[mpich-discuss] mpich2-1.2.1, only starts 5 mpd's and cpi won't run, compiler flags issue?
Dave Goodell
goodell at mcs.anl.gov
Tue Feb 9 12:12:28 CST 2010
On Feb 9, 2010, at 11:58 AM, David Mathog wrote:
> Any idea what might be triggering the "failed to obtain sock from
> manager"?
I think that message is just a consequence of hitting ^C on the
mpiexec, not the actual underlying problem. Despite your thorough
explanations of the symptoms you are seeing, it's not at all clear
what the real problem is here.
Please try hydra instead (mpiexec.hydra). Hydra will be the default
process manager in the upcoming release and is generally faster and
more reliable than mpd:
http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
-Dave
