[mpich-discuss] Error in the mpdboot step
Prashantha Hebbar prashantha.hebbar at manipal.edu
Thu Feb 4 03:48:52 CST 2010
Hi Pavan,
Thanks for all the help. Mpdboot -n <number> -f mpd.hosts & is working fine
now. There was some problem in host names and ssh authentification.
I tried with hydra. That too works fine.
Prashantha
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Pavan Balaji
Sent: Wednesday, February 03, 2010 10:14 PM
Subject: Re: [mpich-discuss] Error in the mpdboot step
Can you try the following:
% mpiexec.hydra -f mpd.hosts -n 2 hostname
 -- Pavan
On 02/03/2010 03:24 AM, Prashantha Hebbar wrote:
> Hi Pavan,
> I added new user with name mlscub1 to mlscub2-desktop and copied
mpi-install
> to the same. Then, did ssh-keygen as well. Still I find the same error.
> mlscub1 at mlscub1-desktop:~$ mpdboot -n 2 -f mpd.hosts
> unable to obtain IP for host: mlscub1 at mlscub1-desktop.local
> unable to obtain IP for host: mlscub1 at mlscub2-desktop.local
> totalnum=2  numhosts=1
> there are not enough hosts on which to start all processes
> Should I make any changes in any other file, other than /etc/hosts?
> Regards,
> Prashantha
> From: mpich-discuss-bounces at mcs.anl.gov
> Sent: Wednesday, February 03, 2010 1:03 PM
> On 02/03/2010 01:29 AM, Prashantha Hebbar wrote:
>> Yes, one with ssh mlscub1 at mlscub1-desktop.local and other with ssh
>> mlscub2 at mlscub2-desktop.local
> Ah. This can be problematic. It's recommended that you have a common
> setup on both machines. That is, same user names, and directory
> structure exporting the MPICH2 installation and executable in a common
> location.
> Most folks typically use a shared filesystem (such as NFS) which gives a
> common view of everything on all machines.
>  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
mpich-discuss mailing list
Attention:
This e-mail message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
Please do not print this email unless it is absolutely necessary.
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments.
WARNING: Computer viruses can be transmitted via email. The recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email.
www.manipal.edu
