[mpich-discuss] ROMIO with SGI MPI MPI_TYPE_MAX
burlen burlen.loring at gmail.com
Sat Feb 27 13:30:07 CST 2010
Apparently it's still an issue, the cluster in question is an SGI Altix
ICE system only a couple of years old. The version of SGI MPI is 1.23.
Does anyone remember details about the problem?
Rajeev Thakur wrote:
> That blurb has been in the user guide since 1997!
> Rajeev
>> -----Original Message-----
>> From: mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of burlen
>> Sent: Friday, February 26, 2010 3:46 PM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [mpich-discuss] ROMIO with SGI MPI MPI_TYPE_MAX
>> Hi All,
>> I have been running into some issues when using SGI MPI and
>> collective
>> IO. My program always crashes with the error
>>     MPI has run out of internal datatype entries.
>> It's quite quick with the default 8192, upping the value does prolong
>> the life of the program but it will still crash after about
>> 300 ish type
>> commit/read/type free operations. Which to me doesn't seem
>> like a very
>> large number for an HPC app.
>> Also I have found a way to reproduce this after only two
>> explicit type
>> commit in my application. There are some point to point
>> communication as
>> well but none of them commit any types. And we're talking
>> about only a
>> handful of MPI calls issued. This reproduction depends on how many
>> process per node are scheduled , eg 1 per core. I have been
>> careful to
>> see that I'm not leaking types, so my conclusion is that SGI MPI is
>> leaking types internally.
>> I was surprised to see a blurb about just this issue in ROMIO
>> user manual.
>> Can anyone out there shed some light on this?
>> Thanks
>> Burlen
>> . When using ROMIO with SGI MPI, you may sometimes get an
>> error message
>> from SGI
>> MPI: "MPI has run out of internal datatype entries. Please set the
>> environment variable
>> MPI TYPE MAX for additional space." If you get this error
>> message, add
>> the following line to
>> your .cshrc ?le:
>> setenv MPI TYPE MAX 65536
>> Use a larger number if you still get the error message.
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
