[mpich-discuss] mpdboot
Dave Goodell goodell at mcs.anl.gov
Thu Aug 12 13:11:23 CDT 2010
What version of MPICH2 are you using?
If you really want to use mpd and not hydra, try using the mpdcheck utility as described in the Installer's Guide.  "mpdboot" and mpd in general tend to yield very strange output in the face of any networking or configuration problems.  This is one of the many reasons that hydra was developed to replace mpd.
That said, the choice of mpd vs. hydra shouldn't usually affect the numerical outcome of any decently coded computation.  I would recommend just using hydra.
-Dave
On Aug 12, 2010, at 12:46 PM CDT, Grzegorz Dwornicki wrote:
> Hi
> i'm getting this error when i'm using mpdboot:
> mpdboot_node4 (handle_mpd_output 407): failed to handshake with mpd on 172.16.3.120; recvd output={}
> All nodes have the same .mpd.conf file, everywhere ,mpd.conf prems are -rw-------. Hydra works but I think that results of calculations will be diferent when it will be run on mpd.
> system: debian squeeze, mpich2
> Gregory
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
