[mpich-discuss] Troubles in configuring process
jayesh at mcs.anl.gov
Thu Aug 5 11:59:05 CDT 2010
Can you compile simple C programs with gcc ? Can you compile the programs below with gcc ?
#include <stdio.h>
int main(int argc, char *argv)
return 0;
#include <limits.h>
return 0;
#include <assert.h>
return 0;
Did you manually copy any std C header files (limits.h/assert.h) to MPICH2 source directory ? I am assuming that you are working on a fresh download of the MPICH2 (1.2.1p1) source from http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads .
Jayesh
----- Original Message -----
To: "jayesh" <jayesh at mcs.anl.gov>
Sent: Wednesday, August 4, 2010 9:12:47 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] Troubles in configuring process
Hi, jayesh,
Configuring still fails following your suggestions. No "c.txt" was generated this time. Thanks a lot.
M-H
