[mpich-discuss] (no subject)
    David.Perron at ch2m.com
    Fri Dec 17 18:52:25 CST 2010
I have used MPICH2 on several computers and clusters in the past to run the Fire Dynamics Simulator (FDS) CFD software but am having issues with a new computer. The below message is generated:
Fatal error in PMPI_Gatherv: Internal MPI error!, error stack:
PMPI_Gatherv(376).....: MPI_Gatherv failed(sbuf=000000003C07F858, scount=1, MPI_
DOUBLE_PRECISION, rbuf=000000003C07F858, rcnts=000000003C0EA8D8, displs=00000000
3C0EA998, MPI_DOUBLE_PRECISION, root=0, MPI_COMM_WORLD) failed
MPIR_Gatherv_impl(189):
MPIR_Gatherv(102).....:
MPIR_Localcopy(349)...: memcpy arguments alias each other, dst=000000003C07F858
src=000000003C07F858 len=8
Can you tell me what this means or what settings may need to be changed to allow MPICH2 to run? I am able to bypass the MPICH2 file path and run FDS on a single core so I am fairly certain that the issue is not with the FDS software.
David
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101217/1a494f0d/attachment.htm>
