[mpich-discuss] Calling MPI from a CGI Python script
Dave Goodell goodell at mcs.anl.gov
Thu Apr 29 08:14:27 CDT 2010
It appears that you are using Open MPI, not MPICH2.  This list is
primarily for MPICH2 discussion and support.  Please contact the Open
MPI developers at users at open-mpi.org.
-Dave
On Apr 29, 2010, at 12:21 AM, Srujan kumar wrote:
> Hi,
> I am trying to run an MPI program as a CGI Python script which is
> running over an Apache web server running locally on my computer.
> I have a test.py file which has the code snippet
> cmd = 'opt/local/bin/mpiexec -n 7 testmpi'
> output = commands.getoutput(cmd)
> When I run the file test.py as an executable over command line (as ./
> test.py ), it works perfectly fine.
> But when I try to run the same over the web browser, the MPI code
> functions as if the command was 'mpiexec -n 1 testmpi'.
> It is unable to recognize that there are multiple processes that are
> being invoked. In other words it is not forking child processes.
> I checked in to the error log in apache regarding the same. The
> corresponding error code is following:
> [Wed Apr 28 20:32:20 2010] [error] [client ::1] [NeoDen-1261.local:
> 07199] [0,0,0]-[0,0,1] mca_oob_tcp_msg_send_handler: writev failed:
> Broken pipe (32), referer: http://localhost:8888/
> 07199] [0,0,0] ORTE_ERROR_LOG: Communication failure in file /
> SourceCache/openmpi/openmpi-5/openmpi/orte/mca/gpr/replica/
> communications/gpr_replica_recv_proxy_msgs.c at line 49, referer: http://localhost:8888/
> [Wed Apr 28 20:32:20 2010] [error] [client ::1] [NeoDen-1261:07199]
> *** Process received signal ***, referer: http://localhost:8888/
> Signal: Segmentation fault (11), referer: http://localhost:8888/
> Signal code: Address not mapped (1), referer: http://localhost:8888/
> Failing at address: 0x8, referer: http://localhost:8888/
> [ 0] 2   libSystem.B.dylib                   0x00000000803ec3fa
> _sigtramp + 26, referer: http://localhost:8888/
> [ 1] 3   ???                                 0x0000000000000004 0x0
> + 4, referer: http://localhost:8888/
> [ 2] 4   libopen-rte.0.dylib                 0x000000000002dca9
> mca_oob_send_packed_nb + 297, referer: http://localhost:8888/
> [ 3] 5   mca_oob_tcp.so                      0x00000000000f4a8f
> mca_oob_tcp_msg_complete + 175, referer: http://localhost:8888/
> [ 4] 6   mca_oob_tcp.so                      0x00000000000f588a
> mca_oob_tcp_peer_send + 298, referer: http://localhost:8888/
> [ 5] 7   mca_oob_tcp.so                      0x00000000000f9973
> mca_oob_tcp_send_nb + 595, referer: http://localhost:8888/
> [ 6] 8   libopen-rte.0.dylib                 0x000000000002dc4c
> mca_oob_send_packed_nb + 204, referer: http://localhost:8888/
> [ 7] 9   mca_gpr_replica.so                  0x00000000002271a0
> orte_gpr_replica_recv + 304, referer: http://localhost:8888/
> [ 8] 10  libopen-rte.0.dylib                 0x000000000002da13
> mca_oob_recv_packed_nb + 403, referer: http://localhost:8888/
> [ 9] 11  mca_oob_tcp.so                      0x00000000000f5073
> mca_oob_tcp_msg_recv_complete + 771, referer: http://localhost:8888/
> [10] 12  mca_oob_tcp.so                      0x00000000000f6400
> mca_oob_tcp_peer_lookup + 2240, referer: http://localhost:8888/
> [11] 13  libopen-pal.0.dylib                 0x0000000000077f3e
> opal_event_base_loop + 990, referer: http://localhost:8888/
> [12] 14  libopen-pal.0.dylib                 0x000000000006e8ce
> opal_progress + 126, referer: http://localhost:8888/
> [13] 15  mpiexec                             0x0000000000001b9d
> orterun + 2242, referer: http://localhost:8888/
> [14] 16  mpiexec                             0x0000000000001764
> orterun + 1161, referer: http://localhost:8888/
> [15] 17  mpiexec                             0x00000000000012d9 main
> + 27, referer: http://localhost:8888/
> [16] 18  mpiexec                             0x000000000000129c
> start + 52, referer: http://localhost:8888/
> *** End of error message ***, referer: http://localhost:8888/
> [Wed Apr 28 20:32:20 2010] [error] [client ::1] /Users/esrujan/
> apache2/htdocs/cgi-bin/shell.sh: line 29:  7199 Segmentation
> fault      mpiexec -np 10 testmpi, referer: http://localhost:8888/
> Can some one help me what the problem is? Why am I not able to run
> the MPI using a CGI script.
> Thanks a ton for your help,
> Srujan Kumar Enaganti
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
