[mpich-discuss] seek help on mpi- mpich
Jayesh Krishna jayesh at mcs.anl.gov
Wed Dec 1 10:17:29 CST 2010
 Good to know your problem is solved. Although I am not sure what your question is, Are you referring to stdout from worker program being redirected (printfs from worker program appearing in the mpiexec cmd prompt ?) to mpiexec ?
Jayesh
----- Original Message -----
To: Jayesh Krishna <jayesh at mcs.anl.gov>
Sent: Tue, 30 Nov 2010 22:26:37 -0600 (CST)
Subject: Re: seek help on mpi- mpich
Hello..Mr Jayesh.
I think I've solved my problem, although I am still confuse why the master
node still print the worker part in hello program. I can see the mpi
invocation in windows task manager when I run my neural net program via 2
nodes.
 I think I have done double setting which should be done in single. I've
configure the machine file and  also to host file in system32 (obtain it
from you or in forum).
Thank you so much for your help and support.
p.s would you help me when I am in a need in future :)?
On Thu, Nov 25, 2010 at 10:37 PM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
>  Can you try running the example MPI program (cpi.exe) provided with MPICH2
> using the following command ?
>  mpiexec -machinefile mf0.txt -n 2 C:\Progra~1\MPICH2\examples\cpi.exe
> Regards,
> Jayesh
> From: UmmuRifqi <ummurifqi09 at gmail.com>
> Sent: Wed, 24 Nov 2010 23:05:44 -0600 (CST)
> Hi, thanks.
> I get what you said. but why my pc worker does'nt show anything that shows
> something the worker's pc is printing/doing what master says to get work
> done.
> until this time...my pc cannot validate (mpiexec -validate)..
> one more thing I configued using wmpiconfig, then i can see this 2
> processors (from master)
> C:\Documents and Settings\Administrator\My Documents\myPar>mpiexec
> -machinefile mf0.txt -np 2 hostname
> hpxp
> ummuRifqi
> ~really messed..
> On Mon, Nov 22, 2010 at 11:18 PM, Jayesh Krishna <jayesh at mcs.anl.gov>
> wrote:
> > Hi,
> > >> mpiexec -machinefile mf.txt hellocluster.exe ...the output on master
> is
> > printing master part only
> >  The machinefile only lists the nodes that mpiexec can use to launch an
> MPI
> > job. mpiexec does not necessarily use all the nodes listed in the
> > machinefile for launching an MPI job. For example you can have 100 nodes
> > listed in the machinefile, but mpiexec only uses the nodes that it needs
> for
> > the job depending on the "-n" argument (eg: -n 3 ; will result in mpiexec
> > launching 3 MPI processes) which provides information on the number of
> > actual processes to launch.
> > # For the example above with 100 nodes listed in the machinefile, mf.txt
> > (Consider the simplest case where only the node ipaddresses of the 100
> hosts
> > are listed in the machinefile),
> > 1) mpiexec -machinefile mf.txt mympipgm.exe ; Results in 1 MPI process -
> > the default since -n argument is not present - being launched on the 1st
> > node listed in the machinefile
> > 2) mpiexec -n 2 -machinefile mf.txt mympipgm.exe ; Results in 2 MPI
> > processes being launched, 1 each on the first 2 nodes/machines listed in
> the
> > machinefile
> > 3) mpiexec -n 100 -machinefile mf.txt mympipgm.exe ; Results in an MPI
> > process launched on all the 100 nodes listed in the machinefile
> > 4) mpiexec -n 101 -machinefile mf.txt mympipgm.exe ; Results in 2 MPI
> > processes launched on the 1st node (The nodes are considered in a round
> > robin fashion) and an MPI process launched on all the other 99 nodes
> listed
> > in the machinefile
> >  You should launch your MPI job as you ran the hostname command (mpiexec
> -n
> > 2 -machinefile mf.txt helloCluster.exe).
> >  Let us know if you have any further questions.
> > Regards,
> > Jayesh
> > Sent: Sun, 21 Nov 2010 23:32:11 -0600 (CST)
> > Hi,
> > 1. what do you mean by message from both cases ? Correct if I am wrong..
> > master's node will print : Master process rank#0 sending message ~Hello,
> > world
> > worker's node will print : Worker with rank#1 receives message ~Hello,
> > world
> > from master
> > ok now, when I did this(as follows) on master's node which is
> > 192.168.33.69:
> > the output on master is printing master part only:
> >       Master process rank#0 sending message ~Hello, world
> > but if I typed this:
> > -hosts 2 192.168.33.69 192.168.33.68 hellocluster.exe
> > the output will be as follows
> >    Worker with rank#1 receives message ~Hello, world from master
> > (where the master also prints the worker part on the master node(which is
> > supposed to be printed by worker's node):
> > the mf.txt which my machine file content are:
> > # XP node
> > 192.168.33.69:1
> > #vista node
> > 192.168.33.68:1
> > 2. issue related with setup
> > -both machine (xp 32 bit &. vista home premium 32bit) installed with
> > mpich2-1.3-win-ia32, with default passphrase
> > -both machine had administrator user account with same password(already
> > tried with new mpiuser with administrator privileges..resulted the same)
> > -both can  execute the mpi stand alone program (multithreading),
> > -firewall wall is totally off.
> > - the confoguration ( wmpiconfig) is  as attached.
> > - everything goes fine but the both machine error when doing command >>
> > mpiexec -validate, the error is
> >    Error during CryptEncrypt: Unknown failure 234
> >    unable to encrypt the password for the validate command.
> >   it hang until I close the command prompt window and restart.
> > - when I run
> > mpiexec -machinefile mf.txt -n 2 hostname
> > the output :
> > hpxp
> > ummuRifqi
> > --> hpxp is XP machine while ummuRifqi is Vista machine
> > Thanks.
> > On Mon, Nov 22, 2010 at 1:35 AM, Jayesh Krishna <jayesh at mcs.anl.gov>
> > wrote:
> > > Hi,
> > > >> In fact, the worker should print something to show ...
> > >  In the output below I can see the message from worker for both cases 2
> > 3
> > > . Can you explain in detail the issue that you see with your setup ?
> > >  You might also want to run "mpiexec -machinefile mf.txt -n 2 hostname"
> > to
> > > see the hosts where the processes get launched.
> > > Regards,
> > > Jayesh
> > > Sent: Sat, 20 Nov 2010 23:14:56 -0600 (CST)
> > > sorry some correction..
> > > On Sun, Nov 21, 2010 at 1:09 PM, UmmuRifqi <ummurifqi09 at gmail.com>
> > wrote:
> > > > Hello again, sorry for late reply (being involved with some other
> > > > not-related things)
> > > > here is my output:
> > > > 1. ====== with machinefile, if I dont specify the no of processors
> > > > C:\~\~\~\myPar>mpiexec -machinefile mf.txt <http://mf.pg>
> > > hellocluster.exe
> > > > 2. ======= if I specify no of processors
> > > > C:\~\~\~\myPar>mpiexec -machinefile mf.txt <http://mf.pg> -np 2
> > > > hellocluster.exe
> > > > 3. ======= without mentioning processor a.k.a multithreading.
> > > > C:\~\~\~\myPar>mpiexec -np 2 hellocluster.exe
> > > > as we can see, the output 2 is arguable because I don't see whether
> the
> > > > node machine is working or not.
> > > > because as output 3, the command may ignore the machine file(assumed
> by
> > > me
> > > > regarding to non reaction of worker's node).
> > >   In fact, the worker should print something to show the message
> received
> > > by it (as in the program code)
> > > > how can I verify that the worker's node is executing the processes
> > > assigned
> > > > by master.
> > > > Can we see it on the worker's node monitor? or it only can be seen on
> > > > master's node?
> > > > the right-click " run as administrator" I regard to when I want to
> open
> > > DOS
> > > > command prompt, there will always 2 optional as previous image I sent
> > > you.
> > > > so I choose administrator and once again enter the password. is that
> > what
> > > > you mean?
> > > > thanks.
> > > > On Tue, Nov 16, 2010 at 11:49 PM, Jayesh Krishna <jayesh at mcs.anl.gov
> > > >wrote:
> > > >> Hi,
> > > >> >> mpiexec -machinefile mf.txt helloCluster.exe
> > > >>  If you do not specify the number of MPI processes only 1 MPI
> process
> > is
> > > >> launched. Use the "-n" option to specify the number of MPI processes
> > > >> required for the job (mpiexec -n 2 -machinefile mf.txt
> > > helloCluster.exe).
> > > >> >> ...when I right-click to choose "run as administrator" ...
> > > >>  Which program are you referring ? Are you running all the commands
> > from
> > > >> an administrator command prompt (In Vista even a user with admin
> > > privileges
> > > >> opens a command prompt it is not an elevated command prompt. In
> Vista
> > to
> > > >> open an administrator/elevated command prompt right-click on the
> > command
> > > >> prompt icon and select "run as administrator". Run all the commands
> on
> > > Vista
> > > >> from an administrator command prompt and see if it works)?
> > > >> Regards,
> > > >> Jayesh
> > > >> Sent: Tue, 16 Nov 2010 02:24:35 -0600 (CST)
> > > >> Hello and thank for your suppot..
> > > >> yes. I tried create new user (mpiuser) with administrator privilege,
> > the
> > > >> other are other windows user with limited privilege.
> > > >> then I registered mpiuser using mpiexec with password. but the
> > validate
> > > >> part
> > > >> fail as following error.
> > > >> but it can lauch mpi locally but only run on master node (which is
> in
> > > this
> > > >> case xp machine) if >>mpiexec -machinefile mf.txt helloCluster.exe
> > > >> fyi, when I right-click to choose "run as administrator" there are
> two
> > > >> option user provided.
> > > >>  either to choose (domain\username) or administrator. (see the
> > > >> image on run as administrator option). This is also happen to my
> vista
> > > >> machine.
> > > >> i am using xp sp2, and vista home premiun sp2
> > > >> additionally, I also have read your comment in mpich-discuss but
> >  cannot
> > > >> refer the documentation (usually suggested by you on the
> installation
> > > >> guide)
> > > >> at
> http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=
> > > >> it is not available.
> > > >> On Tue, Nov 16, 2010 at 4:50 AM, Jayesh Krishna <jayesh at mcs.anl.gov
> > > >> wrote:
> > > >> > Hi,
> > > >> > >> so, i am using the second administrator on both machine (they
> > have
> > > >> the
> > > >> > same passwd) to register...
> > > >> >  As I mentioned before try registering a username different from
> the
> > > >> > "Administrator".
> > > >> >  Please follow the steps below,
> > > >> > 1) On the XP machine & the Vista machine create a user, "mpiuser",
> > > with
> > > >> the
> > > >> > same password (As I mentioned before do not register
> "Administrator"
> > > >> with
> > > >> > mpiexec).
> > > >> > 2) Register & Validate "mpiuser" on each machine.
> > > >> > 3) Test whether the user, "mpiuser" can launch MPI processes
> locally
> > > on
> > > >> > each machine.
> > > >> > 4) Run your job across the XP & Vista machines and see if it
> works.
> > > >> > Regards,
> > > >> > Jayesh
> > > >> > Sent: Mon, 15 Nov 2010 14:43:00 -0600 (CST)
> > > >> > Hello again,
> > > >> > Yeah,  At the first place I've done that (the same windows
> user/same
> > > >> > password with administrator privileges both on XP and Vista).
> > > >> > As I emailed to you,
> > > >> >  in XP, there are 2 windows user 1) hpxp (user with administrator
> > > >> > privileges)  2) Administrator (administrator privileges)
> > > >> >  in Vista, There are also 2 windows user 1) user (administrator
> > > >> > so, i am using the second administrator on both machine (they have
> > the
> > > >> same
> > > >> > passwd) to register username/password with mpiexec which as
> follows:
> > > >> > > the error after >>mpiexec -validate  // done on XP
> > > >> > > Microsoft Windows XP [Version 5.1.2600]
> > > >> > > (C) Copyright 1985-2001 Microsoft Corp.
> > > >> > > C:\Documents and Settings\Administrator>mpiexec -remove
> > > >> > > Account and password removed from the Registry.
> > > >> > > C:\Documents and Settings\Administrator>mpiexec -register
> > > >> > > account (domain\user) [HPXP\Administrator]: Administrator
> > > >> > > password: **
> > > >> > > confirm password: **
> > > >> > > Password encrypted into the Registry.
> > > >> > > C:\Documents and Settings\Administrator>mpiexec -validate
> > > >> > > the error after >>mpiexec -validate Administrator/** //done on
> > Vista
> > > >> > > Microsoft Windows XP [Version 6.0.6002]
> > > >> > > Copyright (C) 2006 Microsoft Corp. All right reserved.
> > > >> > > C:\Users\Administrator>mpiexec -remove
> > > >> > > C:\Users\Administrator>mpiexec -register
> > > >> > > password:
> > > >> > > confirm password:
> > > >> > > C:\Users\Administrator>mpiexec -validate
> > > >> > Eventhough I cannot validate, but I can run the MPI program from 1
> > > node
> > > >> or
> > > >> > multithreading.
> > > >> > result :
> > > >> > in both machine.
> > > >> > The firewalls are all off.
> > > >> > Currently, I tried to change the administrator privileges on user
> > hpxp
> > > >> on
> > > >> > XP, but it disables me to change the role to user privilege, so
> that
> > I
> > > >> only
> > > >> > have 1 administrator privileges. in vista, it can be done easily,
> > will
> > > >> let
> > > >> > you know later.
> > > >> > before that,  do you have any suggestions please?
> > > >> > thanks Mr Jayesh.
> > > >> > On Mon, Nov 15, 2010 at 11:20 PM, Jayesh Krishna <
> > > >> > wrote:
> > > >> > > Hi,
> > > >> > >  Is "myuser" a valid Windows user ? You need to register an
> > existing
> > > >> > > Windows username/password with mpiexec.
> > > >> > >  Please create a windows user (The same username/password on XP
> > > >> Vista
> > > >> > > machines) with administrator privileges and try registering that
> > > >> > > username/password with mpiexec. Let us know the results.
> > > >> > > Regards,
> > > >> > > Jayesh
> > > >> > > Sent: Sun, 14 Nov 2010 20:41:00 -0600 (CST)
> > > >> > > Hello again Mr Jayesh.
> > > >> > > I've removed and created new account other than Administrator as
> > > below
> > > >> > > myuser), (by mpiexec -register)
> > > >> > > then it resulted the same one, I can register but could'nt
> > validate
> > > >> them.
> > > >> > > FYI, in my XP machine, there are 2 accounts of administrator
> > > role..1)
> > > >> > > Administrator 2) hpxp  (we can see it on window welcome screen)
> > > >> > > also in my vista machine, there are also 2 accounts of
> > > administrator.
> > > >> > > I installed the mPICH2  'everyone' not 'just me' features.
> > > >> > > the output on my XP machine:
> > > >> > > -register
> > > >> > > account (domain\user) [HPXP\Administrator]: myuser
> > > >> > > password:
> > > >> > > confirm password:
> > > >> > > -validate
> > > >> > > help me please. Thanks.
> > > >> > > On Thu, Nov 11, 2010 at 10:49 PM, Jayesh Krishna <
> > > >> > > wrote:
> > > >> > > > Hi,
> > > >> > > >  Can you try registering/validating a username (an admin user)
> > > other
> > > >> > than
> > > >> > > > "Administrator" ?
> > > >> > > > Regards,
> > > >> > > > Jayesh
> > > >> > > > Sent: Wed, 10 Nov 2010 22:25:46 -0600 (CST)
> > > >> > > > Hello again,
> > > >> > > > step 1-2 done successfully.
> > > >> > > > step 3 unsuccessful because when to validate the
> > > username/password,
> > > >> > there
> > > >> > > > is
> > > >> > > > an error..it hang and never return the command prompt until I
> > > press
> > > >> > > ctrl-C
> > > >> > > > after several minutes waiting.
> > > >> > > > password:
> > > >> > > > confirm password:
> > > Vista
> > > >> > > > password:
> > > >> > > > confirm password:
> > > >> > > > how it can be solved , attached is my smpd.log
> > > >> > > > thanks Mr. Jayesh.
> > > >> > > > On Thu, Nov 11, 2010 at 9:20 AM, UmmuRifqi <
> > > >> > > wrote:
> > > >> > > > > Thanks for the feedback & suggestion.
> > > >> > > > > Just arrived the lab, I'll try it out and will let you know
> > the
> > > >> > result.
> > > >> > > > > On Wed, Nov 10, 2010 at 11:15 PM, Jayesh Krishna <
> > > >> > > > >wrote:
> > > >> > > > >> Hi,
> > > >> > > > >>  Please try the following,
> > > >> > > > >> 1) Create a machinefile, mf.txt, with the following
> contents,
> > > >> > > > >> # XP node
> > > >> > > > >> 192.168.33.69:1
> > > >> > > > >> # Vista node
> > > >> > > > >> 192.168.33.68:1
> > > >> > > > >> 2) Make sure helloCluster.exe is available in C:\temp on
> both
> > > the
> > > >> > > > >> machines.
> > > >> > > > >> 3) Remove any usernames registered on the machines using
> the
> > > >> > "-remove"
> > > >> > > > >> option of mpiexec ("mpiexec -remove" on both the machines)
> > and
> > > >> > > > re-register a
> > > >> > > > >> username/password available on both the machines (same user
> > > >> with
> > > >> > the
> > > >> > > > same
> > > >> > > > >> password - should be available on both the machines) using
> > the
> > > >> > > > "-register"
> > > >> > > > >> option of mpiexec ("mpiexec -register" on both the
> machines).
> > > >> > > > >>   Validate the username/password registered using the
> > > "-validate"
> > > >> > > option
> > > >> > > > >> of mpiexec ("mpiexec -validate" on both the machines).
> > > >> > > > >> 4) Try running helloCluster.exe on both machines (XP &
> Vista)
> > > >> > locally
> > > >> > > > >> (mpiexec -n 2 helloCluster.exe)
> > > >> > > > >> 5) Try running a non-MPI program like hostname on both the
> > > >> machines
> > > >> > > > >> (mpiexec -n 2 -machinefile mf.txt hostname)
> > > >> > > > >> 6) Now try running helloCluster.exe on the cluster (mpiexec
> > -n
> > > 2
> > > >> > > > >> -machinefile mf.txt c:\temp\helloCluster.exe)
> > > >> > > > >> (PS: If you get an error message please copy-paste it in
> your
> > > >> email)
> > > >> > > > >> Regards,
> > > >> > > > >> Jayesh
> > > >> > > > >> To: jayesh at mcs.anl.gov
> > > >> > > > >> Sent: Wed, 10 Nov 2010 02:43:14 -0600 (CST)
> > > >> > > > >> Subject: seek help on mpi- mpich
> > > >> > > > >> Hello,
> > > >> > > > >> I am new to mpich/mpi and I learn this by myself from the
> > > >> Internet
> > > >> > to
> > > >> > > do
> > > >> > > > >> my
> > > >> > > > >> research.
> > > >> > > > >> I've review the discussion mpich-discuss (
> > http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-July/007469.html)
> > > >> > > > >> been following the thread after thread and decided to email
> > you
> > > >> if
> > > >> > you
> > > >> > > > >> could
> > > >> > > > >> help me on windows clustering using mpich2.
> > > >> > > > >> I'm doing on XP and Vista machine, 32 bit, mpich2 version
> > > >> > > > >> mpich2-1.2.1p1-win-ia32, it works on hello world program
>  for
> > > >> single
> > > >> > > > node
> > > >> > > > >> (stand alone), but it does not run on multinode ( the nest
> > > >> machine).
> > > >> > > it
> > > >> > > > >> says
> > > >> > > > >> -machinefile mf.pg helloCluster.exe
> > > >> > > > >> the firewall already off. the machine file contains
> > > >> > > > >> 192.168.33.69 0 /Documents and Settings/Administrator/My
> > > >> > > > Documents/myPar/
> > > >> > > > >> this is XP machine
> > > >> > > > >> 192.168.33.68 1
> > > >> > > > >> /Users/Administrator/Documents/myPar/
> > > >> > > > >> #this
> > > >> > > > >> is Vista machine
> > > >> > > > >> please help me. what else considering i have to take to
> > enable
> > > >> the
> > > >> > > > >> interaction between the nodes because after this i need to
> do
> > > it
> > > >> on
> > > >> > > 3,5,
> > > >> > > > 8
> > > >> > > > >> machines.
> > > >> > > > >> thank you.
