[mpich-discuss] good system gone bad..
Darius Buntinas
buntinas at mcs.anl.gov
Mon Dec 6 16:53:29 CST 2010
Check that the hydra proxy installed (and accessible) on every node.
-d
On Dec 6, 2010, at 4:27 PM, SULLIVAN David (AREVA) wrote:
> All,
> I am trying to troubleshoot a problem with my MPICH2 install. I compiled version 1.30 with gcc and intel fortran. When I try to execute anything I am greeted with the following:
> bash: /global/mpich2-1.3/bin/hydra_pmi_proxy: No such file or directory
> It is lying though:
> total 2916
> -rwxr-xr-x 1 root root 1656 Dec 6 16:54 bt2line
> -rwxr-xr-x 1 root root 10008 Dec 6 16:54 check_callstack
> -rwxr-xr-x 1 root root 56622 Dec 6 16:54 clog2_join
> -rwxr-xr-x 1 root root 1970 Dec 6 16:54 clog2print
> -rwxr-xr-x 1 root root 53798 Dec 6 16:54 clog2_print
> -rwxr-xr-x 1 root root 53799 Dec 6 16:54 clog2_repair
> -rwxr-xr-x 1 root root 1959 Dec 6 16:54 clog2TOslog2
> -rwxr-xr-x 1 root root 1960 Dec 6 16:54 clogprint
> -rwxr-xr-x 1 root root 1956 Dec 6 16:54 clogTOslog2
> -rwxr-xr-x 1 root root 84887 Dec 6 16:54 hwloc-bind
> -rwxr-xr-x 1 root root 83889 Dec 6 16:54 hwloc-calc
> -rwxr-xr-x 1 root root 79196 Dec 6 16:54 hwloc-distrib
> lrwxrwxrwx 1 root root 6 Dec 6 16:54 hwloc-info -> lstopo
> lrwxrwxrwx 1 root root 6 Dec 6 16:54 hwloc-ls -> lstopo
> lrwxrwxrwx 1 root root 10 Dec 6 16:54 hwloc-mask -> hwloc-calc
> -rwxr-xr-x 1 root root 422199 Dec 6 16:54 hydra_nameserver
> -rwxr-xr-x 1 root root 420869 Dec 6 16:54 hydra_persist
> -rwxr-xr-x 1 root root 586873 Dec 6 16:54 hydra_pmi_proxy
> -rwxr-xr-x 1 root root 1946 Dec 6 16:54 jumpshot
> -rwxr-xr-x 1 root root 1944 Dec 6 16:54 logconvertor
> -rwxr-xr-x 1 root root 136310 Dec 6 16:54 lstopo
> lrwxrwxrwx 1 root root 6 Dec 6 16:54 mpic++ -> mpicxx
> -rwxr-xr-x 1 root root 8974 Dec 6 16:54 mpicc
> -rwxr-xr-x 1 root root 8874 Dec 6 16:54 mpich2version
> -rwxr-xr-x 1 root root 8659 Dec 6 16:54 mpicxx
> lrwxrwxrwx 1 root root 13 Dec 6 16:54 mpiexec -> mpiexec.hydra
> -rwxr-xr-x 1 root root 748519 Dec 6 16:54 mpiexec.hydra
> -rwxr-xr-x 1 root root 10640 Dec 6 16:54 mpif77
> -rwxr-xr-x 1 root root 12615 Dec 6 16:54 mpif90
> lrwxrwxrwx 1 root root 13 Dec 6 16:54 mpirun -> mpiexec.hydra
> -rwxr-xr-x 1 root root 3430 Dec 6 16:54 parkill
> -rwxr-xr-x 1 root root 20427 Dec 6 16:54 plpa-info
> -rwxr-xr-x 1 root root 40775 Dec 6 16:54 plpa-taskset
> -rwxr-xr-x 1 root root 1965 Dec 6 16:54 slog2filter
> -rwxr-xr-x 1 root root 1983 Dec 6 16:54 slog2navigator
> -rwxr-xr-x 1 root root 2015 Dec 6 16:54 slog2print
> -rwxr-xr-x 1 root root 1974 Dec 6 16:54 slog2updater
> clearly it IS there, and it is accessible :
> [dsullivan at athos bin]$ which hydra_pmi_proxy
> This all worked this morning and little has changed since (a restart maybe). Any direction would be greatly appreciated.
> Regards,
> David Sullivan
> AREVA NP INC
> 400 Donald Lynch Boulevard
> Marlborough, MA, 01752
> Phone: (508) 573-6721
> Fax: (434) 382-5597
> David.Sullivan at AREVA.com
> The information in this e-mail is AREVA property and is intended solely for the addressees. Reproduction and distribution are prohibited. Thank you .
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
