[mpich-discuss] Using MPI_Put/Get correctly?
Rajeev Thakur thakur at mcs.anl.gov
Wed Dec 29 00:58:34 CST 2010
Matt,
         The target_disp parameter to MPI_Put is of type integer (kind=MPI_ADDRESS_KIND). If I define a variable disp of that type, set it to 0, and pass it to MPI_Put (instead of directly passing 0), both examples work.
Rajeev
On Dec 27, 2010, at 4:29 PM, Grismer, Matthew J Civ USAF AFMC AFRL/RBAT wrote:
> I've created two example test programs that appear to highlight the issue
> with MPICH2; both die when I run them on 2 processors.  I am pretty certain
> the first (putoneway.f90) should work, as I am only doing a single put from
> one processor to a second processor; the target processor is doing nothing
> with the window'ed array that is receiving the data. My guess is the problem
> lies in the indexed datatypes that I am using for both the origin and
> target.
> The second case (putbothways.f90) closely mirrors what I am actually trying
> to do in my code, that is have each processor put into the other processors
> window'ed array at the same time.  So, each process is sending from and
> receiving into the same array at the same time, with no overlap in the sent
> and received data.  Once again I'm using indexed data types for both the
> origin and target.
> To build:  mpif90 putoneway.f90
> To run:  mpiexec -np 2 a.out
> Matt
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
> Sent: Thursday, December 16, 2010 4:45 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Using MPI_Put/Get correctly?
> That must be a bug in MPICH2.  The name of the routine is helpful, but your
> MPICH2 isn't built with debug information, so it's a bit harder to tell what
> part of that function is causing the trouble.  Also, a stack trace with line
> numbers would be helpful.
> As Rajeev mentioned before, a small test program would really help us
> troubleshoot this.  It can be very difficult to find/fix this sort of thing
> over email.
> -Dave
> On Dec 16, 2010, at 3:35 PM CST, Grismer, Matthew J Civ USAF AFMC AFRL/RBAT
> wrote:
>> I attached to the running processes with gdb, and get the following
>> error when the code dies:
>> Program received signal EXC_BAD_ACCESS, Could not access memory.
>> Reason:  13 at address 0x00000000000
>> 0x000000010040a5e5 in MPID_Segment_blkidx_m2m ()
>> if that is any help at all...
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of James Dinan
>> Sent: Thursday, December 16, 2010 3:28 PM
>> Hi Matt,
>> If my understanding is correct, the only time you are allowed to perform
>> direct load/store accesses on local data that is exposed in a window is
>> when the window is closed under active target or when you are in an
>> exclusive access epoch under passive mode target.  So I think what you
>> are doing may be invalid even though you are able to guarantee that
>> accesses do not overlap.  The source for your put will need to be a
>> private buffer, you may be able to accomplish this easily in your code
>> or you might have to copy data into a private buffer (before you post
>> the window) before you can put().
>> Even though this is outside of the standard, some (many?) MPI
>> implementations may actually allow this on cache-coherent systems (I
>> think MPICH2 on shared memory will allow it).
>> I would be surprised if this error is causing your seg fault (more
>> likely it should just result in corrupted data within the bounds of your
>> buffer).  I would tend to suspect that something is off in your
>> datatype, possibly the target datatype since the segfault occurs in
>> wait() which is when data might be getting unpacked at the target.  Can
>> you run your code through a debugger or valgrind to give us more
>> information on how/when the seg faul occurs?
>> Cheers,
>> ~Jim.
>> On 12/16/2010 12:33 PM, Grismer, Matthew J Civ USAF AFMC AFRL/RBAT
>> wrote:
>>> I am trying to modify the communication routines in our code to use
>>> MPI_Put's instead of sends and receives.  This worked fine for several
>>> variable Put's, but now I have one that is causing seg faults. Reading
>>> through the MPI documentation it is not clear to me if what I am doing
>>> is permissible or not.  Basically, the question is this - if I have
>>> defined all of an array as a window on each processor, can I PUT data
>>> from that array to remote processes at the same time as the remote
>>> processes are PUTing into the local copy, assuming no overlaps of any
>> of
>>> the PUTs?
>>> Here are the details if that doesn't make sense.  I have a (Fortran)
>>> array QF(6,2,N) on each processor, where N could be a very large
>> number
>>> (100,000). I create a window QFWIN on the entire array on all the
>>> processors.  I define MPI_Type_indexed "sending" datatypes (QFSND)
>> with
>>> block lengths of 6 that send from QF(1,1,*), and MPI_Type_indexed
>>> "receiving" datatypes (QFREC) with block lengths of 6 the receive into
>>> QF(1,2,*).  Here * is non-repeating set of integers up to N.  I create
>>> groups of processors that communicate, where these groups will all
>>> exchange QF data, PUTing local QF(1,1,*) to remote QF(1,2,*).  So,
>>> processor 1 is PUTing QF data to processors 2,3,4 at the same time
>> 2,3,4
>>> are putting their QF data to 1, and so on.  Processors 2,3,4 are
>> PUTing
>>> into non-overlapping regions of QF(1,2,*) on 1, and 1 is PUTing from
>>> QF(1,1,*) to 2,3,4, and so on.  So, my calls look like this on each
>>> processor:
>>> assertion = 0
>>> call MPI_Win_post(group, assertion, QFWIN, ierr)
>>> call MPI_Win_start(group, assertion, QFWIN, ierr)
>>> do I=1,neighbors
>>>  call MPI_Put(QF, 1, QFSND(I), NEIGHBOR(I), 0, 1, QFREC(I), QFWIN,
>>> ierr)
>>> end do
>>> call MPI_Win_complete(QFWIN,ierr)
>>> call MPI_Win_wait(QFWIN,ierr)
>>> Note I did define QFREC locally on each processor to properly
>> represent
>>> where the data was going on the remote processors.  The error value
>>> ierr=0 after MPI_Win_post, MPI_Win_start, MPI_Put, and
>> MPI_Win_complete,
>>> and the code seg faults in MPI_Win_wait.
>>> I'm using MPICH2 1.3.1 on Mac OS X 10.6.5, built with Intel XE (12.0)
>>> compilers, and running on just 2 (internal) processors of my Mac Pro.
>>> The code ran normally with this configuration up until the point I put
>>> the above in.  Several other communications with MPI_Put similar to
>> the
>>> above work fine, though the windows are only on a subset of the
>>> communicated array, and the origin data is being PUT from part of the
>>> array that is not within the window.
>>> _____________________________________________________
>>> Matt
>>> mpich-discuss mailing list
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> <putoneway.f90><putbothways.f90>_______________________________________________
