[mpich-discuss] problems with mpich2 configure
    Dave Goodell
    goodell at mcs.anl.gov
    Tue Jan 12 16:08:28 CST 2010
Hi Jacob, can you also send your config.log?  Configure doesn't think
that your C++ compiler is in the best shape, but the exact error
messages will be contained in the config.log.
-Dave
On Jan 12, 2010, at 3:55 PM, jaharvey at chem.umass.edu wrote:
> Dear MPICH2 community,
> I am trying to install MPICH2-1.2.1 on my 26 node cluster running
> CentOS. I want to compile two versions of MPICH2-1.2.1, one for 64
> bit machines and the other for 32 bit machines. So for the 64 bit
> machines I have given the following command:
> ./configure --prefix=/opt/mpich2-1.2.1-i86 CFLAGS=-m64 FFLAGS=-m64
> F90FLAGS=-m64 CXXFLAGS=-m64 2>&1 | tee c.txt
> However, when I run this the configuration process ends abruptly
> with the following errors:
> configure: error: C++ compiler /opt/src/mpich2-1.2.1/bin/mpicxx  has
> neither iostream nor iostream.h.
> configure: error: ./configure failed for test/mpi
> I am indeed on a 64 bit machine when running ./configure. I have
> attached my c.txt file. Any help would be greatly appreciated.
> Jacob Harvey
> <c.txt>_______________________________________________
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
