[mpich-discuss] MPICH2 Between Linux/Windows
    Stephan Hackstedt
    stephan.hackstedt at googlemail.com
    Mon Aug 23 13:19:24 CDT 2010
i also observed, that when i use the ch3:sock build, the MPI_comm_open
always repeats the internal ip adress like:
tag=0 port=46264 description=stephan-desktop ifname=127.0.1.1
regards,
stephan
2010/8/23 Stephan Hackstedt <stephan.hackstedt at googlemail.com>
> Hi,
> I'm trying to establish a connection between a process on linux (ububtu 10
> 04) and a process on a WinXp machine. MPICH 1.2.1 on both machines. The
> WinXP with installer, ubuntu from sources.
> I configured the linux side with
>  ./configure  --with-pm=smpd --with-device=ch3:nemesis
> and another build with
> ./configure  --with-pm=smpd --with-device=ch3:sock ,
> none of them work. I also disabled all firewalls, wonder because when i
> start a virtual machine on the winxo machine i can esatblish a connection to
> the linux machine. Had anybody dealt with such problems before?
> One other question is, do i have to rebuild a MPI Application when using
> another MPICH2 build with another processmanager like above?
> regards,
> stephan
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100823/88bf6daa/attachment.htm>
