[mpich-discuss] specifying hosts with hydra in the configfile
Camilo Rostoker rostoker at gmail.com
Sat Aug 14 21:30:58 CDT 2010
How can I specify which host a given executable should run on?
Before migrating to hydra, I had an configfile which had lines like the
following:
-n 5 -host node01 executable1
-n 4 -host node02 executable2
-n 2 -host node03 executable3
this let me specify which hosts each executable should run on.
If I use this configfile format with hydra, I get the following error
"duplicate host file or host list setting"
I'm using the latest build of hydra (1.3.b1)
Thanks in advance for any help on this matter.
Cheers,
Camilo
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100814/cae3be08/attachment.htm>
