[mpich-discuss] MPI_IN_PLACE argument
    Steenhauer, Kate
    k.steenhauer at abdn.ac.uk
    Wed Apr 28 10:17:03 CDT 2010
The scatter routine looks like this (see below), as far as I can see the sendbuf is based on the number of nodes set by the user. Again I don't understand that this can run with mpich1 and not with mpich2, since it is not the bug that was reported earlier, as A (sendbuf) and B (recbuf) are distinct arrays.
real A(nx,ny,nz), B(nx_1,ny_1,nz_1)
    real, allocatable :: sendbuf(:)
    integer i1(nproc), i2(nproc), &
            j1(nproc), j2(nproc), &
            k1(nproc), k2(nproc)
    ! Scatter an array among the processors
    ! including overlapping borders
    if (myid == idroot) then
        do ip=1,nproc
            i1(ip) = ibmino_1(icoord(1,ip))
            j1(ip) = jbmino_1(icoord(2,ip))
            k1(ip) = kbmino_1(icoord(3,ip))
        end do
        i2 = i1 + nx_1 - 1
        j2 = j1 + ny_1 - 1
        k2 = k1 + nz_1 - 1
        allocate (sendbuf(nproc*nxyz_1))
        L = 0
        do ip=1,nproc
            do k=k1(ip),k2(ip)
            do j=j1(ip),j2(ip)
            do i=i1(ip),i2(ip)
                L = L + 1
                sendbuf(L) = A(i,j,k)
            end do
            end do
            end do
        end do
    end if
call MPI_scatter (sendbuf, nxyz_1, MPI_REAL8, &
                      B, nxyz_1, MPI_REAL8, &
                      idroot, icomm_grid, ierr)
    call updateBorder(B, nx_1,ny_1,nz_1, 1, 1)
    call updateBorder(B, nx_1,ny_1,nz_1, 2, 2)
    call updateBorder(B, nx_1,ny_1,nz_1, 3, 3)
    if (myid == idroot) deallocate (sendbuf)
    return
end
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev Thakur
Sent: 28 April 2010 16:07
Subject: Re: [mpich-discuss] MPI_IN_PLACE argument
Make sure the sendbuf is allocated to be large enough.
Rajeev
> Steenhauer, Kate
> Sent: Wednesday, April 28, 2010 9:48 AM
> Ok, any idea what this could be then? Thanks kate
> Sent: 28 April 2010 15:17
> If sendbuf and B are distinct arrays, you don't need to use
> MPI_IN_PLACE. The problem is something else then.
> Rajeev
> > [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Steenhauer,
> > Kate
> > Sent: Wednesday, April 28, 2010 5:10 AM
> > To: mpich-discuss at mcs.anl.gov; 'Anthony Chan'
> > Subject: [mpich-discuss] MPI_IN_PLACE argument
> > Hi,
> > I am trying to sort the bug in the mpi program (see attached). It
> > seems to me, with my very limited knowledge, that everything is
> > related and the whole program needs to be restructed when upgrading
> > from mpich1 to mpich2? If the MPI_Scatter routine flags a bug (The
> > error message is 'memcpy argument memory ranges overlap,
> > dst_=0xafd74f8 src_=0xafd750c len_=16200, internal ABORT'), then it
> > is, as far as I can see, most likely that the other
> routines, such as,
> > gather(A, B), allGather(A, B), scatterXY(A, B, nk),gatherXY(A, B,
> > nk),allGatherXY(A, B, nk) etc. (see attached), will bring
> up a similar
> > bug as well. So I don't really know where to start,
> considering this
> > is a well-established code, run for many years successfully with
> > mpich1 with sensible output.
> > By using the MPI_IN_Place argument I have to replace the recvbuf,
> > B(nx_1,ny_1,nz_1)?
> >                       idroot, icomm_grid, ierr) I hope you will be
> > able to help me.
> > kate
> Rajeev Thakur
> > Sent: 27 April 2010 17:32
> > Subject: Re: [mpich-discuss] configuration problem
> > Kate,
> >      You have to use the mpif.h file that comes with the MPI
> > implementation, not from some other MPI implementation.
> With MPICH2,
> > you have to use MPICH2's include file.
> > The error with MPI_Scatter indicates there is a bug in your MPI
> > program.
> > You are using the same buffer as sendbuf and recvbuf, which is not
> > allowed in MPI. You can use the MPI_IN_PLACE argument instead, as
> > described in the MPI standard.
> > I would recommend using MPICH2 instead of trying to get
> > MPICH-1 to work.
> > Rajeev
> Steenhauer,
> > > Kate
> > > Sent: Tuesday, April 27, 2010 9:50 AM
> > > To: Anthony Chan; mpich-discuss at mcs.anl.gov
> > > Initially, I tried to run my code with mpich2. The
> > following happens.
> > > We have 1 workstation with 8 processors, the following
> > > software: Linux Centos, Fortran Intel 11.1.
> > > Mpich2, Intel Fortran and Linux is not working on our pc.
> > It does not
> > > like the mpif.inc file, it immediately gets into problems at the
> > > initialisation of the MPI (subroutine MPI_INI).
> > > mpirun -np 8 RUN02
> > > > Fatal error in MPI_Comm_size: Invalid communicator, error stack:
> > > > MPI_Comm_size(111): MPI_Comm_size(comm=0x5b,
> size=0x7fffce629784)
> > > > failed
> > > > MPI_Comm_size(69).: Invalid communicator MPISTART
> > > > rank 7 in job 2  cops-021026_40378   caused collective
> > > abort of all ranks
> > > >  exit status of rank 7: killed by signal 9
> > > Then when I change the mpif.inc file (see attachment) and
> > direct it to
> > > the mpif.h file that came with the mpich2 library, it gets
> > passed this
> > > problem but then runs into a next problem further down
> the line at
> > > MPI_SCATTER, where it is trying to distribute data to the
> different
> > > processors. The error message is 'memcpy argument memory ranges
> > > overlap,
> > > dst_=0xafd74f8 src_=0xafd750c len_=16200, internal ABORT'.
> > > There is something in the parametresiation within the mpi that is
> > > possibly different then when the code is successfully run
> > on another
> > > cluster (this cluster uses Redhat, various mpich versions, e.g.
> > > mpich-1.2.5..12, and various versions of Intel FORTRAN compiler
> > > (ifort), e.g. 7, 9 and 12).
> > > I have attached the mpif.inc file.
> > > Please let me know if you have any ideas?
> > > Thanks
> > > Kate
> > > chan at mcs.anl.gov
> > > Sent: 27 April 2010 15:42
> > > Is there any reason you can't use mpich2 ?  The latest
> > stable release
> > > of mpich2 is 1.2.1p1.
> > > mpich-1 is no longer officially supported.  Latest fortran
> > compilers
> > > are much better supported in mpich2.
> > > A.Chan
> > > ----- "Kate Steenhauer" <k.steenhauer at abdn.ac.uk> wrote:
> > > > Hello,
> > > > We are trying to install mpich-1.2.7p1. I downloaded and
> > > unzipped this
> > > > version from
> http://www.mcs.anl.gov/research/projects/mpi/mpich1/
> > > > We have 1 workstation with 8 processors, and the
> > following software:
> > > > Linux Centos and Fortran Intel 11.1.
> > > > When the documentation guidelines with regard to
> configuring and
> > > > making are followed (see the files attached) it all
> seems ok, e.g.
> > > > mpif90 is generated. However, when a simple parallel job is
> > > tested we
> > > > get the following error:
> > > > mpif90 -o testA MPITEST.f90
> > > > No Fortran 90 compiler specified when mpif90 was created, or
> > > > configuration file does not specify a compiler.
> > > > Is there a specific prefix I need to give with an ifort fortran
> > > > compiler when I configure mpich?
> > > > I would like to thank you in advance for your help. Please
> > > let me know
> > > > if you need any further details.
> > > > Regards
> > > > Kate Steenhauer
> > > > University of Aberdeen
> > > > 01224-272806
> > > > The University of Aberdeen is a charity registered in
> > Scotland, No
> > > > SC013683.
> > > > _______________________________________________
> > > > mpich-discuss mailing list
> > > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Scotland, No
> > > SC013683.
> > The University of Aberdeen is a charity registered in Scotland, No
> > SC013683.
> Scotland, No SC013683.
The University of Aberdeen is a charity registered in Scotland, No SC013683.
