[mpich-discuss] Parallel Jobs
Talla
jtalla at gmail.com
Fri Dec 17 06:10:25 CST 2010
Hello
Thank you very much for the detailed instructions. However, I am still lost
in this (I am just a beginner), do you have an example of .bashrc file? and
where exactely this file should be placed (I mean in the root dir or on my
home dir.?). because I think it is all about this file (I feel something
missing in it?) I am attaching a copy of that file so you may have some idea
what is going on.
Thank you very much,
On Fri, Dec 17, 2010 at 12:36 AM, Gus Correa <gus at ldeo.columbia.edu> wrote:
> Talla wrote:
>> Hello;
>> I build a cluster using Rocks/Open CentOS and I need to perform a parallel
>> jobn it, therefore I am looking for complete instructions how to set up
>> MPICH to get it run correctly as I am struggling with it for while.
>> Your help is really appreciated, Cordially.
>> Hi
> I may have answered you in the Rocks list already.
> Anyway, there it goes again.
> 0) READ the MPICH2 Installation Guide and User Guide first.
> There are complete instructions there.
> Did you read them?
> 1) Install one (ONLY ONE) of the resource manager rolls: SGE or Torque.
> (I use and prefer Torque, which is simpler, but other people love SGE.)
> 2) Download the latest greatest MPICH2 tarball to /share/apps/mydownloads,
> and untar it (tar -zxvf mpich2-... ).
> Configure and install MPICH2 on /share/apps/mpich2.
> You can use gcc, g++, and gfortran compilers for this,
> something like this:
> configure --prefix=/share/apps/mpich2 CC=gcc CXX=g++ F77=gfortran
> F90=gfortran
> make
> make install
> 3) Set the environment varialbles in your .cshrc or .bashrc file
> (as a regular user, NOT root), so that:
> /share/apps/mpich2/bin is first in your PATH,
> /share/apps/mpich2/share/man is first in your MANPATH,
> /share/apps/mpich2/lib is first in your LD_LIBRARY_PATH.
> 4) Compile the cpi.c example in the "examples"
> directory in the MPICH2 *distribution* directory
> (i.e. /share/apps/mydownloads/mpich2-.../examples)
> using mpicc
> mpicc -o cpi cpi.c
> 5) Write a job submission script for it.
> Here is one for Torque:
> #PBS -N cpi
> #PBS -q default
> #PBS -l nodes=2:ppn=4 #example asking for 2 nodes with 4 cores each
> mpiexec.hydra -f $PBS_NODEFILE -np 8 cpi
> 6) Alternatively, if you don't want to use Torque or SGE, create a
> "mynodefile" according to the MPICH2, and launch the job
> directly on the command line:
> mpiexec.hydra -f mynodefile -np 8 cpi
> Also
> mpiexec.hydra --help
> will give you a lot of information about it.
> Good luck
> Gus Correa
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101217/5608c94b/attachment.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101217/5608c94b/attachment.obj>
