[mpich-discuss] Install and config
Rodinei Nunes rodinei.nunes at yahoo.com.br
Mon Jan 4 04:28:39 CST 2010
hello, I have two computers with a 975 Placida Mar MSi power edition with
pentium D 3.4GHZ with 100,100,100,100 and IP mask 255.0.0.0 name of the
computer on the network is MSI-975 and the other computer is an ASUS P5E3
Premium pentium D 2.8GHZ using the IP 255.0.0.0 and mask 100,100,100,101
your name on the network is ASUS. Please can someone send me the setting to
use these two computers together, which the configuration on each computer?
Well I do not know anything about the MPICH2. Grateful
-------Mensagem original-------
De: mpich-discuss-request at mcs.anl.gov
Data: 01/04/10 21:06:54
Para: mpich-discuss at mcs.anl.gov
Assunto: mpich-discuss Digest, Vol 16, Issue 1
Send mpich-discuss mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
  mpich-discuss-owner at mcs.anl.gov
When replying, please edit your Subject line so it is more specific
than "Re: Contents of mpich-discuss digest..."
Today's Topics:
   1. Re:  smpd on windows 7 (Jayesh Krishna)
   2. Re:  MPI_Waitsome and MPI_Getcount incorrect (jayesh at mcs.anl.gov)
   3. Re:  mpich2-1.2.1 on Cygwin/Vista (Jayesh Krishna)
   4. Re:  smpd on windows 7 (Sherry Frese)
   5. Re:  mpich2-1.2.1 on Cygwin/Vista (Sherry Frese)
   6. Re:  smpd on windows 7 (jayesh at mcs.anl.gov)
Message: 1
Date: Mon, 4 Jan 2010 09:09:45 -0600 (CST)
Subject: Re: [mpich-discuss] smpd on windows 7
Cc: Sherry.Frese at Numerex-LLC.com
Message-ID: <12042708.581131262617785646.JavaMail.root at zimbra>
Content-Type: text/plain; charset=utf-8
  Open a command prompt with administrator privileges (Right-click on
command prompt icon and select "Run as administrator") and use the windows
installer from command line to install MPICH2.
  To uninstall MPICH2 (It is recommended that you uninstall MPICH2 before
installing a new version) run the following at the command prompt (with
admin privileges),
   msiexec /x mpich2-1.2.1-win-ia32.msi
  To install MPICH2 run the following at the command prompt (with admin
privileges),
   msiexec /i mpich2-1.2.1-win-ia32.msi
  Let us know if you still have problems.
(PS: Running msiexec at the command prompt should bring up the GUI for
installing MPICH2.)
Jayesh
----- Original Message -----
From: "Sherry Frese" <Sherry.Frese at Numerex-LLC.com>
Sent: Monday, December 28, 2009 9:54:42 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] smpd on windows 7
I have been using MPICH2 on Windows XP (as well as under linux) for
over 2 years.
I am now moving to Windows 7 on a new PC.  I have downloaded and
installed the most recent MPICH2 for Windows and the install appears
to have been OK.  However, the smpd refuses to install as a
service.  smpd never shows up in the Task Manager's list of
services.  I have run 'sc //hostname query smpd', and it says the
'specified service does not exist as an installed service'.
I have redone the full install several times, under 2 different admin
accounts (one of them named 'administator').  I have tried the
explicit smpd -install as well (varying accounts, directory
locations. etc.), and routinely receive the message:
OpenSCManager Failed:
Access is denied. (error 5)
Unable to remove  the previous installation, install failed.
If I try smpd -uninstall, I get the same OpenSCManager Failed... message.
Any advice would be greatly appreciated
Sherry Frese
Message: 2
Date: Mon, 4 Jan 2010 09:43:06 -0600 (CST)
Subject: Re: [mpich-discuss] MPI_Waitsome and MPI_Getcount incorrect
Message-ID: <19470479.583711262619786913.JavaMail.root at zimbra>
  There is a bug in your code which results in accessing invalid indices of
the status array.
  Please modify the for loop in your code as below and let us know if it
works for you.
   for (;;) {
    /* wait for one, or multiple requests to finish */
    int outcount = MPI::Request::Waitsome(2, req, array_of_indeces,
array_of_statuses);
    if (outcount == MPI_UNDEFINED) break; /* no active handles */
    debug("received count: %d", outcount);
    for (int index=0; index<outcount; index++) {
     /* size_t index = array_of_indeces[outcount]; */
                int req_index = array_of_indeces[index];
                debug("Request %d completed", req_index);
     int recv_count = array_of_statuses[index]
Get_count(array_of_types[req_index]);
     debug("MPI_GET_COUNT %d", recv_count);
Jayesh
Sent: Monday, December 28, 2009 3:55:51 AM GMT -06:00 US/Canada Central
Sorry for the late reply but I was out of the country for a week. I am
using MPICH2 1.2.1 on a WinXP SP3 machine running an Intel Core i5
CPU. This is the output I get when running the application (mpiexec -n
2 -l test3.exe)
[1]client before: a 0, b 0
[0]host: a 1, b 2
[0]done, waiting....
[1]received count: 1
[1]MPI_Waitsome index 0
[1]MPI_GET_COUNT 1
[1]MPI_Waitsome index 1
[1]MPI_GET_COUNT -32766
[1]client after: a 1, b 2
[1]done, waiting....
[0]finalize
[1]finalize
On 22/12/2009, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
> I am not able to reproduce this problem when running MPICH2 1.2.1 with 2
> processes on a single machine.
> Rajeev
>> -----Original Message-----
>> From: mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Tam?s Farag?
>> Sent: Wednesday, December 16, 2009 7:48 AM
>> Subject: [mpich-discuss] MPI_Waitsome and MPI_Getcount incorrect
>> My actual problem, why I initiated the previous post at
>> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2009-December
>> /006187.html
>> ([mpich-discuss] MPI_GET_COUNT behaviour unclear).
>> See the very simple source code below. I initialise two
>> persistent requests, then run a Waitsome on both of them and
>> getting the top-level datatypes received. With Waitsome the
>> second one returns MPI_UNDEFINED, no idea why. Waitall
>> correctly returns 1 in both cases.
>> What is going on, is it my fault and can it be solved?
>> I have also uploaded the source code to
>> http://www.liacs.nl/~tfarago/test.cpp
>> NOTE: right now the tags are all the same, but even if
>> different tags are given to the sending and receiving side
>> (eg 0 and 1), the outcoume is the same. From the output it
>> can be seen that even if MPI_GET_COUNT returns some kind of
>> an error the program's behaviour is still correct.
>> NOTE: also, strangely I cannot get Waitsome to return both
>> completed requests, not even if I let the client sleep/idle
>> for several seconds.
>> ---CODE--
>> #include <stdarg.h>
>> #include <stdio.h>
>> #include <mpi.h>
>> #pragma comment(lib, "cxx.lib")
>> #pragma comment(lib, "mpi.lib")
>> void __cdecl debug(const char* msg, ...) {
>> va_list va;
>> va_start(va, msg);
>> vfprintf(stderr, msg, va);
>> fputs("\n", stderr);
>> fflush(stderr);
>> int main() {
>> MPI::Init();
>> int my_node = MPI::COMM_WORLD.Get_rank();
>> int a, b;
>> MPI::Prequest req[2];
>> a = 0; b = 0;
>> if (my_node == 0) {
>> a = 1; b = 2;
>> req[0] = MPI::COMM_WORLD.Send_init(&a, 1,
>> MPI::INT, 1, 0);
>> req[1] = MPI::COMM_WORLD.Send_init(&b, 1,
>> MPI::INT, 1, 0);
>> } else {
>> size_t size = MPI::INT.Pack_size(1, MPI::COMM_WORLD);
>> req[0] = MPI::COMM_WORLD.Recv_init(&a, size,
>> MPI::INT, 0, MPI::ANY_TAG);
>> req[1] = MPI::COMM_WORLD.Recv_init(&b, size,
>> MPI::Prequest::Startall(2, req);
>> if (my_node == 0) {
>> debug("host: a %d, b %d", a, b);
>> } else {
>> debug("client before: a %d, b %d", a, b);
>> int array_of_indeces[2];
>> MPI::Status array_of_statuses[2];
>> MPI::Datatype array_of_types[2];
>> array_of_types[0] = MPI::INT;
>> array_of_types[1] = MPI::INT;
>> #if 1
>> for (;;) {
>> to finish */
>> int outcount =
>> MPI::Request::Waitsome(2, req, array_of_indeces, array_of_statuses);
>> for (outcount--; outcount >= 0; --outcount) {
>> size_t index =
>> debug("MPI_Waitsome index %d", index);
>> int recv_count =
>> array_of_statuses[index].Get_count(array_of_types[index]);
>> #else
>> MPI::Prequest::Waitall(2, req, array_of_statuses);
>> for (int outcount = 2; outcount > 0; --outcount) {
>> int recv_count =
>> array_of_statuses[outcount-1].Get_count(array_of_types[outcount-1]);
>> #endif
>> debug("client after: a %d, b %d", a, b);
>> debug("done, waiting....");
>> MPI::COMM_WORLD.Barrier();
>> debug("finalize");
>> MPI::Finalize();
>> return 0;
>> ---CODE---
Message: 3
Date: Mon, 4 Jan 2010 10:12:36 -0600 (CST)
Subject: Re: [mpich-discuss] mpich2-1.2.1 on Cygwin/Vista
Cc: gustav at indiana.edu
Message-ID: <18116662.585721262621556712.JavaMail.root at zimbra>
  Let me take a look at this and get back to you.
  Meanwhile, if you are planning to work with C/C++ MPI programs (not
fortran MPI programs) you can install MPICH2 on windows and use the gcc libs
(you can even compile/link directly with the windows mpi libraries with gcc)
provided with the installation.
(PS: To install MPICH2 on Vista/windows_7 type "msiexec /i mpich2-1.2
1-win-ia32.msi" from an administrator command prompt. Right-click on the
command prompt icon and select "Run as administrator" to run a command
prompt with admin privileges. Similarly to uninstall MPICH2 type "msiexec /x
mpich2-1.2.1-win-ia32.msi".)
Jayesh
Sent: Thursday, December 24, 2009 7:54:06 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] mpich2-1.2.1 on Cygwin/Vista
Well, it works. Finally. But with one little snag--see below.
    System: Windows Longhorn/Vista (not yet supported!) Ver 6.0 Build 6002
Service Pack 2
    uname:  CYGWIN_NT-6.0-WOW64 Crawley 1.5.25(0.156/4/2) 2008-06-12 19:34
i686 Cygwin
    CPU:    AMD Phenom X4 9550
    gcc:    gcc (GCC) 3.4.4 (cygming special, gdc 0.12, using dmd 0.125)
    MPI:    mpich2-1.2.1
    config: ./configure --prefix=/home/gustav/mpich2-1.2.1
--disable-sharedlibs --enable-timer-type=gettimeofday --with-device=ch3:ssm
--with-thread-package=pthreads
An important step that must be emphasized for Cygwin users is that to
enable XSI IPCs (this activates shared memory too) Cygserver must be
run on the machine. See /usr/share/doc/Cygwin/cygserver.README for
more info. Also, the CYGWIN environmental variable must be set to
"server". This is described in the doc, as well.
With all this done and MPI compiled and installed, it works for a user
with admin privileges. Here's a brief demo:
    root at Crawley 515 # echo $CYGWIN
    server
    root at Crawley 516 # which mpdboot
    /home/gustav/mpich2-1.2.1/bin/mpdboot
    root at Crawley 517 # mpdboot --ncpus=4 --verbose
    running mpdallexit on Crawley
    LAUNCHED mpd on Crawley  via
    RUNNING: mpd on Crawley
    root at Crawley 518 # mpirun -np 4 hostname
    Crawley
    Crawley
    Crawley
    Crawley
    root at Crawley 519 # mpirun -np 4 /home/gustav/src/MPI-tests/hellow2.exe
    Crawley: hello world from process 0 of 4
    Crawley: hello world from process 1 of 4
    Crawley: hello world from process 2 of 4
    Crawley: hello world from process 3 of 4
    root at Crawley 520 # mpdallexit
    root at Crawley 521 #
Alas, there is a little snag. User "root" has admin privileges. User
"gustav" does not. And here is what happens when this hapless
individual attempts the same:
    gustav at Crawley 556 $ echo $CYGWIN
    server
    gustav at Crawley 557 $ mpdboot --ncpus=4 --verbose
    gustav at Crawley 558 $ mpirun -np 4 hostname
    Crawley
    Crawley
    Crawley
    Crawley
    gustav at Crawley 559 $ mpirun -np 4 /home/gustav/src/MPI-tests/hellow2.exe
    Assertion failed in file mpidi_pg.c at line 277: ((pg)->ref_count) == 0
    internal ABORT - process 0
    [cli_0]: aborting job:
    rank 0 in job 2  Crawley_50796   caused collective abort of all ranks
      exit status of rank 0: killed by signal 9
    gustav at Crawley 560 $ mpdallexit
    gustav at Crawley 561 $
On the other hand, this little non-MPI program that tests shared memory
stuff still works for the non-admin user:
    gustav at Crawley 563 $ cat shm.c
    #include <stdio.h>
    #include <sys/types.h>
    #include <sys/ipc.h>
    #include <sys/shm.h>
    int main(int argc, char *argv[])
  int shmid;
  if((shmid = shmget(IPC_PRIVATE, 1, IPC_CREAT)) == -1){
      perror("shmget");
  shmctl(shmid, IPC_RMID, NULL);
    gustav at Crawley 564 $ cc -o shm shm.c
    gustav at Crawley 565 $ ./shm
    gustav at Crawley 566 $ echo $?
    0
    gustav at Crawley 567 $
Question: Why can't the non-admin user execute the MPI program?
Greetings to all,
Zdzislaw (Gustav) Meglicki, Office of the Vice President for Information
Technology, Indiana University, 601 E. Kirkwood Ave., Room 116,
Bloomington, IN 47405-1223, USA, http://perth.ovpit.indiana.edu/gustav,
Ph: 812-856-5597 (o), 812-345-3284 (m), Fax: 812-855-3310/812-856-3147,
Message: 4
Date: Mon, 04 Jan 2010 09:16:45 -0700
From: Sherry Frese <Sherry.Frese at Numerex-LLC.com>
Message-ID: <6.2.5.6.2.20100104083538.02d6ebe0 at Numerex-LLC.com>
Content-Type: text/plain; charset="us-ascii"; format=flowed
Jayesh,
Thanks for the response, but it still does not work.
Previously I had just been executing the .msi file from my admin
account.  This time I uninstalled (which said it was successful) and
then installed the MPICH2, using msiexec from the command line as you
suggested.  The GUI came up,  and all seemed fine (I kept the default
smpd password and installed for all users).  And indeed, as before I
have all  the MPICH2 directories and files in my Program File (x86)
directory.  However the smpd service is not being installed.
I've checked on the Task manager - it's not there.
I tried    sc \\hostname query smpd      and it  now says
[SC] EnumQueryServicesStatus: OpenService FAILED  1060:
The specified service does not exist as an installed service.
My parallel executable is called m2.  When I try
   mpiexec  -n 1 -localonly  m2
I get a request for the smpd passphrase , which I supply.
mpiexec (I assume) then comes back with
Unknown option : -d
missing numproc flag: -n , -np, -hosts,  or -localonly
Unable to parse mipexec command arguments
ReadFile() Failed, error 109
unable to start the local smpd manager
I get the same response if I try    mpiexec  -n 2
-localonly  m2    or     mpiexec  -localonly 1 m2 .
I'm pretty sure that the problem is that the smpd service is not
being installed.
One additional  piece of info.  This is a 64 bit machine, and the m2
I am running is a 32 bit version.  But it runs fine in serial on this
machine.
Thanks for you  help,
Sherry
At 08:09 AM 1/4/2010, you wrote:
>Hi,
> on command prompt icon and select "Run as administrator") and use
> the windows installer from command line to install MPICH2.
> before installing a new version) run the following at the command
> prompt (with admin privileges),
> admin privileges),
>for installing MPICH2.)
>Regards,
>Jayesh
>over 2 years.
>Sherry Frese
&gt;mpich-discuss at mcs.anl.gov
Sherry Frese
NumerEx
505-828-9050
NOTE NEW EMAIL ADDRESS - Sherry.Frese at NumerEx-LLC.com
Message: 5
Date: Mon, 04 Jan 2010 09:31:41 -0700
Message-ID: <6.2.5.6.2.20100104092725.02c87018 at Numerex-LLC.com>
Unfortunately my applications are  both C and Fortran.  But so far
I've been able to compile and link (using the MPICH2 libraries)
on  my windows 7 machine.  I just can't run under mpiexec. (I've
tried executables built on  the windows 7 machine  & older
executables built under XP with the same results).
I'll wait to hear from you.
--Sherry
At 09:12 AM 1/4/2010, you wrote:
>Hi,
> (not fortran MPI programs) you can install MPICH2 on windows and
> use the gcc libs (you can even compile/link directly with the
> windows mpi libraries with gcc) provided with the installation.
>mpich2-1.2.1-win-ia32.msi" from an administrator command prompt.
>Right-click on the command prompt icon and select "Run as
>administrator" to run a command prompt with admin privileges.
>Similarly to uninstall MPICH2 type "msiexec /x mpich2-1.2.1-win-ia32.msi".)
>Regards,
>Jayesh
>From: "gustav" <gustav at indiana.edu>
> Build 6002 Service Pack 2
> 2008-06-12 19:34 i686 Cygwin
>     MPI:    mpich2-1.2.1
> --with-device=ch3:ssm --with-thread-package=pthreads
>     server
>     Crawley
>     Crawley
>     Crawley
>     Crawley
>     server
>     Crawley
>     Crawley
>     Crawley
>     Crawley
exe
0
>     #include <stdio.h>
>         int shmid;
>             perror("shmget");
>     0
>Greetings to all,
Sherry Frese
NumerEx
505-828-9050
Message: 6
Date: Mon, 4 Jan 2010 10:36:47 -0600 (CST)
Message-ID: <1247911.587581262623007296.JavaMail.root at zimbra>
  Can you see MPICH2 process manager in the list of services (Look at
Control Panel\System and Security\Administrative Tools\Services)? Also check
the status of the service (Is it started ?)?
  You don't have to supply the "-localonly" flag to run MPI processes on the
local machine. MPICH2 by default launches the processes on the local machine
("mpiexec -n 1 m2" should launch m2 on the local machine).
  Can you run a simple non-MPI program (mpiexec -n 2 hostname)?
Jayesh
Sent: Monday, January 4, 2010 10:16:45 AM GMT -06:00 US/Canada Central
Jayesh,
Unknown option : -d
being installed.
machine.
Sherry
>Hi,
> admin privileges),
>Regards,
>Jayesh
>over 2 years.
>Sherry Frese
Sherry Frese
NumerEx
505-828-9050
End of mpich-discuss Digest, Vol 16, Issue 1
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100104/ac6edae5/attachment-0001.htm>
