[mpich-discuss] Fix for Hydra LSF resources query
Yauheni Zelenko
zelenko at cadence.com
Mon Aug 2 15:36:18 CDT 2010
Hi, Pavan!
I tested new build for this feature and also number of CPUs in -hosts and everything looks OK.
Eugene.
From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Pavan Balaji [balaji at mcs.anl.gov]
Sent: Monday, August 02, 2010 8:25 AM
Subject: Re: [mpich-discuss] Fix for Hydra LSF resources query
The fix is committed in r6972
[http://trac.mcs.anl.gov/projects/mpich2/changeset/6972]. The latest
nightly snapshot
[http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/trunk]
should have it.
-- Pavan
On 08/01/2010 03:19 PM, Pavan Balaji wrote:
> Hello,
> Thanks for the patch. I don't think duplicating the string makes much
> difference from a correctness perspective, since the environment
> propagation mechanism is completely different in Hydra, and reads the
> environment before modifying it. However, I do agree that it's a better
> programming practice in general to not corrupt the environment. I've
> fixed it in my local git repository and will commit it to the svn as
> soon as it's up.
> -- Pavan
> On 07/30/2010 08:02 PM, Yauheni Zelenko wrote:
>> Hi!
>> I want to propose fix for HYDT_bscd_lsf_query_node_list(). Currently tokenizer operates directly on environment and corrupt it (application gets truncated LSB_MCPU_HOSTS). So it's necessary to create copy of environment and work with it.
>> I suggest next implementation (based on r6885):
>> HYD_status HYDT_bscd_lsf_query_node_list(struct HYD_node **node_list)
>> char *hosts;
>> HYD_status status = HYD_SUCCESS;
>> HYDU_FUNC_ENTER();
>> if (MPL_env2str("LSB_MCPU_HOSTS", (const char **)&hosts) == 0)
>> hosts = NULL;
>> if (hosts == NULL) {
>> *node_list = NULL;
>> HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "No LSF node list found\n");
>> else {
>> char* hosts_copy = HYDU_strdup(hosts);
>> char* hostname = strtok(hosts_copy, " ");
>> while (1) {
>> char* num_procs_str;
>> int num_procs;
>> if (hostname == NULL)
>> break;
>> /* the even fields in the list should be the number of
>> * cores */
>> num_procs_str = strtok(NULL, " ");
>> HYDU_ASSERT(num_procs_str, status);
>> num_procs = atoi(num_procs_str);
>> status = HYDU_add_to_node_list(hostname, num_procs, node_list);
>> HYDU_ERR_POP(status, "unable to add to node list\n");
>> hostname = strtok(NULL, " ");
>> HYDU_free(hosts_copy);
>> fn_exit:
>> HYDU_FUNC_EXIT();
>> return status;
>> fn_fail:
>> goto fn_exit;
>> Please review it and include to Hydra code.
>> Eugene.
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
http://www.mcs.anl.gov/~balaji
