/bgarrison/libraries/mpich2-1.2.1/doc/userguide/user.pdf /home/bgarrison/mpich2-install/share/doc//user.pdf ; fi
if [ -s /home/bgarrison/libraries/mpich2-1.2.1/doc/installguide/install.pdf ] ; then /usr/bin/install -c -m 644 /home/bgarrison/libraries/mpich2-1.2.1/doc/installguide/install.pdf /home/bgarrison/mpich2-install/share/doc//install.pdf ; fi
if [ -s /home/bgarrison/libraries/mpich2-1.2.1/doc/smpd/smpd_pmi.pdf ] ; then /usr/bin/install -c -m 644 /home/bgarrison/libraries/mpich2-1.2.1/doc/smpd/smpd_pmi.pdf /home/bgarrison/mpich2-install/share/doc//smpd_pmi.pdf ; fi
if [ -s /home/bgarrison/libraries/mpich2-1.2.1/doc/logging/logging.pdf ] ; then /usr/bin/install -c -m 644 /home/bgarrison/libraries/mpich2-1.2.1/doc/logging/logging.pdf /home/bgarrison/mpich2-install/share/doc//logging.pdf ; fi
(cd src/env && make INSTALL_STRIP_FLAG= install)
make[1]: Entering directory `/home/bgarrison/mpich2-build/src/env'
if [ ! -d /home/bgarrison/mpich2-install ] ; then mkdir -p /home/bgarrison/mpich2-install ; fi
if [ ! -d /home/bgarrison/mpich2-install/bin ] ; then mkdir -p /home/bgarrison/mpich2-install/bin ; fi
/usr/bin/install -c  mpich2version /home/bgarrison/mpich2-install/bin/mpich2version
/usr/bin/install -c mpicc /home/bgarrison/mpich2-install/bin/mpicc
/usr/bin/install -c parkill /home/bgarrison/mpich2-install/bin/parkill
if [ ! -d /home/bgarrison/mpich2-install/etc ] ; then mkdir -p /home/bgarrison/mpich2-install/etc ; fi
/usr/bin/install -c -m 644 mpixxx_opts.conf /home/bgarrison/mpich2-install/etc/mpixxx_opts.conf
/usr/bin/install -c -m 644 mpicc.conf /home/bgarrison/mpich2-install/etc/mpicc.conf
if [ -s mpicxx ] ; then /usr/bin/install -c mpicxx /home/bgarrison/mpich2-install/bin/mpicxx ; fi
if [ -s mpif77 ] ; then /usr/bin/install -c mpif77 /home/bgarrison/mpich2-install/bin/mpif77 ; fi
if [ -s mpif90 ] ; then /usr/bin/install -c mpif90 /home/bgarrison/mpich2-install/bin/mpif90 ; fi
if [ -s mpicxx.conf ] ; then /usr/bin/install -c -m 644 mpicxx.conf /home/bgarrison/mpich2-install/etc/mpicxx.conf ; fi
if [ -s mpif77.conf ] ; then /usr/bin/install -c -m 644 mpif77.conf /home/bgarrison/mpich2-install/etc/mpif77.conf ; fi
if [ -s mpif90.conf ] ; then /usr/bin/install -c -m 644 mpif90.conf /home/bgarrison/mpich2-install/etc/mpif90.conf ; fi
make install-postamble
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/env'
if [ -x /home/bgarrison/mpich2-install/bin/mpicxx ] ; then \
	    cd /home/bgarrison/mpich2-install/bin && ln -sf mpicxx mpic++ ; fi
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/env'
make[1]: Leaving directory `/home/bgarrison/mpich2-build/src/env'
(cd src/packaging/pkgconfig && make INSTALL_STRIP_FLAG= install)
make[1]: Entering directory `/home/bgarrison/mpich2-build/src/packaging/pkgconfig'
if [ ! -d /home/bgarrison/mpich2-install/lib/pkgconfig ] ; then mkdir -p /home/bgarrison/mpich2-install/lib/pkgconfig ; fi
if [ -s mpich2-ch3.pc ] ; then /usr/bin/install -c -m 644 mpich2-ch3.pc /home/bgarrison/mpich2-install/lib/pkgconfig/mpich2-ch3.pc ; fi
make[1]: Leaving directory `/home/bgarrison/mpich2-build/src/packaging/pkgconfig'
(cd src/packaging/envmods && make INSTALL_STRIP_FLAG= install)
make[1]: Entering directory `/home/bgarrison/mpich2-build/src/packaging/envmods'
make[1]: Leaving directory `/home/bgarrison/mpich2-build/src/packaging/envmods'
for dir in  src/binding/cxx - ; do \
		if [ "$dir" = "-" ] ; then break ; fi ;\
		(cd $dir && make INSTALL_STRIP_FLAG= PACKAGE= install) ;\
	done
make[1]: Entering directory `/home/bgarrison/mpich2-build/src/binding/cxx'
if [ ! -d /home/bgarrison/mpich2-install/include ] ; then mkdir -p /home/bgarrison/mpich2-install/include ; fi
/usr/bin/install -c -m 644 mpicxx.h /home/bgarrison/mpich2-install/include/mpicxx.h
make[1]: Leaving directory `/home/bgarrison/mpich2-build/src/binding/cxx'
for dir in  src/openpa src/pm/mpd src/mpe2 - ; do \
	done
make[1]: Entering directory `/home/bgarrison/mpich2-build/src/openpa'
Making install in src
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/openpa/src'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/openpa/src'
test -z "/home/bgarrison/mpich2-install/lib" || mkdir -p "/home/bgarrison/mpich2-install/lib"
 /usr/bin/install -c -m 644  libopa.a '/home/bgarrison/mpich2-install/lib'
 ( cd '/home/bgarrison/mpich2-install/lib' && ranlib libopa.a )
test -z "/home/bgarrison/mpich2-install/include" || mkdir -p "/home/bgarrison/mpich2-install/include"
 /usr/bin/install -c -m 644 opa_config.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/opa_primitives.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/opa_queue.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/opa_util.h '/home/bgarrison/mpich2-install/include'
mkdir -p '/home/bgarrison/mpich2-install/include/primitives'
 /usr/bin/install -c -m 644  /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/primitives/opa_by_lock.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/primitives/opa_emulated.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/primitives/opa_gcc_ia64.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/primitives/opa_gcc_intel_32_64.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/primitives/opa_gcc_intel_32_64_barrier.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/primitives/opa_gcc_intel_32_64_ops.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/primitives/opa_gcc_intel_32_64_p3.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/primitives/opa_gcc_intel_32_64_p3barrier.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/primitives/opa_gcc_intrinsics.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/primitives/opa_gcc_ppc.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/primitives/opa_gcc_sicortex.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/primitives/opa_nt_intrinsics.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/primitives/opa_sun_atomic_ops.h /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/src/primitives/opa_unsafe.h '/home/bgarrison/mpich2-install/include/primitives'
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/openpa/src'
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/openpa/src'
Making install in test
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/openpa/test'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/openpa/test'
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/openpa/test'
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/openpa/test'
make[2]: Entering directory `/home/bgarrison/mpich2-build/src/openpa'
make[3]: Entering directory `/home/bgarrison/mpich2-build/src/openpa'
test -z "/home/bgarrison/mpich2-install/share/doc/openpa" || mkdir -p "/home/bgarrison/mpich2-install/share/doc/openpa"
 /usr/bin/install -c -m 644 /home/bgarrison/libraries/mpich2-1.2.1/src/openpa/README '/home/bgarrison/mpich2-install/share/doc/openpa'
make[3]: Leaving directory `/home/bgarrison/mpich2-build/src/openpa'
make[2]: Leaving directory `/home/bgarrison/mpich2-build/src/openpa'
make[1]: Leaving directory `/home/bgarrison/mpich2-build/src/openpa'
make[1]: Entering directory `/home/bgarrison/mpich2-build/src/pm/mpd'
copying python files/links into  /home/bgarrison/mpich2-install/bin
make[1]: Leaving directory `/home/bgarrison/mpich2-build/src/pm/mpd'
make[1]: Entering directory `/home/bgarrison/mpich2-build/src/mpe2'
Installing MPE2 include files to /home/bgarrison/mpich2-install/include
Replacing existing file /home/bgarrison/mpich2-install/include/clog_commset.h...
Replacing existing file /home/bgarrison/mpich2-install/include/clog_const.h...
Replacing existing file /home/bgarrison/mpich2-install/include/clog_inttypes.h...
Replacing existing file /home/bgarrison/mpich2-install/include/clog_uuid.h...
Replacing existing file /home/bgarrison/mpich2-install/include/mpe.h...
Replacing existing file /home/bgarrison/mpich2-install/include/mpe_callstack.h...
Replacing existing file /home/bgarrison/mpich2-install/include/mpe_graphics.h...
Replacing existing file /home/bgarrison/mpich2-install/include/mpe_graphicsf.h...
Replacing existing file /home/bgarrison/mpich2-install/include/mpe_log.h...
Replacing existing file /home/bgarrison/mpich2-install/include/mpe_log_thread.h...
Replacing existing file /home/bgarrison/mpich2-install/include/mpe_logf.h...
Replacing existing file /home/bgarrison/mpich2-install/include/mpe_misc.h...
Installing MPE2 libraries to /home/bgarrison/mpich2-install/lib
Replacing existing file /home/bgarrison/mpich2-install/lib/libampe.a...
Replacing existing file /home/bgarrison/mpich2-install/lib/liblmpe.a...
Replacing existing file /home/bgarrison/mpich2-install/lib/libmpe.a...
Replacing existing file /home/bgarrison/mpich2-install/lib/libmpe_collchk.a...
Replacing existing file /home/bgarrison/mpich2-install/lib/libmpe_nompi.a...
Replacing existing file /home/bgarrison/mpich2-install/lib/libmpe_nompi_null.a...
Replacing existing file /home/bgarrison/mpich2-install/lib/libmpe_null.a...
Replacing existing file /home/bgarrison/mpich2-install/lib/libtmpe.a...
Replacing existing file /home/bgarrison/mpich2-install/lib/mpe_prof.o...
Installing MPE2 utility programs to /home/bgarrison/mpich2-install/bin
Replacing existing file /home/bgarrison/mpich2-install/bin/check_callstack...
Replacing existing file /home/bgarrison/mpich2-install/bin/clog2_join...
Replacing existing file /home/bgarrison/mpich2-install/bin/clog2_print...
Replacing existing file /home/bgarrison/mpich2-install/bin/clog2_repair...
Installing MPE2 configuration files to /home/bgarrison/mpich2-install/etc
Installing MPE2 system utility programs to /home/bgarrison/mpich2-install/sbin
Replacing existing file /home/bgarrison/mpich2-install/sbin/mpecheckinstall...
Installing MPE2 man to /home/bgarrison/mpich2-install/share/man
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Add_RGB_color.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_CaptureFile.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Close_graphics.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Comm_global_rank.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Decomp1d.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Describe_comm_event.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Describe_comm_state.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Describe_event.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Describe_info_event.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Describe_info_state.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Describe_state.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Draw_circle.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Draw_line.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Draw_logic.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Draw_point.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Draw_points.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Draw_string.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Errors_call_debugger.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Fill_circle.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Fill_rectangle.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Finish_log.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_GetHostName.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_GetTags.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Get_mouse_press.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_IO_Stdout_to_file.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Iget_mouse_press.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Init_log.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Initialized_logging.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Line_thickness.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Log_bare_event.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Log_comm_event.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Log_comm_receive.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Log_comm_send.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Log_event.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Log_get_event_number.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Log_get_solo_eventID.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Log_get_state_eventIDs.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Log_info_event.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Log_merged_logfilename.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Log_pack.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Log_receive.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Log_send.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Log_sync_clocks.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Make_color_array.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Num_colors.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Open_graphics.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_ReturnTags.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Seq_begin.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Seq_end.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Signals_call_debugger.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Start_log.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Stop_log.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_TagsEnd.4...
Replacing existing file /home/bgarrison/mpich2-install/share/man/man4/MPE_Update.4...
Installing MPE2 html to /home/bgarrison/mpich2-install/share/doc/
Installing SLOG2SDK's lib
Replacing existing file /home/bgarrison/mpich2-install/lib/clog2TOdrawable.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/clog2TOslog2.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/clog2print.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/clogTOdrawable.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/clogTOslog2.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/clogprint.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/jumpshot.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/jumpshot_launcher.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/logconvertor.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/slog2filter.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/slog2navigator.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/slog2printrecur.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/slog2printserial.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/slog2update205to206.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/traceTOslog2.jar...
Replacing existing file /home/bgarrison/mpich2-install/lib/traceprint.jar...
Installing SLOG2SDK's doc
Installing SLOG2SDK's share
Creating SLOG2SDK's bin
Installed SLOG2SDK in /home/bgarrison/mpich2-install
/home/bgarrison/mpich2-install/sbin/mpeuninstall may be used to remove the installation
Installed MPE2 in /home/bgarrison/mpich2-install
make[1]: Leaving directory `/home/bgarrison/mpich2-build/src/mpe2'
