[mpich-discuss] problems with mpich2 configure
    Pavan Balaji
    balaji at mcs.anl.gov
    Tue Jan 12 22:17:36 CST 2010
If you install it from source, I'm not sure what all the tarball
contains. But if you do an Internet install (apt-get, yum, etc.), gcc
and g++ are typically separate packages.
 -- Pavan
On 01/12/2010 09:41 PM, jaharvey at chem.umass.edu wrote:
> This is getting a little off topic but doesn't GCC contain G++ no?
> Jacob
> On Tue, Jan 12, 2010 at 10:29 PM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
>     You need a C++ compiler (e.g., g++), if you plan to use C++ programs.
>     gcc is a C compiler.
>     If you don't need C++, you can just do a configure --disable-cxx, as
>     Dave pointed out.
>      -- Pavan
>     On 01/12/2010 07:38 PM, jaharvey at chem.umass.edu wrote:
>     > Would a re-install of GCC fix this problem?
>     > Jacob
>     > On Tue, Jan 12, 2010 at 5:43 PM, Dave Goodell
> <goodell at mcs.anl.gov> wrote:
>     >     It looks like your C++ compiler installation isn't in the best
> shape
>     > (see the quoted passage at the bottom of this mail for an
> example).  If
>     > you don't need C++ support in your mpich2 installation you can
> configure
>     > with --disable-cxx. Otherwise I would work on getting your C++
> compiler
>     > working on simple programs before attempting to build mpich2.
>     >     -Dave
>     >     -------8<-------
>     >     configure:12111: checking whether C++ compiler works with string
>     >     configure:12145: c++ -c -m64
> -I/opt/src/mpich2-1.2.1/src/openpa/src
>     > -I/opt/src/mpich2-1.2.1/src/openpa/src conftest.cpp >&5
>     >     In file included from conftest.cpp:29:
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../include/c++/3.4.6/string:45:28:
>     > bits/c++config.h: No such file or directory
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../include/c++/3.4.6/bits/stl_algobase.h:70,
>     >                     from
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../include/c++/3.4.6/bits/char_traits.h:46,
>     >                     from
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../include/c++/3.4.6/string:47,
>     >     -------8<-------
>     >     [trimming lots more error output from the same test]
>     >     -------8<-------
>     >     configure:12152: $? = 1
>     >     configure: failed program was:
>     >     | /* confdefs.h.  */
>     >     | #define PACKAGE_NAME ""
>     >     | #define PACKAGE_TARNAME ""
>     >     | #define PACKAGE_VERSION ""
>     >     | #define PACKAGE_STRING ""
>     >     | #define PACKAGE_BUGREPORT ""
>     >     | #define USE_SMP_COLLECTIVES 1
>     >     | #define HAVE_ERROR_CHECKING MPID_ERROR_LEVEL_ALL
>     >     | #define MPICH_ERROR_MSG_LEVEL MPICH_ERROR_MSG_ALL
>     >     | #define USE_LOGGING MPID_LOGGING_NONE
>     >     | #define HAVE_RUNTIME_THREADCHECK 1
>     >     | #define MPICH_THREAD_LEVEL MPI_THREAD_MULTIPLE
>     >     | #define USE_THREAD_IMPL MPICH_THREAD_IMPL_GLOBAL_MUTEX
>     >     | #define MPIU_THREAD_GRANULARITY MPIU_THREAD_GRANULARITY_GLOBAL
>     >     | #define MPIU_HANDLE_ALLOCATION_METHOD
> MPIU_HANDLE_ALLOCATION_MUTEX
>     >     | #define MPIU_THREAD_REFCOUNT MPIU_REFCOUNT_NONE
>     >     | #define HAVE_ROMIO 1
>     >     | #define HAVE__FUNC__ /**/
>     >     | #define HAVE__FUNCTION__ /**/
>     >     | #define HAVE_PRAGMA_WEAK 1
>     >     | #define USE_WEAK_SYMBOLS 1
>     >     | #define HAVE_MULTIPLE_PRAGMA_WEAK 1
>     >     | #define HAVE_LONG_LONG 1
>     >     | #define F77_NAME_LOWER_2USCORE 1
>     >     | #define STDCALL
>     >     | #define HAVE_MPI_F_INIT_WORKS_WITH_C 1
>     >     | #define HAVE_FORTRAN_BINDING 1
>     >     | /* end confdefs.h.  */
>     >     | #include <string>
>     >     | int
>     >     | main ()
>     >     | return 0;
>     >     |   return 0;
>     >     configure:12173: result: no
>     >     configure:12176: WARNING: The C++ compiler c++ cannot compile a
>     > program containing the <string> header - this may indicate a problem
>     > with the C++ installation.  Consider configuing with --disable-cxx
>     >     -------8<-------
>     >     On Jan 12, 2010, at 4:21 PM, jaharvey at chem.umass.edu wrote:
>     >         Dear all,
>     >         Here is my config.log file. Looks like I got errors is a few
>     > places but I'm not sure which ones are the offending ones.
>     >         Jacob
>     >         On Tue, Jan 12, 2010 at 5:08 PM, Dave Goodell
>     >           Hi Jacob, can you also send your config.log?  Configure
>     > doesn't think that your C++ compiler is in the best shape, but the
> exact
>     > error messages will be contained in the config.log.
>     >           -Dave
>     >           On Jan 12, 2010, at 3:55 PM, jaharvey at chem.umass.edu wrote:
>     >               Dear MPICH2 community,
>     >               I am trying to install MPICH2-1.2.1 on my 26 node
> cluster
>     > running CentOS. I want to compile two versions of MPICH2-1.2.1,
> one for
>     > 64 bit machines and the other for 32 bit machines. So for the 64 bit
>     > machines I have given the following command:
>     >               ./configure --prefix=/opt/mpich2-1.2.1-i86 CFLAGS=-m64
>     > FFLAGS=-m64 F90FLAGS=-m64 CXXFLAGS=-m64 2>&1 | tee c.txt
>     >               However, when I run this the configuration process ends
>     > abruptly with the following errors:
>     >               configure: error: C++ compiler
>     > /opt/src/mpich2-1.2.1/bin/mpicxx  has neither iostream nor
> iostream.h.
>     >               configure: error: ./configure failed for test/mpi
>     >               I am indeed on a 64 bit machine when running
> ./configure.
>     > I have attached my c.txt file. Any help would be greatly appreciated.
>     >               Jacob Harvey
>     >               <c.txt>_______________________________________________
>     >               mpich-discuss mailing list
>     >               mpich-discuss at mcs.anl.gov
>     >         <config.log>_______________________________________________
>     Pavan Balaji
>     http://www.mcs.anl.gov/~balaji
Pavan Balaji
