[mpich-discuss] Launching MPMD jobs using mpiexec with hydra
Reuti
reuti at staff.uni-marburg.de
Fri Feb 12 11:23:56 CST 2010
Am 12.02.2010 um 18:10 schrieb Pavan Balaji:
> Hmm.. That's a good point. Unfortunately, config file support is not
> available right now. I'll work on adding it for the next release.
> -- Pavan
> On 02/12/2010 10:12 AM, Sindhi, Waris PW wrote:
>> Pavan,
>> Thanks for the response. The problem with listing
>> executables on
>> the mpiexec command line is that I have each slave using a slightly
>> different executable and the command line gets to long to manage.
if you put it in a script or a wrapper, it should be possible to put
each node in one line and use the \ as last character in a line to
continue on the next one. It will be treated as being one line by the
shell.
-- Reuti
>> Is there a way to list each executable that goes with each slave in a
>> file and pass that to mpiexec with hydra ?
>> Sincerely,
>> Waris
>> -----Original Message-----
>> From: mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Pavan Balaji
>> Sent: Friday, February 12, 2010 11:09 AM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: Re: [mpich-discuss] Launching MPMD jobs using mpiexec with
>> hydra
>> You can use:
>> % mpiexec -f machinefile -n 4 ./foo1 : -n 3 ./foo2 : -n 5 ./foo3
>> -- Pavan
>> On 02/12/2010 10:01 AM, Sindhi, Waris PW wrote:
>>> Hi,
>>> I wanted to know what the best way to launch MPMD jobs using
>>> mpiexec is with the hydra process manager. I tried the -configfile
>> with
>>> mpiexec which does not seem to work with hydra.
>>> Any help would be greatly appreciated.
>>> Sincerely,
>>> Waris
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
