[mpich-discuss] Sending Dynamically Allocated Data
    Dave Goodell
    goodell at mcs.anl.gov
    Mon Apr 26 11:43:50 CDT 2010
Based on your backtrace, I don't think that you are using MPICH2.
However, with that said, I think I see the problem.  You pass
"(npart*size)" as the value for recvcount, but this should be "npart"
instead.  The MPI standard says that this value is the "number of
elements received from any process".
-Dave
On Apr 26, 2010, at 11:05 AM, Duro, Joao wrote:
> Hi there,
> I am trying to send a dynamically allocated structure using
> MPI_Allgather().
> My objective is to gather all the population in the master node and
> then distribute it to all other processes.
> All the code is here:
> http://codepad.org/URczlAEl
> I am getting segmentation from memcpy() called by MPI_Allgather().
> I am probably doing something wrong regarding sending dynamic
> allocated data.
> Could someone have a look?!
> Regards,
> Joao
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
