[mpich-discuss] Error running with hydra
Gaetano Bellanca
gaetano.bellanca at unife.it
Fri Dec 10 06:31:37 CST 2010
Dear Pavan,
this is my command for mpiexec.hydra:
mpiexec.hydra -bootstrap ssh -f machinefile -n 4 ./3dfdtd > run.txt <
/dev/null
and this is the one for mpd:
mpiexec -machinefile machinefile -n 4 ./3dfdtd > run.txt < /dev/null
I have been able to have the code running with hydra removing the <
/dev/null at the end of the script, that was added by one of my students
(I don't know why).
It seems to create some problems with hydra, but not with mpd.
We need to change from mpd (we use to run it at boot time as root) to
hydra because mpd daemons sometimes die without reasons on the slave
machines on this system (where we are using scientific linux). All is
regularly working with mpd on another cluster running ubuntu server 10.04.
Regards.
Gaetano
Il 10/12/2010 13:12, Pavan Balaji ha scritto:
> What is the *exact* command you gave?
> -- Pavan
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
>> Hi,
>> I'm having problems running a simulation with hydra.
>> By submitting a job to a queue system (pbs) with the command:
>> mpiexec-hydra -bootstrap ssh -f machinefile -n number_of_processors
>> name_exec
>> I'm receiving this message:
>> HYDU_create_process (./utils/launch/launch.c:69): execvp error on file
>> 4
>> (Permission denied).
>> The same code works on the same system using mpd .
>> Any idea?
>> Best regards.
>> Gaetano
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Gaetano Bellanca - Department of Engineering - University of Ferrara
Via Saragat, 1 - 44122 - Ferrara - ITALY
Voice (VoIP): +39 0532 974809 Fax: +39 0532 974870
mailto:gaetano.bellanca at unife.it
Costituzione della Repubblica - Art. 9.
La Repubblica promuove lo sviluppo della cultura e la ricerca scientifica e tecnica.
Tutela il paesaggio e il patrimonio storico e artistico della Nazione.
