[mpich-discuss] F90FLAGS "-i4" statement for mpich2 configuration
Pavan Balaji
balaji at mcs.anl.gov
Thu Apr 29 07:22:43 CDT 2010
You can pass F90FLAGS to configure using:
% ./configure --prefix=/opt/mpich2 F90FLAGS=-i4
Alternatively, you can use gfortran as your F90 compiler as well (this
is preferred):
% ./configure --prefix=/opt/mpich2 F77=gfortran F90=gfortran
-- Pavan
On 04/29/2010 06:38 AM, Steenhauer, Kate wrote:
> Hello,
> My mpich2 was configured as follows
> [eng923 at cops-021026 job]$ mpich2version
> MPICH2 Version: 1.2.1p1
> MPICH2 Release date: Unknown, built on Mon Mar 29 14:37:13 BST 2010
> MPICH2 Device: ch3:nemesis
> MPICH2 configure: --prefix=/opt/mpich2
> MPICH2 CC: gcc -O2
> MPICH2 CXX: c++ -O2
> MPICH2 F77: gfortran -O2
> MPICH2 F90: f95 -O2
> When I read the following (see below) in migrating from mpich1 to
> mpich2, is this possibly causding the problem in mpi_scatter? As I am
> using an Intel fortran compiler on a 64 bit linux platform? Would I need
> to reinstall and configure MPIch2 and where and how do I include the
> F90FLAGS "-i4" statement on a bash Shell?
> D.4 Q: When I use the g95 Fortran compiler on a 64-bit
> platform, some of the tests fail
> A: The g95 compiler incorrectly defines the default Fortran integer as a 64-
> bit integer while defining Fortran reals as 32-bit values (the Fortran
> standard
> requires that INTEGER and REAL be the same size). This was apparently
> done to allow a Fortran INTEGER to hold the value of a pointer, rather
> than requiring the programmer to select an INTEGER of a suitable KIND.
> To force the g95 compiler to correctly implement the Fortran standard, use
> the -i4 flag. For example, set the environment variable F90FLAGS before
> configuring MPICH2:
> setenv F90FLAGS "-i4"
> G95 users should note that there (at this writing) are two distributions of
> g95 for 64-bit Linux platforms. One uses 32-bit integers and reals (and
> conforms to the Fortran standard) and one uses 32-bit integers and 64-bit
> reals. We recommend using the one that conforms to the standard (note
> that the standard specifies the /ratio /of sizes, not the absolute
> sizes, so a
> Fortran 95 compiler that used 64 bits for /both /INTEGER and REAL would
> also conform to the Fortran standard. However, such a compiler would need
> to use 128 bits for DOUBLE PRECISION quantities).
> Thanks kate
> The University of Aberdeen is a charity registered in Scotland, No SC013683.
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
