[mpich-discuss] ./maint/updatefiles and configure problems
Dave Goodell
goodell at mcs.anl.gov
Mon Feb 15 17:47:12 CST 2010
FWIW, this check has been added: https://trac.mcs.anl.gov/projects/mpich2/changeset/6284
-Dave
On Feb 15, 2010, at 8:24 AM, Dave Goodell wrote:
> Yeah, we can add something like this. There is a version
> requirement specified in the AM_INIT_AUTOMAKE line, but the actual
> check only occurs when automake is run. So when your maint/
> updatefiles step bails after only running autoconf, you never get
> the more understandable message about version mismatch.
> -Dave
> On Feb 15, 2010, at 7:27 AM, Jeff Hammond wrote:
>> Can ./maint/updatefiles be instrumented to check for that
>> compatibility as well (i.e. in addition to autoconf 2.63)? That
>> would
>> help us noobs running a GNU toolchain that's more than three months
>> old :)
>> Thanks,
>> Jeff
>> On Sun, Feb 14, 2010 at 10:59 PM, Pavan Balaji <balaji at mcs.anl.gov>
>> wrote:
>>> Looks like you don't have automake-1.11.
>>> -- Pavan
>>> On 02/14/2010 10:24 PM, Jeff Hammond wrote:
>>>> I did the usual "svn update" and ./maint/updatefiles on the mpich2
>>>> trunk but there were problems in the second stage as well as the
>>>> subsequent configure step.
>>>> I'm not dependent on this code, so there is no urgency in fixing
>>>> what
>>>> I perceive to be a problem.
>>>> Thanks,
>>>> Jeff
>>>> step 1
>>>> jeff at megatron:/software/mpich/mpich2-trunk> svn update
>>>> step 2
>>>> jeff at megatron:/software/mpich/mpich2-trunk> ./maint/updatefiles
>>>> You have autoconf version 2.63 or greater.
>>>> Checking that libtool version is acceptable...
>>>> running autoreconf in src/pm/hydra
>>>> autoreconf: Entering directory `.'
>>>> autoreconf: configure.in: not using Gettext
>>>> autoreconf: running: aclocal --force -I mpl/confdb
>>>> configure.in:181: warning: macro `AM_SUBST_NOTMAKE' not found in
>>>> library
>>>> configure.in:182: warning: macro `AM_SUBST_NOTMAKE' not found in
>>>> library
>>>> configure.in:183: warning: macro `AM_SUBST_NOTMAKE' not found in
>>>> library
>>>> configure.in:195: warning: macro `AM_SUBST_NOTMAKE' not found in
>>>> library
>>>> configure.in:231: warning: macro `AM_SUBST_NOTMAKE' not found in
>>>> library
>>>> configure.in:237: warning: macro `AM_SUBST_NOTMAKE' not found in
>>>> library
>>>> configure.in:238: warning: macro `AM_SUBST_NOTMAKE' not found in
>>>> library
>>>> configure.in:239: warning: macro `AM_SUBST_NOTMAKE' not found in
>>>> library
>>>> autoreconf: configure.in: tracing
>>>> autoreconf: running: libtoolize --copy --force
>>>> libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, `mpl/
>>>> confdb'.
>>>> libtoolize: copying file `mpl/confdb/ltmain.sh'
>>>> libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `mpl/confdb'.
>>>> libtoolize: copying file `mpl/confdb/libtool.m4'
>>>> libtoolize: copying file `mpl/confdb/ltoptions.m4'
>>>> libtoolize: copying file `mpl/confdb/ltsugar.m4'
>>>> libtoolize: copying file `mpl/confdb/ltversion.m4'
>>>> libtoolize: copying file `mpl/confdb/lt~obsolete.m4'
>>>> library
>>>> library
>>>> library
>>>> library
>>>> library
>>>> library
>>>> library
>>>> library
>>>> autoreconf: running: /usr/bin/autoconf --force
>>>> configure.in:183: error: possibly undefined macro: AM_SUBST_NOTMAKE
>>>> If this token and others are legitimate, please use
>>>> m4_pattern_allow.
>>>> See the Autoconf documentation.
>>>> autoreconf: /usr/bin/autoconf failed with exit status: 1
>>>> step 3
>>>> jeff at megatron:/software/mpich/mpich2-trunk> ./configure CC=gcc
>>>> CXX=g++
>>>> F77=gfortran FC=gfortran
>>>> --prefix=/software/mpich/gnu-build-mpich2-trunk
>>>> --with-thread-package=pthreads --enable-threads=default --enable-
>>>> f77
>>>> --enable-f90 --enable-cxx --enable-romio --enable-smpcoll --
>>>> enable-mpe
>>>> --with-pm=hydra
>>>> checking boot-strap server... ssh,rsh,fork,slurm,persist
>>>> /software/mpich/mpich2-trunk/src/pm/hydra/configure: line 12966:
>>>> syntax error near unexpected token `hydra_bss_init_decl'
>>>> `AM_SUBST_NOTMAKE(hydra_bss_init_decl)'
>>> Pavan Balaji
>>> http://www.mcs.anl.gov/~balaji
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> mpich-discuss at mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> Jeff Hammond
>> Argonne Leadership Computing Facility
>> jhammond at mcs.anl.gov / (630) 252-5381
>> http://www.linkedin.com/in/jeffhammond
