[mpich-discuss] Problems with Pcontrol and MPE2 -- fixed, please accept this patch
Brian Wainscott
brian at lstc.com
Tue Apr 27 11:29:53 CDT 2010
Hi Anthony,
OK, I've created a short program that does this:
1 -- creates and dups some communicators
2 -- frees some of them
3 -- uses some of them, then frees them.
It can be compiled without any calls to MPI_Pcontrol, in which case it runs fine
and produces a log file. It can also be compiled with calls to MPI_Pcontrol(0)
just before (1) and a call to MPI_Pcontrol(1) between (2) and (3). (see
WITH_PCONTROL at the top of the source file).
If I build it with the MPI_Pcontrol calls in place, it segfaults with your latest
changes. Hopefully this will help you figure out what is going on.
I'm using OpenMPI with MPE2, but I really don't think that matters. I built it
with this command:
mpecc -mpilog -o dynasim dynasim.c
and ran it on 4 processors.
Good luck, and let me know what you find out.
Brian
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100427/7eebd6ae/attachment.c>
