[mpich-discuss] Error in the mpdboot step
Prashantha Hebbar prashantha.hebbar at manipal.edu
Wed Feb 3 01:42:33 CST 2010
Ok. I faced this problem too, when executing mpiexec. Later, got into
example directory and executed. So, worked out.
Thanks for all the help. I will work towards that.
Prashantha
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Pavan Balaji
Sent: Wednesday, February 03, 2010 1:03 PM
Subject: Re: [mpich-discuss] Error in the mpdboot step
On 02/03/2010 01:29 AM, Prashantha Hebbar wrote:
> Yes, one with ssh mlscub1 at mlscub1-desktop.local and other with ssh
> mlscub2 at mlscub2-desktop.local
Ah. This can be problematic. It's recommended that you have a common
setup on both machines. That is, same user names, and directory
structure exporting the MPICH2 installation and executable in a common
location.
Most folks typically use a shared filesystem (such as NFS) which gives a
common view of everything on all machines.
 -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
mpich-discuss mailing list
Attention:
This e-mail message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
Please do not print this email unless it is absolutely necessary.
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments.
WARNING: Computer viruses can be transmitted via email. The recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email.
www.manipal.edu
