[mpich-discuss] static compiling with mpich2
Dave Goodell
goodell at mcs.anl.gov
Mon Feb 1 14:48:51 CST 2010
So I misunderstood your original question. We don't usually link
statically by using the "-static" flag to gcc/gfortran/etc. Some
googling around turned up the following two relevant pages:
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=33581
http://www.mail-archive.com/gcc@gcc.gnu.org/msg26770.html
The basic upshot of which was "don't use `-static', especially with
threads". When I said that we usually link statically, I meant that
we compile without "--enable-sharedlibs=...". That will generate a
static library archive (libmpich.a) for MPICH2, but the system
libraries will still be linked dynamically.
Jakub Jelinek proposes using "-Wl,--whole-archive -lnptl -Wl,--no-
whole-archive" to sort this out, but I don't know anything about this
solution. It sounds rather hack-ish to me.
-Dave
On Feb 1, 2010, at 2:29 PM, Jason Palmer wrote:
> So, the problem seems to be limited to gfortran (4.4.3) compiling with
> static and MPICH2 commands. I don't get any errors when compiling
> without
> -static.
> Gdb shows the main fortran executable dying in a thread mutex call
> inside a
> fotran io function:
> (gdb) run
> Starting program: /home/jason/amica_gcc/a.out
> [Thread debugging using libthread_db enabled]
> Program received signal SIGSEGV, Segmentation fault.
> 0x0000000000000000 in ?? ()
> (gdb) where
> #0 0x0000000000000000 in ?? ()
> #1 0x000000000047c203 in __gthread_mutex_trylock (n=6, do_create=1)
> at
> ../../../gcc-4.4.3/libgfortran/../gcc/gthr-posix.h:767
> #2 get_external_unit (n=6, do_create=1) at
> ../../../gcc-4.4.3/libgfortran/io/unit.c:330
> #3 0x000000000047aa0f in data_transfer_init (dtp=0x7fffffffe0c0,
> read_flag=0) at ../../../gcc-4.4.3/libgfortran/io/transfer.c:2017
> #4 0x0000000000400302 in MAIN__ ()
> #5 0x000000000047627a in main (argc=1, argv=0x7fffffffe5b8) at
> ../../../gcc-4.4.3/libgfortran/fmain.c:21
> I recompiled gcc without --enable threads=posix, and I get the same
> error. I
> get no errors when building gcc.
> I get the exact same seg fault in examples, same time in execution,
> when I
> run the f90pi example program compiled with -static.
> Example f90pi compiles and runs when compiled without -static, but
> it still
> has io issues--it doesn't print anything on the scree until <enter> is
> typed, then it prints the usual input message but immediately exits
> (without
> error).
> On the other hand, with cpi and cxxpi, everything works fine with or
> without
> static.
> I ran make testing, and got the following io related problems:
> Processing directory coll
> Looking in ./coll/testlist
> Unexpected output in bcast2: mpiexec_juggling.ucsd.edu
> (handle_sig_occurred
> 1144): job ending due to env var MPIEXEC_TIMEOUT=420
> Program bcast2 exited without No Errors
> Unexpected output in bcast3: mpiexec_juggling.ucsd.edu
> Program bcast3 exited without No Errors
> Processing directory io
> Looking in ./f77/io/testlist
> Unexpected output in iwriteatf: mpiexec_juggling.ucsd.edu
> (handle_sig_occurred 1144): job ending due to env var
> MPIEXEC_TIMEOUT=180
> Program iwriteatf exited without No Errors
> ... 11 more identical errors in ./f77/io/testlist for similar
> functions
> Looking in ./cxx/io/testlist
> Unexpected output in iwriteatx: mpiexec_juggling.ucsd.edu
> MPIEXEC_TIMEOUT=180
> Program iwriteatx exited without No Errors
> ... 23 more identical erros in ./cxx/io/testlist for similar functions
> Processing directory threads
> Looking in ./threads/testlist
> Processing directory pt2pt
> Looking in ./threads/pt2pt/testlist
> Unexpected output in threads: mpiexec_juggling.ucsd.edu
> 1144): job ending due to env var MPIEXEC_TIMEOUT=600
> Program threads exited without No Errors
> Some programs (threads) may still be running:
> pids = 14676
> The executable (threads) will not be removed.
> Unexpected output in multisend4: mpiexec_juggling.ucsd.edu
> MPIEXEC_TIMEOUT=180
> Program multisend4 exited without No Errors
> Processing directory comm
> Looking in ./threads/comm/testlist
> Processing directory init
> Looking in ./threads/init/testlist
> Processing directory spawn
> Looking in ./threads/spawn/testlist
> 41 tests failed out of 580
> So apparently cxx is having io issues as well, but I didn't get any
> erros on
> cxxpi with -static.
> I'm using gcc-4.4.3 (and latest gmp, mpfr, and mpc) and Mpich2-1.2.1
> on an
> x86_64-linux host (AMD Opteron).
> Has anyone else used gfortran 4.4.3 to compile Mpich2 programs
> statically?
> Again, the above testing errors notwithstanding, things seem to work
> when
> compiled dynamically, and when using c or cxx with or without static.
> Also, my test program (MPI_INIT + print + MPI_FINALIZE) compiles and
> runs
> successfully when the MPI calls are commented out (using -static and
> mpif90)
> so the problem doesn't seem to be limited to gfortran and static,
> but seems
> to involve gfortran, static, mpich2, and possibly threads.
> Maybe I should try explicitly disabling threads?
> Thanks again for your help!
> Jason
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev Thakur
> Sent: Friday, January 29, 2010 5:26 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] static compiling with mpich2
> You can also run "make testing" in the top-level mpich2 directory,
> which
> will run the entire test suite in test/mpi, including a whole bunch of
> f90 tests (can take an hour or more).
> A simpler first step may be to run the example in examples/f90
> Rajeev
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jason Palmer
>> Sent: Friday, January 29, 2010 6:17 PM
>> The problem does seem to be related to MPICH and/or gcc with
>> static compilation ... oddly, I only get a seg fault when I
>> try to print (to
>> stdout) and execute an MPI instruction, but either alone works.
>> I can compile using mpif90 with or without -static.
>> In the following simple fortran program:
>> program main
>> use mpi
>> implicit none
>> integer :: ierr
>> print *, 'This is a test ...'
>> call MPI_INIT(ierr)
>> call MPI_FINALIZE(ierr)
>> end program
>> when compiled with MPICH2 mpif90 and gcc-4.4.3, and -static,
>> no optimization, I get a seg fault.
>> If I comment out the print statement, there is no error (even
>> with static compile).
>> If I comment out the MPI statements, the print statement
>> works and no error (even though compiled with mpif90).
>> I get the error both with the "use mpi" and include mpif.h.
>> I re-compiled MPICH2 without --enable-fast, and with
>> --enable-g=dbg and --enable-debug-info (I got a compile error
>> when I tried to use --enable-error-checking complaining about
>> and unknown error number).
>> I ran gdb, and the seg fault happens during a return from a
>> thread mutex call. I compiled gcc with enable-threads=posix,
>> but there is no explicit threading in my code here.
>> The MPI routines work fine with static and no print
>> statement, and vice-versa. And somehow the combination seems
>> to die in a thread call.
>> I will try recompiling gcc without --enable-threads=posix to
>> see what that does (assuming no immediate fixes are forthcoming.)
>> Thanks for your help.
>> Jason
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
>> Sent: Friday, January 29, 2010 1:21 PM
>> We (the MPICH2 developers) primarily compile statically and
>> we definitely use static libraries in many of our nightly
>> tests. GCC is also well tested with MPICH2 and is totally
>> compatible on most platforms.
>> Have you used gdb or valgrind to determine where/why the
>> segfault is occurring?
>> If the segfault is coming from within MPICH2, can you try
>> configuring with "--enable-g=dbg --enable-error-checking" and
>> *without* any "-- enable-fast" arguments? Versions of MPICH2
>> built for performance are much less forgiving of errors in
>> application code.
>> -Dave
>> On Jan 29, 2010, at 3:03 PM, Jason Palmer wrote:
>>> Hi all,
>>> We recently switched from Mpich1 to Mpich2 as part of a general
>>> upgrade, and I'm re-building a program that was previously
>> compiled as
>>> a static binary under Mpich1 on 64-bit RedHat Linux using pathscale
>>> fortran on an AMD Opteron cluster.
>>> We are now using gcc-4.4.3 (instead of pathscale), and I
>> can compile
>>> and run the code with dynamic libraries, but when I compile with -
>>> static, the compile succeeds, but the binary gives a segmentation
>>> fault when executed, with or without mpiexec.
>>> I have tried compiling Mpich2 (using gcc 4.4.3) both with -enable-
>>> sharedlibs=gcc and without, but both give the error in the static
>>> version but no error in the non-static version.
>>> Has anyone had success with static compiling of Mpich2 /
>> gcc programs?
>>> Thanks,
>>> Jason
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
