[mpich-discuss] configuration problem
Steenhauer, Kate
k.steenhauer at abdn.ac.uk
Tue Apr 27 14:02:38 CDT 2010
Thanks for your reply. I will look into it. Note that I am relatively new to this, I do have another question related to your answer. The code I am trying to compile is successfully run in parallel on another cluster (this cluster uses Redhat, various mpich1 versions, e.g. mpich-1.2.5..12, and various versions ofIntel FORTRAN compiler (ifort), e.g. 7, 9 and 12). How is it that I can have a bug in the MPI program as I directly copied the whole code on to my workstation? Is this because there are discrepancies between mpich1 and mpich2? If so, MPI_Scatter routines seems to be correctly working on one cluster with mpich1 and not on my workstation with mpich2? This is why I tried to imitate the other cluster as much as possible and tried installing mpich1, which gives yet another problem, i.e. the configuration problem, described below.
Have you got an anwer for this maybe? And did you have a look at my mpif.inc file as other people using the other cluster tell me it is compatible and in use with different mpi versions.
Thanks
Kate
From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev Thakur [thakur at mcs.anl.gov]
Sent: 27 April 2010 17:32
To: mpich-discuss at mcs.anl.gov; 'Anthony Chan'
Subject: Re: [mpich-discuss] configuration problem
Kate,
You have to use the mpif.h file that comes with the MPI
implementation, not from some other MPI implementation. With MPICH2, you
have to use MPICH2's include file.
The error with MPI_Scatter indicates there is a bug in your MPI program.
You are using the same buffer as sendbuf and recvbuf, which is not
allowed in MPI. You can use the MPI_IN_PLACE argument instead, as
described in the MPI standard.
I would recommend using MPICH2 instead of trying to get MPICH-1 to work.
Rajeev
> -----Original Message-----
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
> Steenhauer, Kate
> Sent: Tuesday, April 27, 2010 9:50 AM
> To: Anthony Chan; mpich-discuss at mcs.anl.gov
> Initially, I tried to run my code with mpich2. The following happens.
> We have 1 workstation with 8 processors, the following
> software: Linux Centos, Fortran Intel 11.1.
> Mpich2, Intel Fortran and Linux is not working on our pc. It
> does not like the mpif.inc file, it immediately gets into
> problems at the initialisation of the MPI (subroutine MPI_INI).
> mpirun -np 8 RUN02
> > Fatal error in MPI_Comm_size: Invalid communicator, error stack:
> > MPI_Comm_size(111): MPI_Comm_size(comm=0x5b, size=0x7fffce629784)
> > failed
> > MPI_Comm_size(69).: Invalid communicator MPISTART
> > rank 7 in job 2 cops-021026_40378 caused collective
> abort of all ranks
> > exit status of rank 7: killed by signal 9
> Then when I change the mpif.inc file (see attachment) and
> direct it to the mpif.h file that came with the mpich2
> library, it gets passed this problem but then runs into a
> next problem further down the line at MPI_SCATTER, where it
> is trying to distribute data to the different processors. The
> error message is 'memcpy argument memory ranges overlap,
> dst_=0xafd74f8 src_=0xafd750c len_=16200, internal ABORT'.
> There is something in the parametresiation within the mpi
> that is possibly different then when the code is successfully
> run on another cluster (this cluster uses Redhat, various
> mpich versions, e.g. mpich-1.2.5..12, and various versions of
> I have attached the mpif.inc file.
> Please let me know if you have any ideas?
> Thanks
> Kate
> chan at mcs.anl.gov
> Sent: 27 April 2010 15:42
> Is there any reason you can't use mpich2 ? The latest stable
> release of mpich2 is 1.2.1p1.
> mpich-1 is no longer officially supported. Latest fortran compilers
> are much better supported in mpich2.
> A.Chan
> ----- "Kate Steenhauer" <k.steenhauer at abdn.ac.uk> wrote:
> > Hello,
> > We are trying to install mpich-1.2.7p1. I downloaded and
> unzipped this
> > version from http://www.mcs.anl.gov/research/projects/mpi/mpich1/
> > We have 1 workstation with 8 processors, and the following software:
> > Linux Centos and Fortran Intel 11.1.
> > When the documentation guidelines with regard to configuring and
> > making are followed (see the files attached) it all seems ok, e.g.
> > mpif90 is generated. However, when a simple parallel job is
> tested we
> > get the following error:
> > mpif90 -o testA MPITEST.f90
> > No Fortran 90 compiler specified when mpif90 was created, or
> > configuration file does not specify a compiler.
> > Is there a specific prefix I need to give with an ifort fortran
> > compiler when I configure mpich?
> > I would like to thank you in advance for your help. Please
> let me know
> > if you need any further details.
> > Regards
> > Kate Steenhauer
> > University of Aberdeen
> > 01224-272806
> > The University of Aberdeen is a charity registered in Scotland, No
> > SC013683.
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Scotland, No SC013683.
The University of Aberdeen is a charity registered in Scotland, No SC013683.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100427/ae9769ab/attachment.diff>
