[mpich-discuss] Cannot run MPI pgm on x5460
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Wed Apr 28 10:12:40 CDT 2010
 Please provide us details on your problem.
# What is the OS installed on the machine ?
# Which version of MPICH2 is installed on the machine (Did you get any error messages during install ? )?
# Where you able to run any MPI programs on the machine (Is this the first time ?)?
# What is the value of %MPIRUN% (Does it point to mpiexec from MPICH2)?
# Can you run simple non-MPI programs like hostname (mpiexec -n 2 hostname)?
# Can you run simple MPI programs on the machine (mpiexec -n 2 c:\progra~1\mpich2\examples\cpi.exe)?
# If you have any firewalls running on the machine, try turning the firewall off and re-running your code.
Jayesh
----- Original Message -----
To: mpich2-maint at mcs.anl.gov
Sent: Wednesday, April 28, 2010 10:02:55 AM GMT -06:00 US/Canada Central
Subject: [mpich2-maint] (no subject)
I get the following error when trying to verify mpi installation on my x5460 machine. Can you offer any help?
Thanks
Stan Pade
c:\ldi\pOWERBALL\1004>%MPIRUN% -genvlist VNI_F90_MSG -n 4 imslmpi.exe
Error while connecting to host, No connection could be made because the target machine actively refused it. (10061)
Connect on sock (host=Basia-Pc, port=8676) failed, exhaused all end points
Unable to connect to 'Basia-Pc:8676',
sock error: Error = -1
mpich2-maint mailing list
mpich2-maint at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/mpich2-maint
