[mpich-discuss] issue compiling mpich
chan at mcs.anl.gov chan at mcs.anl.gov
Thu Feb 4 02:19:18 CST 2010
Unset your CFLAGS and CPPFLAGS in your configure command
and try again.  Largefile support is enabled by default if
it is available.  CPPFLAGS stands for "C PreProcessor FLAGS"
not "C++ FLAGS"  Setting it incorrectly is the likely reason
of your configure failure.
A.Chan
----- "Joe Buck" <jbbuck at gmail.com> wrote:
> I'm trying to compile mpich2-1.2.1 on an ubuntu 9.10 server running
> on
> x86_64 hardware and I'm seeing an issue while running configure. The
> error I
> get looks like this:
> checking for OpenPA atomic primitive availability... no
> configure: error:
> The nemesis channel was selected yet a set of working OpenPA headers
> were not found.  Please check the OpenPA configure step for errors.
> configure: error: ./configure failed for channels/nemesis
> configure: error: Configure of src/mpid/ch3 failed!
> I'm attaching the entire ./configure output. I looked through the
> archives
> and found some mention of this but didn't see a solution to it. Can
> anyone
> point me in a useful direction?
> I've tried checking out the latest trunk and building that with the
> following tools:
> automake 1.11.1
> autoconf 2.63
> and libtool 2.2.6
> as per this website:
> http://wiki.mcs.anl.gov/mpich2/index.php/Getting_And_Building_MPICH2
> as well as trying to build the stable mpich2-1.2.1 tarball with the
> tools
> that ubuntu 9.10 comes with.
> Thanks for the help,
> -Joe Buck
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
