[mpich-discuss] libmpich.a "No such file or directory"
sasha lambert
lambert.sasha at gmail.com
Sun Aug 15 10:38:16 CDT 2010
Hmm still nothing; no errors but no main.o.
My mpich configure, make, and make install steps went smoothly. The "which
mpicc" test was successful, indicating its location at usr/bin.
Sasha
On Sun, Aug 15, 2010 at 11:25 AM, Si Hammond <simon.hammond at gmail.com>wrote:
> Can you try...
> mpicc -o main.o -c main.c
> mpicc -o hello main.o
> You should see the main.o in the directory, if no errors on the screen then
> it sounds like its working fine.
> S.
> On 15 Aug 2010, at 16:21, sasha lambert wrote:
> I tried compiling using mpicc, and nothing seems to happen.
> The prompt just reappears and no executable file has been made.
> Sasha
> On Sun, Aug 15, 2010 at 11:12 AM, Si Hammond <simon.hammond at gmail.com>wrote:
>> Have you tried compiling with mpicc?
>> mpicc -o hello main.c
>> This sets up the linking etc for you.
>> S.
>> On 15 Aug 2010, at 16:02, sasha lambert wrote:
>> I'm fairly new to unix and mpich, so please bear with me.
>> I've tried to compile a simple "hello" program below:
>> /*The Parallel Hello World Program*/
>> #include <stdio.h>
>> #include <mpi.h>
>> main(int argc, char **argv)
>> int node;
>> MPI_Init(&argc,&argv);
>> MPI_Comm_rank(MPI_COMM_WORLD, &node);
>> printf("Hello World from Node %d\n",node);
>> MPI_Finalize();
>> Here is the shell response:
>> $ gcc main.c -o hello
>> Undefined symbols:
>> "_MPI_Comm_rank", referenced from:
>> _main in ccWLoMyo.o
>> "_MPI_Finalize", referenced from:
>> _main in ccWLoMyo.o
>> "_MPI_Init", referenced from:
>> _main in ccWLoMyo.o
>> ld: symbol(s) not found
>> collect2: ld returned 1 exit status
>> I tried searching for "MPI_init" in libmpich.a, thinking it might have to
>> do with the added underscore in " _MPI_Init".
>> Shell response:
>> $ nm libmpich.a | grep mpi_init
>> nm: can't open file: libmpich.a (No such file or directory)
>> I've added usr/local/lib to the PATH, but still nothing. Any suggestions?
>> Thanks,
>> Sasha
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> Si Hammond
>> Research Fellow & Knowledge Transfer Associate
>> Performance Computing & Visualisation Group
>> Department of Computer Science
>> University of Warwick, CV4 7AL, UK
>> http://go.warwick.ac.uk/hpsg
> Si Hammond
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100815/05270167/attachment-0001.htm>
