[mpich-discuss] using hydra to start a task on a specific node
Pavan Balaji balaji at mcs.anl.gov
Thu Aug 19 18:39:39 CDT 2010
Please note that some of these features are added after mpich2-1.2.1p1
was released (such as the hostlist parameter).
But if you are feeling adventurous today, read on :-).
You can pick the Hydra version from mpich2-1.3b1
(http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/1.3b1/hydra-1.3b1.tar.gz)
and use it to run applications compiled with mpich2-1.2.1p1.
Building this new Hydra separately will give you an "mpiexec" and some
other executables files, which you can directly use with your existing
1.2.1p1 application. Just have the "--prefix" point to your existing
MPICH2's install location.
  -- Pavan
On 08/19/2010 06:09 PM, Camilo Rostoker wrote:
> I asked this question just a few days ago and Pavan suggested the
> following which worked for me:
> host/hosts/hostlist is a global parameter that affects all executables.
> Can you try this:
> % mpiexec -hostlist node01:5,node02:4,node03:2 -n 5 ./exec1 : -n 4
> ./exec2 : -n 2 ./exec3
> On Thu, Aug 19, 2010 at 5:03 PM, Rajnish <rajnish at cc.gatech.edu
> <mailto:rajnish at cc.gatech.edu>> wrote:
>     Hi,
>     Is it possible to use mpiexec.hydra to start a task on a specific node?
>     Something like:
>     mpiexec -host node1 task1
>     But I would like to use mpiexec.hydra to have the above effect?
>     Thanks in advance,
>     - Raj.
>     _______________________________________________
>     mpich-discuss mailing list
>     mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>     https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
http://www.mcs.anl.gov/~balaji
