[mpich-discuss] issue compiling mpich
Darius Buntinas buntinas at mcs.anl.gov
Thu Feb 4 11:52:24 CST 2010
Actually, I think largefile support should be there by default on
x86_64, so you should be able to leave those options off entirely.
Without setting CPPFLAGS or CFLAGS the configure should work.
-d
On 02/04/2010 11:28 AM, Darius Buntinas wrote:
> Hi Joe,
> This looks to be a problem with how we're using configure. We're working
> on it. Sorry, I'm not sure what a good work around would be right now.
> -d
> On 02/03/2010 07:58 PM, Joe Buck wrote:
>> I'm trying to compile mpich2-1.2.1 on an ubuntu 9.10 server running on
>> x86_64 hardware and I'm seeing an issue while running configure. The
>> error I get looks like this:
>> checking for OpenPA atomic primitive availability... no
>> configure: error:
>> The nemesis channel was selected yet a set of working OpenPA headers
>> were not found. Please check the OpenPA configure step for errors.
>> configure: error: ./configure failed for channels/nemesis
>> configure: error: Configure of src/mpid/ch3 failed!
>> I'm attaching the entire ./configure output. I looked through the
>> archives and found some mention of this but didn't see a solution to it.
>> Can anyone point me in a useful direction?
>> I've tried checking out the latest trunk and building that with the
>> following tools:
>> automake 1.11.1
>> autoconf 2.63
>> and libtool 2.2.6
>> as per this website:
>> http://wiki.mcs.anl.gov/mpich2/index.php/Getting_And_Building_MPICH2
>> as well as trying to build the stable mpich2-1.2.1 tarball with the
>> tools that ubuntu 9.10 comes with.
>> Thanks for the help,
>> -Joe Buck
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
