[mpich-discuss] Crash starting job with particular machine list
Dave Goodell goodell at mcs.anl.gov
Thu Aug 12 09:11:49 CDT 2010
Fixed in the trunk: https://trac.mcs.anl.gov/projects/mpich2/changeset/7052
Thanks for the bug report.
-Dave
On Aug 11, 2010, at 2:42 PM CDT, Dave Goodell wrote:
> On Aug 11, 2010, at 1:28 PM CDT, Steve Krueger wrote:
>> I'm using the SOCK driver in a 1.2.1 build of mpich2 and the
>> mpd daemon on a Linux X86-64 grid.
>> This problem seems to be fixed in 1.3, although I couldn't find
>> a fix similar to the one I'm using.
> Hmm... Between 1.2.1-->1.3 the default process manager changed from MPD to Hydra.  I suspect that MPD simply gave up on calculating a mapping for an irregular layout like (A,B,B), triggering the code path you describe below.  Hydra, on the other hand, probably actually calculates a valid mapping which avoids this problem entirely.
>> The problem is in mpid_vc.c. This line:
>> mpi_errno = populate_ids_from_mapping(value, &num_nodes, pg, &did_map);
>> Setting it back to 0 before the loop seems to solve the problem.
>>   g_num_nodes = 0; /* NEW LINE */
>>   for (i = 0; i < pg->size; ++i)
>>       if (i == our_pg_rank)
>> Please advise if this as an appropriate fix.
> I'll take a closer look at the code in question (it's been a little while since I've looked at it) and let you know if there's a better fix.  Thanks for letting us know about the problem.
> -Dave
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
