[mpich-discuss] Fix for Hydra LSF resources query
Pavan Balaji
balaji at mcs.anl.gov
Sun Aug 1 15:19:03 CDT 2010
Hello,
Thanks for the patch. I don't think duplicating the string makes much
difference from a correctness perspective, since the environment
propagation mechanism is completely different in Hydra, and reads the
environment before modifying it. However, I do agree that it's a better
programming practice in general to not corrupt the environment. I've
fixed it in my local git repository and will commit it to the svn as
soon as it's up.
-- Pavan
On 07/30/2010 08:02 PM, Yauheni Zelenko wrote:
> Hi!
> I want to propose fix for HYDT_bscd_lsf_query_node_list(). Currently tokenizer operates directly on environment and corrupt it (application gets truncated LSB_MCPU_HOSTS). So it's necessary to create copy of environment and work with it.
> I suggest next implementation (based on r6885):
> HYD_status HYDT_bscd_lsf_query_node_list(struct HYD_node **node_list)
> char *hosts;
> HYD_status status = HYD_SUCCESS;
> HYDU_FUNC_ENTER();
> if (MPL_env2str("LSB_MCPU_HOSTS", (const char **)&hosts) == 0)
> hosts = NULL;
> if (hosts == NULL) {
> *node_list = NULL;
> HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "No LSF node list found\n");
> else {
> char* hosts_copy = HYDU_strdup(hosts);
> char* hostname = strtok(hosts_copy, " ");
> while (1) {
> char* num_procs_str;
> int num_procs;
> if (hostname == NULL)
> break;
> /* the even fields in the list should be the number of
> * cores */
> num_procs_str = strtok(NULL, " ");
> HYDU_ASSERT(num_procs_str, status);
> num_procs = atoi(num_procs_str);
> status = HYDU_add_to_node_list(hostname, num_procs, node_list);
> HYDU_ERR_POP(status, "unable to add to node list\n");
> hostname = strtok(NULL, " ");
> HYDU_free(hosts_copy);
> fn_exit:
> HYDU_FUNC_EXIT();
> return status;
> fn_fail:
> goto fn_exit;
> Please review it and include to Hydra code.
> Eugene.
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
