[mpich-discuss] Using MPI_Put/Get correctly?
James Dinan dinan at mcs.anl.gov
Thu Dec 16 16:07:59 CST 2010
Hi Matt,
Valgrind is an open source memory checker.  It will monitor all the
memory references that your program makes and look for errors -
accessing invalid memory, reading from uninitialized memory, double
frees, etc..
I don't know of any documentation, can anybody help us out?  This is how
I use valgrind, though there may be some better way:
$ mpiexec -np 2 valgrind ./mpi_program
Valgrind should label each line of output with the process ID so you can
untangle them afterwards.
  ~Jim.
On 12/16/2010 03:12 PM, Grismer, Matthew J Civ USAF AFMC AFRL/RBAT wrote:
> I haven't used valgrind before, can you point me to some documentation
> on how to use it with MPICH2?
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of James Dinan
> Sent: Thursday, December 16, 2010 3:28 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Using MPI_Put/Get correctly?
> Hi Matt,
> If my understanding is correct, the only time you are allowed to perform
> direct load/store accesses on local data that is exposed in a window is
> when the window is closed under active target or when you are in an
> exclusive access epoch under passive mode target.  So I think what you
> are doing may be invalid even though you are able to guarantee that
> accesses do not overlap.  The source for your put will need to be a
> private buffer, you may be able to accomplish this easily in your code
> or you might have to copy data into a private buffer (before you post
> the window) before you can put().
> Even though this is outside of the standard, some (many?) MPI
> implementations may actually allow this on cache-coherent systems (I
> think MPICH2 on shared memory will allow it).
> I would be surprised if this error is causing your seg fault (more
> likely it should just result in corrupted data within the bounds of your
> buffer).  I would tend to suspect that something is off in your
> datatype, possibly the target datatype since the segfault occurs in
> wait() which is when data might be getting unpacked at the target.  Can
> you run your code through a debugger or valgrind to give us more
> information on how/when the seg faul occurs?
> Cheers,
>    ~Jim.
> On 12/16/2010 12:33 PM, Grismer, Matthew J Civ USAF AFMC AFRL/RBAT
> wrote:
>> I am trying to modify the communication routines in our code to use
>> MPI_Put's instead of sends and receives.  This worked fine for several
>> variable Put's, but now I have one that is causing seg faults. Reading
>> through the MPI documentation it is not clear to me if what I am doing
>> is permissible or not.  Basically, the question is this - if I have
>> defined all of an array as a window on each processor, can I PUT data
>> from that array to remote processes at the same time as the remote
>> processes are PUTing into the local copy, assuming no overlaps of any
> of
>> the PUTs?
>> Here are the details if that doesn't make sense.  I have a (Fortran)
>> array QF(6,2,N) on each processor, where N could be a very large
> number
>> (100,000). I create a window QFWIN on the entire array on all the
>> processors.  I define MPI_Type_indexed "sending" datatypes (QFSND)
> with
>> block lengths of 6 that send from QF(1,1,*), and MPI_Type_indexed
>> "receiving" datatypes (QFREC) with block lengths of 6 the receive into
>> QF(1,2,*).  Here * is non-repeating set of integers up to N.  I create
>> groups of processors that communicate, where these groups will all
>> exchange QF data, PUTing local QF(1,1,*) to remote QF(1,2,*).  So,
>> processor 1 is PUTing QF data to processors 2,3,4 at the same time
> 2,3,4
>> are putting their QF data to 1, and so on.  Processors 2,3,4 are
> PUTing
>> into non-overlapping regions of QF(1,2,*) on 1, and 1 is PUTing from
>> QF(1,1,*) to 2,3,4, and so on.  So, my calls look like this on each
>> processor:
>> assertion = 0
>> call MPI_Win_post(group, assertion, QFWIN, ierr)
>> call MPI_Win_start(group, assertion, QFWIN, ierr)
>> do I=1,neighbors
>>     call MPI_Put(QF, 1, QFSND(I), NEIGHBOR(I), 0, 1, QFREC(I), QFWIN,
>> ierr)
>> end do
>> call MPI_Win_complete(QFWIN,ierr)
>> call MPI_Win_wait(QFWIN,ierr)
>> Note I did define QFREC locally on each processor to properly
> represent
>> where the data was going on the remote processors.  The error value
>> ierr=0 after MPI_Win_post, MPI_Win_start, MPI_Put, and
> MPI_Win_complete,
>> and the code seg faults in MPI_Win_wait.
>> I'm using MPICH2 1.3.1 on Mac OS X 10.6.5, built with Intel XE (12.0)
>> compilers, and running on just 2 (internal) processors of my Mac Pro.
>> The code ran normally with this configuration up until the point I put
>> the above in.  Several other communications with MPI_Put similar to
> the
>> above work fine, though the windows are only on a subset of the
>> communicated array, and the origin data is being PUT from part of the
>> array that is not within the window.
>> _____________________________________________________
>> Matt
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
