[mpich-discuss] Getting runtime exception
Rajnish
rajnish99 at gmail.com
Fri Feb 5 13:03:11 CST 2010
Great! After bringing both nodes to have latest MPICH2 version, and both
hydra and mpd are working great:
% mpiexec.hydra -f machinefile -n 4 hostname
even though mpdboot hangs, still after a cntrl-c, mpdtrace shows successful
start of the mpd daemons, and mpiexec works fine.
Thanks again to Pavan and Dave.
- Rajnish.
On Fri, Feb 5, 2010 at 1:26 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> FYI, if you install version 1.2.1 and your mpdboot hangs, you might need to
> apply the fix described in ticket #963:
> https://trac.mcs.anl.gov/projects/mpich2/ticket/963
> -Dave
> On Feb 5, 2010, at 11:59 AM, Rajnish wrote:
> Thank you Pavan for suggesting the use of hydra, did not have it in the
>> default installation, doing that right now.
>> Thank you Dave for pointing out about the version incompatibility. Yes,
>> md5sums are different indeed...
>> I had installed 1.2.1 on node-n1, and node n2 had it already, but not sure
>> which version, must be incompatible.
>> I am going to install fresh and will give you updates.
>> - Rajnish.
>> On Fri, Feb 5, 2010 at 12:37 PM, Dave Goodell <goodell at mcs.anl.gov>
>> wrote:
>> On Feb 5, 2010, at 7:24 AM, Rajnish wrote:
>> [snip]
>> However, when I schedule tasks across both nodes, with n2 as the master
>> node, I get the following message on n1:
>> mpd_uncaught_except_tb handling:
>> exceptions.KeyError: 'process_mapping'
>> /usr/local/bin/mpd 1354 do_mpdrun
>> msg['process_mapping'][lorank] = self.myHost
>> /usr/local/bin/mpd 984 handle_lhs_input
>> self.do_mpdrun(msg)
>> /usr/local/bin/mpdlib.py 780 handle_active_streams
>> handler(stream,*args)
>> /usr/local/bin/mpd 301 runmainloop
>> rv = self.streamHandler.handle_active_streams(timeout=8.0)
>> /usr/local/bin/mpd 270 run
>> self.runmainloop()
>> /usr/local/bin/mpd 1643 ?
>> mpd.run()
>> n1-wulf.myhost.org_mpdman_1 (run 287): invalid msg from lhs; expecting
>> ringsize got: {}
>> What version of MPICH2 are you running?
>> This message seems to indicate that you have somehow installed
>> incompatible versions of "mpd.py" between the two hosts. What output do you
>> get from running the following commands on both hosts?
>> -------8<-------
>> tail -n +2 `which mpd.py` | md5sum
>> tail -n +2 `which mpdman.py` | md5sum
>> -------8<-------
>> (the "tail" business is needed because the shebang line is usually altered
>> by the install step)
>> Results for a few releases:
>> -------8<-------
>> release mpich2-1.2.1
>> 68a128402fb44c6fdebe631bbc1c4b7f mpd.py
>> b79fd98d6e4f9d9b80c295e05e01591c mpdman.py
>> release mpich2-1.2
>> be37cc1347b915a0ec32cba54c928f63 mpd.py
>> 5a9cd3f44b5986584b27a648f889bf31 mpdman.py
>> release mpich2-1.1.1p1
>> 550958d41e76cdef0ceaa74d540760de mpd.py
>> release mpich2-1.1
>> f59c7e766dd2d3488b6df212a663ccb9 mpd.py
>> 07129c1f68cd815c56bd186eb1b59038 mpdman.py
>> release mpich2-1.0.8
>> 65fb3b8b1c9e3d053bb97d5ef2ae86ad mpd.py
>> 2083f8908d0b9698eb0550c32ef3d153 mpdman.py
>> -------8<-------
>> After doing mpdallexit, n2 shows the following message:
>> mpiexec_n2-wulf.myhost.org (mpiexec 377): no msg recvd from mpd when
>> expecting ack of request
>> You can ignore this message, it's a consequence of the earlier error.
>> -Dave
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100205/758da520/attachment.htm>
