[mpich-discuss] X11 and mpich2 - passing environment variables with a colon in the name
Dave Goodell goodell at mcs.anl.gov
Tue Feb 2 16:44:02 CST 2010
On Feb 2, 2010, at 4:17 PM, John Watts wrote:
> Thanks for the suggestion, but that gives the same result.   However
> (as so often happens...) having searched the internet for days, and
> then submitted this question, I find the answer within the hour...
> If you want to define the environment variable DISPLAY for an X11
> process, use the full <hostname:m.n> format, eg -env DISPLAY
> localhost:0.0.   Another example:  /cygdrive/c/mpich2/bin/
> mpiexec.exe -env DISPLAY GibbonRd-T40:0.0 -n $1 executable_name.exe
John, I'm glad you found a workaround.
This appears to be an SMPD-only limitation.  MPD and Hydra do the
right thing when there is a colon in the environment variable value,
at least when using the trunk on my Mac.  That is, they separate MPMD
executables by exactly ":" as a token.
(bare mpiexec is hydra's mpiexec)
--------8<-------
% cat quux.sh
#!/bin/sh
echo VAL=$VAL
% ./quux.sh
VAL=
% VAL=:foo ./quux.sh
VAL=:foo
% mpiexec -env VAL :foo -n 1 ./quux.sh
VAL=:foo
% mpiexec.mpd  -env VAL :foo -n 1 ./quux.sh
VAL=:foo
--------8<-------
-Dave
