[mpich-discuss] updated lustre adio driver from LiuYing
Rob Latham robl at mcs.anl.gov
Mon Jan 4 14:16:37 CST 2010
Cc:
Bcc:
Subject: [Emoly.Liu at Sun.COM: some fixes for lustre adio driver]
Reply-To:
Here is LiuYing's message from last month.  If all looks OK, once I've
merged the two patch sets, all the known bugs will be fixed.
Thanks for the work!
==rob
----- Forwarded message from "emoly.liu" <Emoly.Liu at Sun.COM> -----
Sender: Emoly.Liu at Sun.COM
Subject: some fixes for lustre adio driver
Date: Mon, 14 Dec 2009 18:32:34 +0800
Message-id: <4B261442.5010909 at sun.com>
User-Agent: Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9.1.4pre)
	Gecko/20090922 Fedora/3.0-3.9.b4.fc12 Thunderbird/3.0b4
To: Robert Latham <robl at mcs.anl.gov>
Cc: "Tom.Wang" <Tom.Wang at Sun.COM>
X-Spam-Status: No, score=-3.043 tagged_above=-10 required=6.6
	tests=[AWL=-0.444, BAYES_00=-2.599]
Hi Rob,
Since our discussion in June, I haven't been working on lustre adio
driver. Now, I'm back.
Here is a patch(based on remio revision 5963) to fix the following
problems in the driver:
1. unsafe lum initialization in ADIOI_LUSTRE_Open()
2. wrong avail_cb_nodes calculation in
ADIOI_LUSTRE_Get_striping_info(). Wei-keng found this bug and I
remember I ever submitted this correction, but probably missed.
3. enabling ROMIO_LUSTRE in ad_fstype.c
I test this patch on my local machine, it passed all the cases in
romio/test/runtest, except i_noncontig and noncontig, which should be
not related to collective I/O.
I will continue to investigate them, so please land this patch first.
If you have any problems on the patch or lustre adio driver, please
let me know.
LiuYing
Best regards,
LiuYing
System Software Engineer, Lustre Group
Sun Microsystems ( China ) Co. Limited
Index: adio/ad_lustre/ad_lustre_open.c
--- adio/ad_lustre/ad_lustre_open.c	(revision 5963)
+++ adio/ad_lustre/ad_lustre_open.c	(working copy)
@@ -10,10 +10,13 @@
 #include "ad_lustre.h"
+#define MAX_LOV_UUID_COUNT      1000
 void ADIOI_LUSTRE_Open(ADIO_File fd, int *error_code)
     int perm, old_mask, amode, amode_direct;
-    struct lov_user_md lum = { 0 };
+    int lumlen;
+    struct lov_user_md *lum = NULL;
     char *value;
 #if defined(MPICH2) || !defined(PRINT_ERR_MSG)
@@ -46,30 +49,34 @@
     if (fd->fd_sys != -1) {
         int err;
-        value = (char *) ADIOI_Malloc((MPI_MAX_INFO_VAL+1)*sizeof(char));
         /* get file striping information and set it in info */
-        lum.lmm_magic = LOV_USER_MAGIC;
-        err = ioctl(fd->fd_sys, LL_IOC_LOV_GETSTRIPE, (void *) &lum);
+        lumlen = sizeof(struct lov_user_md) +
+                 MAX_LOV_UUID_COUNT * sizeof(struct lov_user_ost_data);
+        lum = (struct lov_user_md *)ADIOI_Malloc(lumlen);
+        lum->lmm_magic = LOV_USER_MAGIC;
+        err = ioctl(fd->fd_sys, LL_IOC_LOV_GETSTRIPE, (void *)lum);
+        if (!err) {
+            value = (char *) ADIOI_Malloc((MPI_MAX_INFO_VAL+1)*sizeof(char));
-        if (!err) {
-            fd->hints->striping_unit = lum.lmm_stripe_size;
-            sprintf(value, "%d", lum.lmm_stripe_size);
+            fd->hints->striping_unit = lum->lmm_stripe_size;
+            sprintf(value, "%d", lum->lmm_stripe_size);
             MPI_Info_set(fd->info, "striping_unit", value);
-            fd->hints->striping_factor = lum.lmm_stripe_count;
-            sprintf(value, "%d", lum.lmm_stripe_count);
+            fd->hints->striping_factor = lum->lmm_stripe_count;
+            sprintf(value, "%d", lum->lmm_stripe_count);
             MPI_Info_set(fd->info, "striping_factor", value);
-            fd->hints->fs_hints.lustre.start_iodevice = lum.lmm_stripe_offset;
-            sprintf(value, "%d", lum.lmm_stripe_offset);
+            fd->hints->fs_hints.lustre.start_iodevice = lum->lmm_stripe_offset;
+            sprintf(value, "%d", lum->lmm_stripe_offset);
             MPI_Info_set(fd->info, "romio_lustre_start_iodevice", value);
+            ADIOI_Free(value);
-        ADIOI_Free(value);
+        ADIOI_Free(lum);
         if (fd->access_mode & ADIO_APPEND)
             fd->fp_ind = fd->fp_sys_posn = lseek(fd->fd_sys, 0, SEEK_END);
     if ((fd->fd_sys != -1) && (fd->access_mode & ADIO_APPEND))
@@ -86,7 +93,7 @@
     /* --BEGIN ERROR HANDLING-- */
-    if (fd->fd_sys == -1 || ((fd->fd_direct == -1) &&
+    if (fd->fd_sys == -1 || ((fd->fd_direct == -1) &&
 		(fd->direct_write || fd->direct_read))) {
 	if (errno == ENAMETOOLONG)
 	    *error_code = MPIO_Err_create_code(MPI_SUCCESS,
Index: adio/ad_lustre/ad_lustre_aggregate.c
--- adio/ad_lustre/ad_lustre_aggregate.c	(revision 5963)
+++ adio/ad_lustre/ad_lustre_aggregate.c	(working copy)
@@ -59,7 +59,7 @@
      * so that each OST is accessed by only one or more constant clients. */
     CO_nodes = stripe_count * CO;
     avail_cb_nodes = ADIOI_MIN(nprocs_for_coll, CO_nodes);
-    if (avail_cb_nodes ==  CO_nodes) {
+    if (avail_cb_nodes < CO_nodes) {
         do {
             /* find the divisor of CO_nodes */
             divisor = 1;
Index: adio/common/ad_fstype.c
--- adio/common/ad_fstype.c	(revision 5963)
+++ adio/common/ad_fstype.c	(working copy)
@@ -347,7 +347,7 @@
 # endif
 /*#if defined(LINUX) && defined(ROMIO_LUSTRE)*/
-#if 0
+#if 1
     /* disable lustre auto-detection until we figure out why collective i/o
      * broken */
 #ifdef ROMIO_LUSTRE
----- End forwarded message -----
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
