[mpich-discuss] Hydra genv_fn() memory leaks fix
Pavan Balaji balaji at mcs.anl.gov
Wed Aug 4 14:11:58 CDT 2010
On 08/04/2010 01:42 PM, Yauheni Zelenko wrote:
> I agree that structure may be convenient to add several environment
> variables at once. However memory management is not clear:
> programmers should always keep in mind that created structure should
> be free after insertion to list.
No, not only for list manipulations, but also when you need to keep
track of different types of environments separately (e.g., ones which
are inherited vs. ones which are explicitly passed by the user vs. ones
which are set by mpiexec itself). You can see the pm/pmiserv/pmip* files
for examples of this.
The only place it's slightly inconvenient is when the user parameters
are being read (ui/mpich/utils.c), which I wasn't particularly concerned
about. I'll add a new function to append environment variables without
creating an environment structure separately to make this cleaner.
  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
