[mpich-discuss] Using MPI_Put/Get correctly?
Grismer, Matthew J Civ USAF AFMC AFRL/RBAT Matthew.Grismer at wpafb.af.mil
Mon Dec 27 10:42:27 CST 2010
I rebuilt using --with-device=ch3:sock, and it dies in exactly the same
place, same routine...
Matt
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev Thakur
Sent: Tuesday, December 21, 2010 9:51 AM
Subject: Re: [mpich-discuss] Using MPI_Put/Get correctly?
You could also try configuring MPICH2 with --with-device=ch3:sock. That
will use a different communication method and will help narrow down the
problem.
Rajeev
On Dec 17, 2010, at 2:59 PM, Grismer, Matthew J Civ USAF AFMC AFRL/RBAT
wrote:
> I rebuilt MPICH2 with debugging support, so I get some more detail on
> the error point from gdb:
> Program received signal EXC_BAD_ACCESS, Could not access memory.
> Reason: 13 at address: 0x0000000000000000
> 0x000000010040a645 in MPID_Segment_blkidx_m2m
(blocks_p=0x7fff5fbfd328,
> count=1606407072, blocklen=3138, offsetarray=0x6, el_type=8847888,
> rel_off=4310413312, bufp=0x6000218000000000, v_paramp=0x7fff5fbfd3a0)
at
> segment_packunpack.c:313
> 313		    MPIDI_COPY_FROM_VEC(src, dest, 0, int64_t, blocklen,
> 1);
> (gdb) list
> 308
> 309		/* note: macro modifies dest buffer ptr, so we must
> reset */
> 310		if (el_size == 8
> 311		    MPIR_ALIGN8_TEST(src, dest))
> 312		{
> 1);
> 314		}
> 315		else if (el_size == 4
> 316			 MPIR_ALIGN4_TEST(src,dest))
> 317		{
> Also, I'm trying to come up with a small sample that demonstrates the
> issue.
> Matt
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
> Sent: Thursday, December 16, 2010 4:45 PM
> That must be a bug in MPICH2.  The name of the routine is helpful, but
> your MPICH2 isn't built with debug information, so it's a bit harder
to
> tell what part of that function is causing the trouble.  Also, a stack
> trace with line numbers would be helpful.
> As Rajeev mentioned before, a small test program would really help us
> troubleshoot this.  It can be very difficult to find/fix this sort of
> thing over email.
> -Dave
> On Dec 16, 2010, at 3:35 PM CST, Grismer, Matthew J Civ USAF AFMC
> AFRL/RBAT wrote:
>> I attached to the running processes with gdb, and get the following
>> error when the code dies:
>> Reason:  13 at address 0x00000000000
>> 0x000000010040a5e5 in MPID_Segment_blkidx_m2m ()
>> if that is any help at all...
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of James Dinan
>> Sent: Thursday, December 16, 2010 3:28 PM
>> Hi Matt,
>> If my understanding is correct, the only time you are allowed to
> perform
>> direct load/store accesses on local data that is exposed in a window
> is
>> when the window is closed under active target or when you are in an
>> exclusive access epoch under passive mode target.  So I think what
you
>> are doing may be invalid even though you are able to guarantee that
>> accesses do not overlap.  The source for your put will need to be a
>> private buffer, you may be able to accomplish this easily in your
code
>> or you might have to copy data into a private buffer (before you post
>> the window) before you can put().
>> Even though this is outside of the standard, some (many?) MPI
>> implementations may actually allow this on cache-coherent systems (I
>> think MPICH2 on shared memory will allow it).
>> I would be surprised if this error is causing your seg fault (more
>> likely it should just result in corrupted data within the bounds of
> your
>> buffer).  I would tend to suspect that something is off in your
>> datatype, possibly the target datatype since the segfault occurs in
>> wait() which is when data might be getting unpacked at the target.
> Can
>> you run your code through a debugger or valgrind to give us more
>> information on how/when the seg faul occurs?
>> Cheers,
>> ~Jim.
>> On 12/16/2010 12:33 PM, Grismer, Matthew J Civ USAF AFMC AFRL/RBAT
>> wrote:
>>> I am trying to modify the communication routines in our code to use
>>> MPI_Put's instead of sends and receives.  This worked fine for
> several
>>> variable Put's, but now I have one that is causing seg faults.
> Reading
>>> through the MPI documentation it is not clear to me if what I am
> doing
>>> is permissible or not.  Basically, the question is this - if I have
>>> defined all of an array as a window on each processor, can I PUT
data
>>> from that array to remote processes at the same time as the remote
>>> processes are PUTing into the local copy, assuming no overlaps of
any
>> of
>>> the PUTs?
>>> Here are the details if that doesn't make sense.  I have a (Fortran)
>>> array QF(6,2,N) on each processor, where N could be a very large
>> number
>>> (100,000). I create a window QFWIN on the entire array on all the
>>> processors.  I define MPI_Type_indexed "sending" datatypes (QFSND)
>> with
>>> block lengths of 6 that send from QF(1,1,*), and MPI_Type_indexed
>>> "receiving" datatypes (QFREC) with block lengths of 6 the receive
> into
>>> QF(1,2,*).  Here * is non-repeating set of integers up to N.  I
> create
>>> groups of processors that communicate, where these groups will all
>>> exchange QF data, PUTing local QF(1,1,*) to remote QF(1,2,*).  So,
>>> processor 1 is PUTing QF data to processors 2,3,4 at the same time
>> 2,3,4
>>> are putting their QF data to 1, and so on.  Processors 2,3,4 are
>> PUTing
>>> into non-overlapping regions of QF(1,2,*) on 1, and 1 is PUTing from
>>> QF(1,1,*) to 2,3,4, and so on.  So, my calls look like this on each
>>> processor:
>>> assertion = 0
>>> call MPI_Win_post(group, assertion, QFWIN, ierr)
>>> call MPI_Win_start(group, assertion, QFWIN, ierr)
>>> do I=1,neighbors
>>>  call MPI_Put(QF, 1, QFSND(I), NEIGHBOR(I), 0, 1, QFREC(I), QFWIN,
>>> ierr)
>>> end do
>>> call MPI_Win_complete(QFWIN,ierr)
>>> call MPI_Win_wait(QFWIN,ierr)
>>> Note I did define QFREC locally on each processor to properly
>> represent
>>> where the data was going on the remote processors.  The error value
>>> ierr=0 after MPI_Win_post, MPI_Win_start, MPI_Put, and
>> MPI_Win_complete,
>>> and the code seg faults in MPI_Win_wait.
>>> I'm using MPICH2 1.3.1 on Mac OS X 10.6.5, built with Intel XE
(12.0)
>>> compilers, and running on just 2 (internal) processors of my Mac
Pro.
>>> The code ran normally with this configuration up until the point I
> put
>>> the above in.  Several other communications with MPI_Put similar to
>> the
>>> above work fine, though the windows are only on a subset of the
>>> communicated array, and the origin data is being PUT from part of
the
>>> array that is not within the window.
>>> _____________________________________________________
>>> Matt
>>> mpich-discuss mailing list
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
