[mpich-discuss] Hydra genv_fn() memory leaks fix
Pavan Balaji
balaji at mcs.anl.gov
Wed Aug 4 13:34:59 CDT 2010
Thanks. I've fixed a bunch of memory leaks in r7000
[https://trac.mcs.anl.gov/projects/mpich2/changeset/7000].
The env structure is a bit wasteful while reading the user parameters,
but it's convenient while passing around environment lists throughout
the code. But it shouldn't really affect performance.
-- Pavan
On 08/02/2010 04:48 PM, Yauheni Zelenko wrote:
> Hi!
> I want to suggest fix for memory leaks in genv_fn(). Code is based on r6973. Please review code.
> I also wonder with adding environment to list is so complicated and involve several memory copies (strings and structures)? May be should just HYDU_append_env_to_list() use name and value arguments instead of intermediate environment structure?
> static HYD_status genv_fn(char *arg, char ***argv)
> char *env_name, *env_value, *str[2] = { NULL, NULL };
> struct HYD_env *env;
> HYD_status status = HYD_SUCCESS;
> status = HYDU_strsplit(**argv,&str[0],&str[1], '=');
> HYDU_ERR_POP(status, "string break returned error\n");
> (*argv)++;
> env_name = str[0];
> if (str[1] == NULL) { /* The environment is not of the form x=foo */
> if (**argv == NULL) {
> status = HYD_INTERNAL_ERROR;
> goto fn_fail;
> env_value = **argv;
> (*argv)++;
> else {
> env_value = str[1];
> status = HYDU_env_create(&env, env_name, env_value);
> HYDU_ERR_POP(status, "unable to create env struct\n");
> HYDU_append_env_to_list(*env,&HYD_handle.user_global.global_env.user);
> fn_exit:
> if (str[0])
> HYDU_free(str[0]);
> if (str[1])
> HYDU_free(str[1]);
> if (env)
> HYDU_env_free(env);
> return status;
> fn_fail:
> goto fn_exit;
> Eugene.
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
