[mpich-discuss] configuration problem
    Steenhauer, Kate
    k.steenhauer at abdn.ac.uk
    Tue Apr 27 09:50:00 CDT 2010
Initially, I tried to run my code with mpich2. The following happens.
We have 1 workstation with 8 processors, the following software: Linux Centos, Fortran Intel 11.1.
Mpich2, Intel Fortran and Linux is not working on our pc. It does not like the mpif.inc file, it immediately gets into problems at the initialisation of the MPI (subroutine MPI_INI).
mpirun -np 8 RUN02
> Fatal error in MPI_Comm_size: Invalid communicator, error stack:
> MPI_Comm_size(111): MPI_Comm_size(comm=0x5b, size=0x7fffce629784)
> failed
> MPI_Comm_size(69).: Invalid communicator MPISTART
> rank 7 in job 2  cops-021026_40378   caused collective abort of all ranks
>  exit status of rank 7: killed by signal 9
Then when I change the mpif.inc file (see attachment) and direct it to the mpif.h file that came with the mpich2 library, it gets passed this problem but then runs into a next problem further down the line at MPI_SCATTER, where it is trying to distribute data to the different processors. The error message is 'memcpy argument memory ranges overlap, dst_=0xafd74f8 src_=0xafd750c len_=16200, internal ABORT'.
There is something in the parametresiation within the mpi that is possibly different then when the code is successfully run on another cluster (this cluster uses Redhat, various mpich versions, e.g. mpich-1.2.5..12, and various versions of Intel FORTRAN compiler (ifort), e.g. 7, 9 and 12).
I have attached the mpif.inc file.
Please let me know if you have any ideas?
Thanks
Kate
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of chan at mcs.anl.gov
Sent: 27 April 2010 15:42
Subject: Re: [mpich-discuss] configuration problem
Is there any reason you can't use mpich2 ?  The latest stable
release of mpich2 is 1.2.1p1.
mpich-1 is no longer officially supported.  Latest fortran compilers
are much better supported in mpich2.
A.Chan
----- "Kate Steenhauer" <k.steenhauer at abdn.ac.uk> wrote:
> Hello,
> We are trying to install mpich-1.2.7p1. I downloaded and unzipped this
> version from http://www.mcs.anl.gov/research/projects/mpi/mpich1/
> We have 1 workstation with 8 processors, and the following software:
> Linux Centos and Fortran Intel 11.1.
> When the documentation guidelines with regard to configuring and
> making are followed (see the files attached) it all seems ok, e.g.
> mpif90 is generated. However, when a simple parallel job is tested we
> get the following error:
> mpif90 -o testA MPITEST.f90
> No Fortran 90 compiler specified when mpif90 was created, or
> configuration file does not specify a compiler.
> Is there a specific prefix I need to give with an ifort fortran
> compiler when I configure mpich?
> I would like to thank you in advance for your help. Please let me know
> if you need any further details.
> Regards
> Kate Steenhauer
> University of Aberdeen
> 01224-272806
> The University of Aberdeen is a charity registered in Scotland, No
> SC013683.
> mpich-discuss mailing list
The University of Aberdeen is a charity registered in Scotland, No SC013683.
Desc: mpif.inc
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100427/307ca93a/attachment.obj>
