[mpich-discuss] problems with mpich2 configure
    Dave Goodell
    goodell at mcs.anl.gov
    Tue Jan 12 16:43:10 CST 2010
It looks like your C++ compiler installation isn't in the best shape
(see the quoted passage at the bottom of this mail for an example).
If you don't need C++ support in your mpich2 installation you can
configure with --disable-cxx. Otherwise I would work on getting your C+
+ compiler working on simple programs before attempting to build mpich2.
-Dave
-------8<-------
configure:12111: checking whether C++ compiler works with string
configure:12145: c++ -c -m64  -I/opt/src/mpich2-1.2.1/src/openpa/src -
I/opt/src/mpich2-1.2.1/src/openpa/src conftest.cpp >&5
In file included from conftest.cpp:29:
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../include/c++/3.4.6/
string:45:28: bits/c++config.h: No such file or directory
In file included from /usr/lib/gcc/x86_64-redhat-linux/
3.4.6/../../../../include/c++/3.4.6/bits/stl_algobase.h:70,
3.4.6/../../../../include/c++/3.4.6/bits/char_traits.h:46,
3.4.6/../../../../include/c++/3.4.6/string:47,
-------8<-------
[trimming lots more error output from the same test]
-------8<-------
configure:12152: $? = 1
configure: failed program was:
| /* confdefs.h.  */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define USE_SMP_COLLECTIVES 1
| #define HAVE_ERROR_CHECKING MPID_ERROR_LEVEL_ALL
| #define MPICH_ERROR_MSG_LEVEL MPICH_ERROR_MSG_ALL
| #define USE_LOGGING MPID_LOGGING_NONE
| #define HAVE_RUNTIME_THREADCHECK 1
| #define MPICH_THREAD_LEVEL MPI_THREAD_MULTIPLE
| #define USE_THREAD_IMPL MPICH_THREAD_IMPL_GLOBAL_MUTEX
| #define MPIU_THREAD_GRANULARITY MPIU_THREAD_GRANULARITY_GLOBAL
| #define MPIU_HANDLE_ALLOCATION_METHOD MPIU_HANDLE_ALLOCATION_MUTEX
| #define MPIU_THREAD_REFCOUNT MPIU_REFCOUNT_NONE
| #define HAVE_ROMIO 1
| #define HAVE__FUNC__ /**/
| #define HAVE__FUNCTION__ /**/
| #define HAVE_PRAGMA_WEAK 1
| #define USE_WEAK_SYMBOLS 1
| #define HAVE_MULTIPLE_PRAGMA_WEAK 1
| #define HAVE_LONG_LONG 1
| #define F77_NAME_LOWER_2USCORE 1
| #define STDCALL
| #define HAVE_MPI_F_INIT_WORKS_WITH_C 1
| #define HAVE_FORTRAN_BINDING 1
| /* end confdefs.h.  */
| #include <string>
| int
| main ()
| return 0;
|   return 0;
configure:12173: result: no
configure:12176: WARNING: The C++ compiler c++ cannot compile a
program containing the <string> header - this may indicate a problem
with the C++ installation.  Consider configuing with --disable-cxx
-------8<-------
On Jan 12, 2010, at 4:21 PM, jaharvey at chem.umass.edu wrote:
> Dear all,
> Here is my config.log file. Looks like I got errors is a few places
> but I'm not sure which ones are the offending ones.
> Jacob
> On Tue, Jan 12, 2010 at 5:08 PM, Dave Goodell <goodell at mcs.anl.gov>
> wrote:
>    Hi Jacob, can you also send your config.log?  Configure doesn't
> think that your C++ compiler is in the best shape, but the exact
> error messages will be contained in the config.log.
>    -Dave
>    On Jan 12, 2010, at 3:55 PM, jaharvey at chem.umass.edu wrote:
>        Dear MPICH2 community,
>        I am trying to install MPICH2-1.2.1 on my 26 node cluster
> running CentOS. I want to compile two versions of MPICH2-1.2.1, one
> for 64 bit machines and the other for 32 bit machines. So for the 64
> bit machines I have given the following command:
>        ./configure --prefix=/opt/mpich2-1.2.1-i86 CFLAGS=-m64
> FFLAGS=-m64 F90FLAGS=-m64 CXXFLAGS=-m64 2>&1 | tee c.txt
>        However, when I run this the configuration process ends
> abruptly with the following errors:
>        configure: error: C++ compiler /opt/src/mpich2-1.2.1/bin/
> mpicxx  has neither iostream nor iostream.h.
>        configure: error: ./configure failed for test/mpi
>        I am indeed on a 64 bit machine when running ./configure. I
> have attached my c.txt file. Any help would be greatly appreciated.
>        Jacob Harvey
>        <c.txt>_______________________________________________
>        mpich-discuss mailing list
>        mpich-discuss at mcs.anl.gov
>        https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> <config.log>_______________________________________________
