[mpich-discuss] FW: MPICH1.2.1 Install Problem on Linux RedhatEnterprise 4 64 bit
Woods, Andrew Andrew.Woods at ATK.COM
Mon Feb 1 08:34:16 CST 2010
Dave,
Thanks for your reply.
The trac system will not allow me to include test from the console
showing the error nor to attach files, so I am sending this to you
directly from a subsequent try:
 Console output near end of failed 1.2.1 Mpich2 install on Linux Redhat
4 64
    done ; \
fi
make[2]: *** No rule to make target
`/home/magic/mpich2_install/mpich2-1.2.1/src/pm/hydra/ui/mpiexec/callbac
k.c', needed by `mpiexec-callback.o'.  Stop.
make[2]: Entering directory `/tmp/bldmpich/src/pm/hydra'
make[2]: Leaving directory `/tmp/bldmpich/src/pm/hydra'
make[2]: Entering directory `/tmp/bldmpich/src/pm/gforker'
  CC
/home/magic/mpich2_tar/mpich2-1.2.1/src/pm/gforker/mpiexec.c
cd ../util && make
make[3]: Entering directory `/tmp/bldmpich/src/pm/util'
  CC
/home/magic/mpich2_tar/mpich2-1.2.1/src/pm/gforker/../util/cmnargs.c
  CC
/home/magic/mpich2_tar/mpich2-1.2.1/src/pm/gforker/../util/process.c
  CC
/home/magic/mpich2_tar/mpich2-1.2.1/src/pm/gforker/../util/ioloop.c
  CC
/home/magic/mpich2_tar/mpich2-1.2.1/src/pm/gforker/../util/pmiserv.c
  CC
/home/magic/mpich2_tar/mpich2-1.2.1/src/pm/gforker/../util/labelout.c
  CC
/home/magic/mpich2_tar/mpich2-1.2.1/src/pm/gforker/../util/env.c
  CC
/home/magic/mpich2_tar/mpich2-1.2.1/src/pm/gforker/../util/newsession.c
  CC
/home/magic/mpich2_tar/mpich2-1.2.1/src/pm/gforker/../util/rm.c
  CC
/home/magic/mpich2_tar/mpich2-1.2.1/src/pm/gforker/../util/pmiport.c
  CC
/home/magic/mpich2_tar/mpich2-1.2.1/src/pm/gforker/../util/dbgiface.c
  AR cr libmpiexec.a cmnargs.o process.o ioloop.o pmiserv.o labelout.o
env.o newsession.o rm.o pmiport.o dbgiface.o
  RANLIB          libmpiexec.a
make[3]: Leaving directory `/tmp/bldmpich/src/pm/util'
gcc -O2    -o mpiexec mpiexec.o  \
../util/libmpiexec.a ../../../lib/libmpich.a -lpthread   -lrt
gcc: ../../../lib/libmpich.a: No such file or directory
make[2]: *** [mpiexec] Error 1
make[2]: Leaving directory `/tmp/bldmpich/src/pm/gforker'
make[1]: Leaving directory `/tmp/bldmpich'
/usr/bin/install -c -m 644 src/include/mpi.h
/usr/local/mpich2-1.2.1/include/mpi.h
/usr/bin/install -c -m 644 lib/libmpich.a
/usr/local/mpich2-1.2.1/lib/libmpich.a
/usr/bin/install: cannot stat `lib/libmpich.a': No such file or
directory
make: *** [install] Error 1
Thanks for any help you can give.
Andy Woods
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
Sent: Friday, January 29, 2010 3:06 PM
Subject: Re: [mpich-discuss] FW: MPICH1.2.1 Install Problem on Linux
Hi Andrew,
Would you please file this information as a ticket in our bug tracking
system?
https://trac.mcs.anl.gov/projects/mpich2/newticket
Also, please attach the c.txt, m.txt, and config.log files that you
mention below to the ticket.
We've had one previous report with similar error messages, but it's
difficult to figure out exactly what's going wrong in this case
without a bit more digging and back-and-forth communication.  Putting
it in a bug report will keep the attachments out of everyone's mailbox
and will make it easier for me to keep track of the issue.
There's probably a programming error in that code somewhere that stems
from a bad assumption.  However because that code makes heavy use of
macros it's not obvious what's happening without expanding all the
macros.  We can talk about it more in the ticket.
-Dave
On Jan 29, 2010, at 9:31 AM, Woods, Andrew wrote:
> I have now subscribed.
> Thanks,
> Andy Woods
> From: Woods, Andrew
> Sent: Friday, January 29, 2010 10:08 AM
> Subject: MPICH1.2.1 Install Problem on Linux Redhat Enterprise 4 64
> bit
> Dear Mpich helpers:
> I am attempting to install MPICH1.2.1 on Linux Redhat Enterprise 4
> 64 bit and the following error occurs after make VERBOSE=1 |tee m.txt:
> -DHAVE_CONFIG_H -I. -I/home/magic/mpich2_install/mpich2-1.2.1/src/
> mpi/coll -I../../include -I/home/magic/mpich2_install/mpich2-1.2.1/
> src/include -I/home/magic/mpich2_install/mpich2-1.2.1/src/mpi/
> datatype -O2 -I/home/magic/mpich2_install/mpich2-1.2.1/src/openpa/
> src -I/tmp/bldmpich/src/openpa/src -DUSE_PROCESS_LOCKS -I/tmp/
> bldmpich/src/mpid/ch3/include -I/home/magic/mpich2_install/
> mpich2-1.2.1/src/mpid/ch3/include -I/tmp/bldmpich/src/mpid/common/
> datatype -I/home/magic/mpich2_install/mpich2-1.2.1/src/mpid/common/
> datatype -I/tmp/bldmpich/src/mpid/common/locks -I/home/magic/
> mpich2_install/mpich2-1.2.1/src/mpid/common/locks -I/tmp/bldmpich/
> src/mpid/ch3/channels/nemesis/include -I/home/magic/mpich2_install/
> mpich2-1.2.1/src/mpid/ch3/channels/nemesis/include -I/tmp/bldmpich/
> src/mpid/ch3/channels/nemesis/nemesis/include -I/home/magic/
> mpich2_install/mpich2-1.2.1/src/mpid/ch3/channels/nemesis/nemesis/
> include -I/tmp/bldmpich/src/mpid/ch3/channels/nemesis/nemesis/utils/
> monitor -I/home/magic/mpich2_install/mpich2-1.2.1/src/mpid/ch3/
> channels/nemesis/nemesis/utils/monitor -I/tmp/bldmpich/src/mpid/
> common/locks -I/home/magic/mpich2_install/mpich2-1.2.1/src/mpid/
> common/locks -I/tmp/bldmpich/src/util/wrappers -I/home/magic/
> mpich2_install/mpich2-1.2.1/src/util/wrappers -c /home/magic/
> mpich2_install/mpich2-1.2.1/src/mpi/coll/opsum.c
> /home/magic/mpich2_install/mpich2-1.2.1/src/mpi/coll/opsum.c: In
> function `MPIR_SUM':
> /home/magic/mpich2_install/mpich2-1.2.1/src/mpi/coll/opsum.c:57:
> error: duplicate case value
> error: previously used here
> function `MPIR_SUM_check_dtype':
> /home/magic/mpich2_install/mpich2-1.2.1/src/mpi/coll/opsum.c:92:
> make[3]: *** [opsum.o] Error 1
> make[3]: Leaving directory `/tmp/bldmpich/src/mpi/coll'
> make[2]: *** [all-redirect] Error 2
> make[2]: Leaving directory `/tmp/bldmpich/src/mpi'
> make[1]: *** [all-redirect] Error 2
> make[1]: Leaving directory `/tmp/bldmpich/src'
> make: *** [all-redirect] Error 2
> [root at VA90S-OPTERON-LINUX bldmpich]# pwd
> /tmp/bldmpich
> [root at VA90S-OPTERON-LINUX bldmpich]# make VERBOSE=1 |tee m.txt
> Build steps were:
> tar xfz /home/magic/mpich2_install/mpich2-1.2.1.tar.tar
> /home/magic/mpich2_install/mpich2-1.2.1/configure -prefix=/usr/local/
> mpich2/ |tee c.txt
> make | tee m.txt
> make install | tee mi.txt
> in build directory:
> /tmp/bldmpich
> Can you please advise on this?
> Thanks,
> Andrew J. Woods
> Sr. Scientist/Engineer
> MAGIC Tool Suite Development Team
> http://www.magictoolsuite.com
> Alliant Techsystems (ATK)
> 8560 Cinderbed Road, Suite 700
> Newington, VA, USA 22122
> (703) 254 2416
> Fax: (703) 339 6953
> (Andrew.Woods at atk.com)
> mpich-discuss mailing list
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100201/96acf0ff/attachment-0002.txt>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100201/96acf0ff/attachment-0003.txt>
Desc: config.log
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100201/96acf0ff/attachment-0001.obj>
